corsaircorp
Ballroom brawlers ! Need more blue in my cabinet ! F6F
Hello Dears,
What another double WiP ??
I've been asked by a friend about Hellcats, So I start a study !
We have this one
And this one
Here are some sprues
That old Monogram kits, as toyish as they are, were finally quite good, look !
dimensions and shape were right seemingly !
A little work here and there and she will look good !
My similar Avenger Tarpon project is in stall for that while
will have silicon and resin soon,
But here I already have it
So I already have a brand new smile for the monogram one
The monogram will be transformed as a F6F-5P of the VF 61 ( I can't change)
The Eduard will be made as per the box art, A cat mouth instead of a shark one !
Now Gents have a look at this, these ladies are really good !! I look a good tenth time !
Have a very good modelling time Aaaaand Rock'n Roll
Sincerely.
Corsaircorp
Hi
They are great and the Hellcats too. Good luck with your builds. I did the Monogram 1/48 Harvard and it was a cracking model I did it as the chequered nosed New Zealand AFAIK display scheme what a cracking scheme.
All the best
Chris
Interesting video cousin 👍
I will build any and all monogram kits. Im a member of the Monogram Mafia.
Edited by Corsairfoxfouruncle
Me too, I save the F4U-4 as a collector, but I have a lot of that old monogram kits !
thanks Cousin, Glad that you have enjoyed the bagpipers !
Sincerely.
CC
2 hours ago, DMC said:
Great! Crack on CC, following this.
And, if you haven’t seen it already, this might be of interest.
http://www.geocities.jp/yoyuso/f6f/f6fe-1.html#bottom
Dennis
Thanks Dennis,
I did'nt know this, to me the eduard cowling was almost right :(:(
Soooo, What to do now, Remake a cowling, I still have 2 or 3 Monogram kits and an Hasegawa one..
That can be Worth the job !
An Hellcat RFIed in 2018 ?? Most unlikely :rofl::drink:
Thank again, I'm going to study it !
Let's paint now SWMBO is gone for the week end
Fumes fumes fumes
Sncerely !
CC
Hello Dears, I'm cleaning up my attic !
And found this back, do you remember the time where these books were the best documentation available ???
I speak to the grey haired like me or ex gray haired…. :cheers:
WP_20180904_20_43_47_Pro
But I did'nt find pics of my projected modification ...
No problems I surely have it in another box….
Have a great time !! Modelling or anything else !!
Thank for your support !!
Sincerely.
CC
Looking forward to the build. I did the Monogram kit as an F6F-5K Drone. The fit of the outer wing panels to the inner wing panels wasn't the best to say the least.  If you aren't going to detail the landing gear bays it might make things simpler if you install the landing gear legs so they're movable, leave them folded up in the wing while you build the rest of the plane and then when you're ready, extend them and glue them solid. I used tube glue for the pivot joint and liquid glue for the gear leg rotation joint
Ah a Hellcat! They always look best to me in the three colour scheme - Dark Slate Grey, Extra Dark Sea Grey & Sky...  😁
I recently completed the Eduard kit (my third), it really is a great model, make sure you have the right cowling for your chosen subject (don't ask me how I know) and look to the fitting of the flaps which I'm not sure I got right on mine (fill and hide the upper wing join or show it as a movable panel).
Enjoy building this one.  Do you mind if I tag along?
Hello Grey !
Welcome aboard, The third Hellcat is coming..
And it will be the one flown by Stan Orr during Operation Tungsten....
Did it remind somethng to you ?? Let's say that your build has been a great source of inspiration for me.
So there will be a Sky, DSG and EDSG one in this thread, Have a seat, a beer, a cigar or something !
I just will try to do half as good as your, if you don't mind ?
Sincerely.
CC
Hi CC,
Good luck with JV125 E*o  I am sure you will do a much better job than I did.
Where are you going to get your Red O with the white outline?  I made my own in the end as I couldn't source one from anywhere else.
If you are interested, this is how I did it.  If you have a source fast forward to the bottom:-
 I printed my own decals for that using MSWord to make the decal and a Canon Inkjet to print it.
The word file consisted of the "O" which was Uppercase "O" in Calibri 32pt font.  I used Text Effects in the Font Format to give a 1pt white border (2pt might be better) this gave me an "O" of equal height to the F of the other decals in the set.  For the Red colour I went into text colours, More Colours, Custom, Red = 168, Green=24, Blue=24.  This should give you ID Red which should match the colour of the E.
