Sign in to follow this
PhantomBigStu
Revell Victor K2
Only just occurred to me, I have a new bench much larger than my old one, and a nimrod and victor in the stash, why not get one of them out (or buy a cheap Revell Vic tanker  and sell the airfix bomber) for this GB...
Edited by PhantomBigStu
Or you could fill it with loads of smaller aircraft Stu,I have the Revell Victor and it's not a bad old girl just those intakes which when I get round to doing
it I'll scratch build some FOD covers.
Indeed though it’s been nothing but small or small to medium builds since the new year (b52 aside), fancy a change. So it will be the nimrod, a victor from airfix or revell or the Halifax I’d forgotten is in the wardrobe part of my stash. Plenty of time to think. I have to assemble the new bench  tomorrow
Feeling a bit cowardly now the bench is up and running, want to do the victor, but my prior experience with spraying white has not been very successful, and the thought of doing even a half white victor is  scary, so im currently high bidder on a revell one that ends later, so if I win it'll be hemp victor.....if not a hemp nimrod
So my cowardice has decided that it will be a Revell victor, having finished the auction as winner
The Revell Victor builds up into a nice model - not without its issues but I think they can all be overcome easily enough. There have been some great builds on BM so worth searching for them. I’d go with Steve’s suggestion and make some intake covers though, although there is a Flightpath set which includes resin intakes and loads of PE.
I beat airfix Vulcans intakes, just a step or two up for the victor, or could even nick parts from the airfix and replace them later  using airfix spares....
If you had waited, you would've been up against the time window got the GB - good to have it with us!
Revel kits arrived, may dig the airfix out just to have a fondle and perhaps see if I can rustle up the odd improvement to the cockpit.
When I lived in the UK I discovered Halfords Matt white primer in a spray can. This is a really great dense coat of white and sprays from the can. I used it a lot and once you have a good finish a light sand with 1000 grit and a spray with gloss white from the airbrush gave a beautiful finish. I tried the appliance white and Ford white but the gloss is too thick a coat so would not recommend.
My choice every time.
Colin
Colin
I like it too.  I generally go for two thin coats if I need the full impact of the white
Colin
Apart from the airbrush that exactly how I would do it,  and that was the problem, app white comes way to thick as you say
Finding a way to keep it alive will be a challenge but anyway filler applied to everywhere it’s needed on the upper surfaces and inside the intakes and jet pipes
To keep this thread alive dug this out, had started this before the victor before putting it away demoralised (why is probably obvious) , its a hybrid build being parts from 3 different copies, from the main fuselage and everything else from one kit, the cockpit from a build that never made it and the forward fuselage actually being salvaged from a finished build I did over 3 years ago. Should at least try a but before binning it
Sanding the that upper fuselage was relatively simple affair, the lower fuselage not so much, significant misalignment, which may be unfixable
21 minutes ago, stever219 said:
Is the Norfolk Land Shark Tornado planned to wear markings for one of the Marham-based units?
Indeed, 617 markings with wrap around camo
