greggles.w Posted April 23, 2018 Share Posted April 23, 2018 Inspirational. I would feel heroic setting a goal such as this at 1/48! Much respect for your craftsmanship, and lovely to see these skills directed to such a delightful subject. 1 Link to comment Share on other sites More sharing options...
AdrianMF Posted April 23, 2018 Share Posted April 23, 2018 Lovely work. It is a wonderfully delicate machine. At this point in a build I often write a list - it's a trade-off between the shock you get when you realise how long it is and the pleasure you get from crossing items off it. (let's not talk about the bit where you add a whole load more items because you forgot about them when you made the list...) Regards, Adrian 3 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted April 23, 2018 Author Share Posted April 23, 2018 (edited) 3 hours ago, AdrianMF said: At this point in a build I often write a list - it's a trade-off between the shock you get when you realise how long it is and the pleasure you get from crossing items off it. (let's not talk about the bit where you add a whole load more items because you forgot about them when you made the list...) Regards, Adrian Hi Adrian I too write "the list" (a mnemonic device) at the point when the model is quite advanced, because I often fail to add the last little things (Pitot, Venturi, antennas, small struts, props, exhausts, lights, etc) I made and set aside until I take 50 photos of the "finished" model, only to realize the missing bits when I start to post the images, and have to go back to the building board, and then re-shoot. I found more efficient to build more than one model at the same time, so when I have to wait for something to dry I can keep working, and that sometimes produces glitches too (parts for one model end up in the other model parts bin). I thoroughly check references before starting the build, but unavoidably will discover more things that need attention as the construction proceeds, and I make notes of those too (for example that the specific airframe I have chosen has different landing lights or probes positions, etc). Needless to say, I sometimes misplace the list and forget about it too, until.... Cheers Edited April 23, 2018 by Moa to correct typo 1 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted April 24, 2018 Author Share Posted April 24, 2018 And primer is applied: 5 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted April 27, 2018 Author Share Posted April 27, 2018 The oil reservoir was mounted on the fuselage side on two wood rails: The conduit on the fuselage top present in some airframes is added. This makes my choice clear: it's going to be Belgian OO-ENC, the plane Poirot once flew in 😉 The wind-driven generator on the wing is added: Landing gear added: 6 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted April 27, 2018 Author Share Posted April 27, 2018 (edited) A beacon seen in photos on the wing center panel LE is fabricated: The oil reservoir is glued on: The canopy railings are added: It's funny that the task of adding details never seems to finish. Hopefully after a few more touch-ups the model will be ready for the first base coat of paint (gloss black). The scheme of this Belgium-registered machine was the one used in G-ACDD, that is red bottom half of fuselage and fin flash, blue upper half and regs, silver on part of the nose, wings and horizontal tail. A white thin line divided the colors. White double outline regs were painted on the fuselage sides. The decals have been already commissioned. Some careful masking will be in order... Edited April 27, 2018 by Moa to correct typo 16 Link to comment Share on other sites More sharing options...
k5054nz Posted April 28, 2018 Share Posted April 28, 2018 Great choice for paint, Moa. I look forward to it. Brilliant work. 1 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted April 28, 2018 Author Share Posted April 28, 2018 Black base on: 14 Link to comment Share on other sites More sharing options...