I needed to print on white decal paper to get the white outline because my printer does not print white.  If yours is the same you need to differentiate the edge of the outline against the camouflage colour below.  I checked and the O is on a solid colour on both sides (just).  I copied the O a few times on separate lines so I could have some on Extra Dark Sea Grey and some on Dark Slate Grey.  For both lines I drew a rectangular shape in word.  Sent it to the back and colour filled them.  The first I filled with the Extra Dark Sea Grey Colour.  In the Fill, More Colours, Custom in the Red=56, Green=67, Blue=86. and Dark Slate Grey Red=83, Green=97, Blue=71.
You should end up with a EDSG Rectangle with your Red O with a white outline and a DSG Rectangle with a Red O with a white outline.  Print, Seal with spray laqueur and you have decals.
When you apply the decal, cut away as much of the EDSG or DSG as you can but hopefully it should match quite well.
Warning - don't convert to a PDF before printing as the colours do not come through the process the same.  Don,t ask me how I know this...
I'll be looking in after work to see how far you have got.  You will finish yours before I finish mine I'm sure
Good luck
Hello Dears,
Birthday gift has arrived !!
WP_20180927_09_28_07_Pro
Ahem, As usual with me… There are now 3 Hellcats on the go :cheers:
I have these bits too !
WP_20180927_09_28_58_Pro
Looking that way…. For the Ministry of domestic affairs… I've been quite reasonable <_<<_< Is'nt it ??
Well, last evening work day, saturday, SWMBO invited me in a restaurant and hotel in germany :yahoo:
Sunday back home and modelling !! Good way to start my own 56th year...
Have a great modelling time and take care !
Sincerely.
CC
Hellcat City with the promise of occasional Thunderflash.  What’s not to like?
I'll take my seat at the front here if you don't mind..
Welcome aboard Grey !
2 Navy experts at the bar, lookin' at me ! That's a great honor Dears !
Welcome aboard Crisp !
One more evening work day and tomorrow, I put my mits on these !
Sad to see that the Sea King are now retired from the service. I just hope that they will save one in flyable conditions at Yeovilton !
So, the plan is to turn the Monogram into an F6F-5P of the Jolly Rogers Sqdn
The Hellcat Mk I as JV125 for my Tungsten serie Plus Stan Orr Warbirds !
The F6F-3 with a cat mouth, not really original but I like it !
Mmmmhhhh An Engine resin for the Monogram first ! The Eduard engine look quite good
I hope that you will enjoy the thread !
Have a beer and tomorrow, the battle begin !
Thank for watching !
Sincerely.
CC
Caracal has eduted the decals for the "Polka dots" Sqdn.so, I cough and buy it!
I have 2 RF-84 in the stash, this Sqdn has been involved in both the
korean conflict with F-6 Mustang (I'm still searching for the F-6 decals), RF-80 and RF-86, Then they go to Viet Nam with RF-101 Voodoo
I like to have the Aircrafts of a Sqdn and follow it through the years !
Did I forget to mention that all these birds are waiting in my attic ??😜
Thank for following !
Sincerely.
CC
Hello Dears ,
What a luck, as I was makin' my mind to Oramask for a red E bordered in white ….
WP_20180928_21_56_12_Pro
Thanks Eduard ! No more worries !! And the depicted aircraft is serialled JV105
The serial is almost right, no more worries for the engine cowling, since these 2 (JV105 and JV125) are from the same batch !
Funnily enough, these are not Hellcat but Gannet...
They were called Hellcat going from the third batch !
WP_20180928_22_35_46_Pro
Some documentation...
And let's go with the interiors !
WP_20180928_23_07_40_Pro
The seats will be replaced by resin ones ! I love the Monogram representation of the seat !:rofl2:
Just behind the back of Da poor blobby pilot "
Ok, I now go for Germany, See you tomorrow !!
Sincerely.
CC
Hi CC that's what I did was to take the E but how are you going to make the o
I think that I will use the Oramask or a stuff of this kind
There is also Frisket, Thin mask for artist.
Sincerely.
CC
Sincerely.
CC
I printed up decals for mine, I'm in the Cave later, I'll take a picture and see what you think..
Very sad CC I agree, but the Sea King lives on for now, operating out of Portland with HeliOperations https://helioperations.co/ I am fortunate enough to live down that way and regularly see the Sea King flying.
Nice to see a Hellcat build CC, looking forward to it!
Terry
The came from the kit, the o I printed on white decal paper with a DSG background..
Hope this helps..
Hello Grey,
It look great ! sure it help ! last evening work day, I'll be back at the bench tomorrow.
I'll cast some resin parts for the Hellcat, Corsairs and Seafire...
Sincerely.
CC who must finish a Corsair this year 😜
