Julien Posted March 28, 2018 Share Posted March 28, 2018 KrAZ-260B Tractor with 5P85TE TEL S-300PMU Hobbyboss 1:35 (HB85511) The KrAZ-260 was designed in the 1980s but not publicly unveiled until the 1985 Moscow parade where it was towing 152mm Nuclear capable artillery guns. The 260B is similar to the 255B it replaced but with a more angular bonnet to accommodate a turbo charged diesel engine. The 260B has only been produced for the military and not offered for civilian sale. The unit used for towing S-300 missiles is a 6x4 drive with a slightly longer chassis of 1.88m. The S-300PMU is a modernisation of the S-300P with the NATO reporting name of SA-20 Gargoyle. This has a detection range of upto 120KM with the 30N6 radar unit. Using a 5N64S radar range can be extended to 300km. The missile itself has a range of 150km with a height envelope of 10m to 27km. 4 missiles are carried on the TEL. The Kit The kit arrives in a fairly substantial box. There are 24 sprues of plastic, 2 sets of missile tubes, two sheets of PE, some flexible hose and a set of window masks. The missile tubes are one part hollow mouldings. Construction starts with a very detailed engine unit for the KrAZ. This unit has so many parts that the first 3 pages of the instructions deal only with its construction. Once the engine is done the gear box/transmission is made up the two can then be fitted into the chassis as it is made up. Again there are plenty of part for the chassis, the front bumper is also added along with the 5th wheel plate. The exhaust system is added along with the axles and transmission shafts. Suspension units and springs are also added. Air tanks and the battery box are also added. Last up for the chassis the mud guards are added and the wheels. Next up the cab is built up, follwed by the front wings/mud guards and finally the bonnet. This can then be attached to the chass. Last up for the chassis is attaching the spare wheel carrier which sits behind the cab. now its time to assemble the TEL. The base unit is first made up along with the unit used to raise it into the launch position. The top support unit is also made up. These can then be attached to the main beam box section which is also assembled at this time. Once this sub assembly is completed it can be put to one side. The main bed of the trailer is then assembled, onto this fit the suspension units, axles and wheels. Stabiliser plates are also fitted for use when the launcher is erected. The modeller can either have these extended or stowed. Once the main bed of the trailer is finished the reels for the control cables can be added to the front along with control boxes. The TEL parts can then be attached. Lastley the missile tubes are assembled and added to the final trailer. The tubes being one part moulding just need their end caps fitting. The trailer can then be attached to the cab. Decals Markings are provided for two camoflaged examples, and three in iverall green with different coloured missile canisters. No information is provided as to units etc. The Conclusion This is an will build up into an impressive looking kit. Hightly recommended. Review sample courtesy of 1 Link to comment Share on other sites More sharing options...
