Graeme H Posted April 3, 2018 Share Posted April 3, 2018 another for shotgun pellets, I got the opportunity to help myself to about 100Kgs for free, decided on several Kgs, would be more than enough, will outlast me, I use CA mostly but have used white glue quite a lot if I think the plastic is going to melt Link to comment Share on other sites More sharing options...
Rob G Posted April 4, 2018 Share Posted April 4, 2018 4 hours ago, Graeme H said: about 100Kgs ! That's a lot of shot. Link to comment Share on other sites More sharing options...
Sturmovik Posted April 4, 2018 Share Posted April 4, 2018 Depends on the model, when I built Trumpeter´s Me 262 in 32nd I used one 100 grams weight cut in half with a razor saw and glued to the forward bulkhead with epoxy glue, but when I build Hobbycraft´s Skyhawk, I used smaller, lighter, and cylindrically shaped weights and also cut with a razorsaw. Link to comment Share on other sites More sharing options...
Giorgio N Posted April 4, 2018 Share Posted April 4, 2018 Simple fishing weights, that I sometime flatten if this helps fitting them into small spaces. I prefer using silicone sealant to fix them in place as this guarantees adhesion also in case of hits to the model. In any case keeping a B-24 model on the nose wheels is never easy, same for other aircrafts with extensive front glazings like the B-25 and 26. I had the landing gear collapse on a B-26 where I had to stuff the nacelles with lead. Link to comment Share on other sites More sharing options...
John R Posted April 4, 2018 Share Posted April 4, 2018 I use Milliput to to keep bits of lead in place Link to comment Share on other sites More sharing options...
MilneBay Posted April 4, 2018 Share Posted April 4, 2018 .45 or .38 cal. bullets, fishing sinkers even sheet lead. Whatever is to hand. I use Blu Tac to fix them in place and have never had any leaching problems with it. I don't regard using lead as hazardous as I'm not actually eating the stuff so don't fall for the nanny state health and safety stuff. Just remember that standing behind every OH&S dweeb is a nagging woman. Link to comment Share on other sites More sharing options...
Sydhuey Posted April 4, 2018 Share Posted April 4, 2018 I use lead shot , got about a Kg from a mate who reloads, were possible I just pour the shot in to fill the hole and hold in place with white glue, for some models without much room I have made little moulds and melted the lead to get max weight for the space, takes a bit of time but yields results with more weight. Link to comment Share on other sites More sharing options...
bentwaters81tfw Posted April 4, 2018 Share Posted April 4, 2018 Lead Customs seals, although you can't get them now. Offcuts of roof flashing, fine lead shot, and a mound of flattened lead airgun pellets from a rifle range. Fishing and wheel weights, steel balls, bolts, or whatever is to hand. I tried Georgio's silicone method. A definite convert. Link to comment Share on other sites More sharing options...
little-cars Posted April 5, 2018 Share Posted April 5, 2018 We sell 200g bottles of steel shot for weighting models down. Have had a bit of a run on them recently. Liquid Steel 200g Ta, Paul Link to comment Share on other sites More sharing options...
