Noobarama Posted March 29, 2018 Share Posted March 29, 2018 (edited) Hey, so I have this problem with Revell colors. I've bought Revell enamel matt 37 for the surface to look, well, matt. But that isn't the case as you can see in the pictures. The red color appears glossy. Now, I've put a matt 69 besides it for comparison, so you can clearly see the difference. I don't know what is going on. Could this be a mistake by Revell or did I do something wrong? Model looks kinda ruined for me now, because everything should have matt finish (it's a Boba Fett Slave I by Revell by the way). Is there any way to safe it? I have some varnish... Also, the paint has been drying for more than 24h, that is important for you to know. So, what to do? Edited March 29, 2018 by Noobarama Link to comment Share on other sites More sharing options...
johnd Posted March 29, 2018 Share Posted March 29, 2018 Whenever that's happened to me it's been because I haven't stirred it enough. I wouldn't say the model was ruined, though. A coat of flat varnish will sort it out. John. Link to comment Share on other sites More sharing options...
Noobarama Posted March 29, 2018 Author Share Posted March 29, 2018 Yes, might also be because I haven't stirred it enough. Will try again and if that doesn't work, I will apply some varnish. Will post results here later on. Thanks! Link to comment Share on other sites More sharing options...
johnd Posted March 29, 2018 Share Posted March 29, 2018 Good luck. I'd wait for the current coat to dry before you do anything though. John. Link to comment Share on other sites More sharing options...
garynumanfan Posted September 28, 2020 Share Posted September 28, 2020 im getting same problem with humbrol acrylic matt paints..they are drying sort of satin not matt..its not just one pot..ive tried other pots and same is happening...ill have to get some matt varnish spray Link to comment Share on other sites More sharing options...
