Bladerunner Posted April 12, 2018 Share Posted April 12, 2018 (edited) Hi guys, I started scratch building a 1/48 UH-60 Upturned Exhaust System (as used on the UH-60L/M) for the Italeri UH-60/MH-60 Black Hawk. The original exhaust openings were filled with epoxy clay and shaped, then the majority of upturned exhausts was built. It was becoming a bit difficult to work on the model, so the engine deck was removed. The exhaust stacks and louvers were made from plastic card. The APU outlet on the kit was rather vague, so it was drilled out and replaced with a section of aluminium tube to look more presentable. The test fit on the host kit was a bit rough, as it is missing some material where the cutting disc was used. Cheers, John Edited September 15, 2018 by Bladerunner Missing text 1 Link to comment Share on other sites More sharing options...
exdraken Posted April 12, 2018 Share Posted April 12, 2018 Great work! You'd need to cast those..... Link to comment Share on other sites More sharing options...
Bladerunner Posted April 12, 2018 Author Share Posted April 12, 2018 Thanks exdraken, that is the plan. I'll have the molds ready soon, and post some pictures of the first casting. 1 Link to comment Share on other sites More sharing options...
Red Dot Posted April 14, 2018 Share Posted April 14, 2018 proper modelling, well done and guess what, my first thought was also casting! Andy Link to comment Share on other sites More sharing options...
Richard E Posted April 14, 2018 Share Posted April 14, 2018 54 minutes ago, Red Dot said: proper modelling, well done and guess what, my first thought was also casting! Andy Andy - you said just what I was thinking. Link to comment Share on other sites More sharing options...
Bladerunner Posted April 14, 2018 Author Share Posted April 14, 2018 Thanks guys. The molds were made, and here is the first test casting. It's a very tricky part to cast and even more to take out of the mold, but I'm pleased with the result. 3 Link to comment Share on other sites More sharing options...
Bladerunner Posted September 15, 2018 Author Share Posted September 15, 2018 Hi guys, I finally got some time to make the master for the new wider chord composite main rotor blades master to compliment the Upturned Exhaust System. Should have the molds ready soon. Should anyone be interested, please send me an e-mail to [email protected] 🙂 Cheers, John 2 Link to comment Share on other sites More sharing options...
Bladerunner Posted September 17, 2018 Author Share Posted September 17, 2018 First set of composite main rotor blades test fitting Cheers, John 1 Link to comment Share on other sites More sharing options...
flarpen Posted September 26, 2018 Share Posted September 26, 2018 Looks very nice indeed. I would be interested in those blades to go with the upturned exhaust. Will you be molding them with some kind of strengthening to keep the blades from saging? /Johan Link to comment Share on other sites More sharing options...
Bladerunner Posted September 26, 2018 Author Share Posted September 26, 2018 Hi Johan, Glad you like the set. The blades are cast with a different resin that doesn't sag beyond what you see in the pictures. The test assembled blades has proven successful, and hasn't sagged. If you want to order a set of blades and upturned exhausts, please send me an email to [email protected] Cheers, John Link to comment Share on other sites More sharing options...
