Uncle Uncool 984 Posted April 1, 2018 Share Posted April 1, 2018 (edited) Hi there, lads. How's it hangin'? I was trying to remember whether it was CMK, Pavla, Wolfpack, Armory, Reskit, Royale Resin or... the ones who made 'em, but not the Eduard ones, please. Need 'em for my Argie Sabres build. Yeh, me does. Thanks in advance! Cheers, Unc2 Edited April 1, 2018 by Uncle Uncool I'm SO dumb! Link to post Share on other sites
Sabrejet 4,983 Posted April 2, 2018 Share Posted April 2, 2018 You can use both 'solid' and 'spoked' wheels for FAA F-86Fs (the Eduard ones are fine for the latter!). However I can't recall any 1/48 aftermarket 'solid' versions. Link to post Share on other sites
Uncle Uncool 984 Posted April 6, 2018 Author Share Posted April 6, 2018 Thanks for the reply, my mate. It's just me needs the solid ones, y'see? Nice scheme this one. Anybody else, chaps? Please? I knew someone aftermarketed this type, it's just I can't seem to be able to recall who. Cheers, Unc2 Link to post Share on other sites
Sabrejet 4,983 Posted April 6, 2018 Share Posted April 6, 2018 That's a ground trainer at Escuela de Reactores: hence the shield. I'd take a look at T-33 a/m because the solid T-bird wheels are the same. Failing that, just use the spoked wheel! Link to post Share on other sites
vesthepes 625 Posted April 7, 2018 Share Posted April 7, 2018 (edited) There are five different nose wheel types on the F-86. Same wheels can be used on the T-33. Sabers and T-33s in the Yugoslav AF switched wheels often, that means you could see the same plane with different type front wheel. If you don't have the full rim one just use another one... Edited April 7, 2018 by vesthepes 1 Link to post Share on other sites
Uncle Uncool 984 Posted April 7, 2018 Author Share Posted April 7, 2018 On 06/04/2018 at 12:58 PM, Sabrejet said: I'd take a look at T-33 a/m because the solid T-bird wheels are the same. Failing that, just use the spoked wheel! No luck finding the solid nose wheel for the T-birds either... Me said I fancied using the solid wheel! 9 hours ago, vesthepes said: There are five different nose wheel types on the F-86. Same wheels can be used on the T-33. Yeh, I know about that, it's only that I've ne'er seen an Argie Sabre with the type of wheel spoke of the piccy I quoted above, which is the type offered on "they're" Hasegawa kit. Worse still; now me's already ruined that nose wheel trying to modify it while turning it on the lathe... Link to post Share on other sites
vesthepes 625 Posted April 7, 2018 Share Posted April 7, 2018 Just change the wheel, like they did... don't overkill that, it's just a wheel Link to post Share on other sites
Sabrejet 4,983 Posted April 7, 2018 Share Posted April 7, 2018 29 minutes ago, Uncle Uncool said: Yeh, I know about that, it's only that I've ne'er seen an Argie Sabre with the type of wheel spoke of the piccy I quoted above, which is the type offered on "they're" Hasegawa kit. Not common on FAA F-86Fs, but they were used: 1 Link to post Share on other sites
Uncle Uncool 984 Posted April 7, 2018 Author Share Posted April 7, 2018 Bummer, now I don't even have the option of using the type of wheel which the kit brought. So, how much do you lads think P&H will be for just a nose wheel replacement from Japan to Argieland? Hello, Hasegawa? Come again...???? Such a stubborn bloke I am. Thank you both, fellas. Cheers dr(Unc)2 Link to post Share on other sites
Tony Edmundson 662 Posted April 8, 2018 Share Posted April 8, 2018 Just get a True Details ‘late ‘wheel set, the nose wheel is way better than the kit wheel. Heck, if you are really concerned with accuracy, then replace the god awful nose leg while you’re at it. Both Has and Academy think there is a sharp angle to the nose fork. cheers, Tony 1 Link to post Share on other sites
Uncle Uncool 984 Posted April 8, 2018 Author Share Posted April 8, 2018 Hola, Tony. I've (me has) already sorted the nose fork issue on the Hasegawa kit by ordering the one on the 1/48 Monogram Sabre Dog, as well as I've modified the wrong way in which Hasegawa devised the way the airbrakes deploy. The nose wheel type is the last item on my list of corrections. Got "they're" Cutting Edge slat set to go with this one too. I'm in the process of getting the armament well set by CMK. Really want 'em solid type of nose wheel to go with my build. Thinking it may not be that difficult to replicate the type on any given Sabre nose wheel. What do you think? 1 Link to post Share on other sites
Tony Edmundson 662 Posted April 8, 2018 Share Posted April 8, 2018 yup. other than fashion your own solid wheel, I have no idea where to get one. Good Luck. Tony Link to post Share on other sites
Uncle Uncool 984 Posted May 20, 2018 Author Share Posted May 20, 2018 Well, me's just ruined YET another wheel on the lathe trying to fashion a solid spoke! It's just the ribs on it are much too tiny to fashion outa scratch. Can you believe this bloke? Link to post Share on other sites
71chally 7,475 Posted May 20, 2018 Share Posted May 20, 2018 Love the camo on the Argie F-86s. Link to post Share on other sites
Sabrejet 4,983 Posted May 20, 2018 Share Posted May 20, 2018 I've done a recent trawl of F-86 nosewheel types and ended up with seven different versions. Link to post Share on other sites
