Sairou Posted April 12, 2018 Posted April 12, 2018 I am unsure how exactly to use the film provided in eduard etch sets (like in the pic provided). I have a rough idea, but I'm not sure if I should paint the dials from behind, or what. Could someone with a little more experience please help? I have a few projects where there is film provided for dials and etc. Thanks, CS.
dnl42 Posted April 12, 2018 Posted April 12, 2018 The film usually goes behind the PE. Take a look at page 6 on the instructions for that set, it shows the PE IP part 23 plus the film plus model part G6. The film usually has clear bits, I'll generally paint the film backside or the backing plastic part white or silver. 1
Sairou Posted April 12, 2018 Author Posted April 12, 2018 18 minutes ago, dnl42 said: The film usually goes behind the PE. Take a look at page 6 on the instructions for that set, it shows the PE IP part 23 plus the film plus model part G6. The film usually has clear bits, I'll generally paint the film backside or the backing plastic part white or silver. Thank you. To clarify, that is not the set I had, just the first example I could find at the moment. That's what I thought I should do, and I'll try that relatively soon. Thank you.
