MeneMene Posted April 13, 2018 Share Posted April 13, 2018 I have the Tamiya Meteor F1 up next, and the cockpit is very crude and simple. Eduard doesn't have much PE for it, and I can't find any resin detail sets. Any suggestions? Is the old Eduard PE set (48211) really my best option? Thanks Link to comment Share on other sites More sharing options...
Seawinder Posted April 13, 2018 Share Posted April 13, 2018 1 hour ago, MeneMene said: I have the Tamiya Meteor F1 up next, and the cockpit is very crude and simple. Eduard doesn't have much PE for it, and I can't find any resin detail sets. Any suggestions? Is the old Eduard PE set (48211) really my best option? Thanks IMHO, yes, having just finished the same kit. The Eduard set includes a seat, which is not hard to fold into shape and is more accurate in size than the kit part. The instrument panel is a sandwich with film for the instrument faces. There's also a number of other detail bits to make the area somewhat busier. I also used some pre-painted Eduard RAF seat belts. Do bear in mind that the whole cockpit is basically black, and with the canopy in place (open or closed), the lack of detail is not going to pop out particularly. Link to comment Share on other sites More sharing options...
Bob C. Posted April 13, 2018 Share Posted April 13, 2018 You might want to check my post of Feb 19, in which Navy870 and rossm provided some very interesting info, even if it was somewhat on the 1/72 Cyber Hobby F.3. Good luck, Bob C. Link to comment Share on other sites More sharing options...
TBC Posted April 13, 2018 Share Posted April 13, 2018 (edited) 22 hours ago, MeneMene said: I have the Tamiya Meteor F1 up next, and the cockpit is very crude and simple. Eduard doesn't have much PE for it, and I can't find any resin detail sets. Any suggestions? Is the old Eduard PE set (48211) really my best option? Thanks Hi Tech made one for this kit. I've had one for donkey's years. I have absolutely no memory of where I purchased it. It's pretty good. FWIW, a build on Hyperscale using it in the F.3 kit. http://hsfeatures.com/features04/meteorf3wb_1.htm Edited April 14, 2018 by TBC Link to comment Share on other sites More sharing options...
fernandocouto Posted April 15, 2018 Share Posted April 15, 2018 Eduard PE is a good solution. Or you may scratchbuild some details, cause the cockpit is mostly black, details do not make so much sense as a interior green cockpit. The easiest method....put the "huge" pilot the kit provides. It looks as Czech striker Jan Koller.... Link to comment Share on other sites More sharing options...
