Hardtarget
HT's B-25C Mitchell Mk.II FL176 'Grumpy'
I shall start off with the well known airshow circuit kite 'Grumpy' previously of the Fighter Collection.
Here's' a taster of her in action.
Edited by Hardtarget
Top vid. Gotta love the B-25
Which kit you going to use?
doh just seen the tag, having a blind moment!!
Edited by Skids
Engine noises like we don't hear very often... Beautiful plane, beautiful roar!
JR
Rightho made a start.
Boxshot
41328644802_148895c658_h.jpgDSC_0273 by stuart wellard, on Flickr
Assembly of the cockpit area, adding seats, IP, floor and wheel well.
27500587148_ec436f3ca1_h.jpgDSC_0274 by stuart wellard, on Flickr
40658248074_d64625541f_h.jpgDSC_0294 by stuart wellard, on Flickr
Whilst that was drying the fuselage halves got some attention. Bombay detail and doors along with the tracking cemented in place.
41328647982_6fba70327a_h.jpgDSC_0295 by stuart wellard, on Flickr
Thanks Tony, typical as i had a set made for me a wfew years back just waiting for a better C/D model to be released. Was hoping Hasegawa followed up with their G,H,J versions but welcoming the airfix release.  Might have to grab that sheet for the other schemes!
Sheets arrived today, thank for the heads up on this Tony. Ill use another kite from this sheet for my Hasegawa J/Mk.III version.
Shame they don’t do those deals in 1/48 as it has the one on I wanted!!
Some progress on this gal.
Cockpit assembled and painted.
27437561687_2b9a8b5da2_h.jpgDSC_0002 by stuart wellard, on Flickr
Pit inserted onto the port fuselage, no issues with fit at all.
42306178651_c9f5852572_h.jpgDSC_0003 by stuart wellard, on Flickr
Matching up the fuselage halves needed only a little persuasion. the seams being soft will need some filling and sanding.
41404902755_02a958fb2c_h.jpgDSC_0004 by stuart wellard, on Flickr
Tail sections and wings cemented to the spars.  Need a little extra liquid cement at the joints to ensure that they are smooth rather than at right angles. Also a little bit of either filling or liquid glue and compression at the tail joint.
28433455918_729fd0b1d8_h.jpgDSC_0005 by stuart wellard, on Flickr
Engines painted on the sprue tut tut.
42306179871_dc88bb500a_h.jpgDSC_0006 by stuart wellard, on Flickr
Cowls in place and setting out the engine nacelles with the u/c as per instructions.
28433457808_14eeee7e5c_h.jpgDSC_0007 by stuart wellard, on Flickr
Once set in place a test fitting for weight is required. I added a little bit more to the nacells but adding too much weight and the  nose u/c will not take the strain.  Im sure SAC will release if not already a weight and u/c set. Ill use this next time for this tail sitter.
40499952030_b6b90cdccc_h.jpgDSC_0008 by stuart wellard, on Flickr
Apparently I've missed this build so far. Looking good.
Back in August, 2015, Grumpy was at the Edmonton Airshow. I got to get inside for some pictures.
Chris
Hello @Hardtarget ... I found this while looking for B-17 pictures prepping for that group build. Dont know if you have this but I thought id post this. UPGVraB.jpg
A picture of the real “Grumpy” with crew.
Dennis
Edited by Corsairfoxfouruncle
She has now been primed in stylnrez ready for her top coat which will be RAF Green as apposed to OD being a RAF kits and very likely to have been re-painted. Underside will be MSG. Paints will be Vallejo MA but its too hot in office to airbrush today.
43128404551_3f0ad051a0_h.jpgDSC_0074 by stuart wellard, on Flickr
