Hardtarget
HT's other Mitchell's Son
For my second build which will run in-conjunction with the Airfix offering, ill be making the Hasegawa J version.
Box
26500369937_88836840bd_h.jpgDSC_0288 by stuart wellard, on Flickr
Pit and bomb bay assembled.
39562194110_09b6863fb1_h.jpgDSC_0289 by stuart wellard, on Flickr
A bit more details with lumps and bumps in this J version than the C/D.
40658249674_405c885263_h.jpgDSC_0290 by stuart wellard, on Flickr
Got the Gun loaded with Vallejo MA interior Green.
41328649102_934b2b2d61_h.jpgDSC_0291 by stuart wellard, on Flickr
40476814115_793b53ada6_h.jpgDSC_0292 by stuart wellard, on Flickr
41328648462_e0b9c6bccf_h.jpgDSC_0293 by stuart wellard, on Flickr
Great start Hardtarget, are you doing the scheme on the box?
Nope, i shall be doing another scheme from the DK decal sheet, so will have a Mk.II & mk.III when done.
Ok, a bit of progress on this bird.
Cockpit painted along with other internal bits requiring some colour.
41847935222_3569b7036e_h.jpgDSC_0298 by stuart wellard, on Flickr
Engines
41847934872_5dc1e00595_h.jpgDSC_0299 by stuart wellard, on Flickr
Engine Nacelles to wing.  No issues apart form a small bit of sanding on top of the air intake to the wing nascelle.
40992178895_a600ed4297_h.jpgDSC_0300 by stuart wellard, on Flickr
Internal compartments starting to be cemented to the fuselage halves.
41847934332_8b0ee7414f_h.jpgDSC_0301 by stuart wellard, on Flickr
Fuselage cemented along with the wings attached.  I added weight to the fuselage nose opposite side to the nose wheel oleo.  AND i dropped some liquid gravity in the nacelles. I dropped it in through the U/C opening once everything has set.  This way i could temporarily affix the u/c in place put the wheels on and see where her equilibrium is.  the shot was held in place with PVA also just dropped in the hole. Warning! you need to keep her nose down to prevent any PVA from oozing out of the wheel wells.
40992178515_cd7d3a4a04_h.jpgDSC_0302 by stuart wellard, on Flickr
Masking time, with the aid of an Eduard set which is a must as there is a lot of glazing.
41847933692_b1bdeb1b30_h.jpgDSC_0303 by stuart wellard, on Flickr
All masked up ready for some internal colour then primer.
40992177815_1dbaf50399_h.jpgDSC_0304 by stuart wellard, on Flickr
Wheels getting some treatment.
41847932882_d13dbd16e3_h.jpgDSC_0305 by stuart wellard, on Flickr
Edited by Hardtarget
Thats coming along great Stuart. interior looks great, almost seems a shame it won't be seen.
Right Home run on this bird.
She was primed using stynyrez then airbrushed using vallejo OD and NG. Decals applied using Daco strong fluid.  Bit more detailing then a flat coat with masking then removed and some weathering but i doubt this will be done today as its another hot one day today and its too hot in the office.
43128404151_8571e3a064_h.jpgDSC_0075 by stuart wellard, on Flickr