StephenCJ Posted April 28, 2018 Share Posted April 28, 2018 Moa this is coming along wonderfully, you are a fantastic modeller. Where do you and others get your reference material from? I only know about google images. I also miss Aeroclub, I used to buy WWI propellers, engines, wheels and machine guns in the 80's. Wonderful bits and bobs. I have Valom's Southern Cross and Dennko's Northrop Gamma I would like to start. Once again your builds are great. Stephen Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted April 28, 2018 Author Share Posted April 28, 2018 50 minutes ago, StephenCJ said: Where do you and others get your reference material from? I only know about google images. Hi Stephen I find most of what I need on the Net, but you have to look wide and deep, not a two minute, one phrase search. The more you search, the more you learn about how to search, same as for building. Occasionally fellow modelers will help, but before even dare to ask and bother people, I will exhaust all the sources I can think of. I also have a very small library of aviation books, but I hardly ever find very useful stuff there, it is more for inspiration. Google images is fine, but not all info comes from the images. I always do in parallel a "normal" search, and visit and fully explore what seems to be the better links proposed by the search. There is no magic, I am afraid, but good ole butt-hours on the chair. Cheers 2 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted May 2, 2018 Author Share Posted May 2, 2018 The aluminium color is applied all over. Then masking will ensue to preserve the areas that will remain that color: Pants, doors and wheels are painted too: 13 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted May 2, 2018 Author Share Posted May 2, 2018 At this point I decided to make a little detour and experiment a bit on props, working with aluminium sheet instead of re-shaping plastic spares. I have done this before while working on the Rohrbach Roland to render the Reed pressed metal props, but the machine I finally represented didn't have those. So I made then real laminated wood ones: In this case, there is a spinner involved: I am not sure I will use these, but it's fun to try and do things sometimes. They may be useful down the lane. 15 Link to comment Share on other sites More sharing options...
Courageous Posted May 3, 2018 Share Posted May 3, 2018 Very impressive . Is their a special technique for making these ali prop blades? Stuart 1 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted May 3, 2018 Author Share Posted May 3, 2018 6 hours ago, Courageous said: Is their a special technique for making these ali prop blades? Hi Stuart Not really, other than cut the aluminium sheet in strips, and then trimming and sanding to contour the blades, polishing them a bit, and giving the blades a twist to resemble the proper change in the pitch (less toward the tips). The spinners as you see are made from leftover sprue rods, sanding them by hand or chucking them on a drill and carefully sanding as they spin; then drilling the holes for the blades before removing from the rod to facilitate handling; then the spinner is removed by rolling a blade on the rod, and then drilled for the axle. Practice is all is needed. Making some amount will give you the knack, and then you select the ones that pair better. After decades of making hundreds of models, the best technique and advice I have is: make a bunch, over and over, until you get it 😉 No instruction or methodical approach will ever bypass or substitute practice. In our field or everywhere else. 3 1 Link to comment Share on other sites More sharing options...
Martian Posted May 3, 2018 Share Posted May 3, 2018 I particularly like the laminated props. Martian 1 Link to comment Share on other sites More sharing options...
Tomoshenko Posted May 3, 2018 Share Posted May 3, 2018 Stunning stuff. Really like those aluminium props. 1 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted May 3, 2018 Author Share Posted May 3, 2018 And here is an even smaller one that will finally go on the model to replace the "wood" one provided with the kit. Tiny Fairey logo light blue stripes will eventually be added to the blades, as per images of the real plane. It has no shaft, but a hole, so I can glue it eventually to the free-wheeling boss that protrudes from inside the nose: 8 Link to comment Share on other sites More sharing options...
lars_opland Posted May 4, 2018 Share Posted May 4, 2018 On 4/28/2018 at 2:44 PM, StephenCJ said: Moa this is coming along wonderfully, you are a fantastic modeller. Where do you and others get your reference material from? I only know about google images. I also miss Aeroclub, I used to buy WWI propellers, engines, wheels and machine guns in the 80's. Wonderful bits and bobs. I have Valom's Southern Cross and Dennko's Northrop Gamma I would like to start. Once again your builds are great. Stephen Hi Stephen, In this genre, internet image searches will often find only the tip of the iceberg. Because many pre-WWII civil types are less well known, their photos posted hither & yon are often mis-captioned & will only appear while you are looking for something else entirely, or searching for images under the name of a pilot who flew the thing or a company that owned one. Even on museum web sites, I often find gems captioned simply as "an airplane", "a biplane", "a floatplane (or "float plane")", "plane on skis", etc. Happy hunting! "Moa", old friend, I am loving this! Cheers, -Lars 1 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted May 7, 2018 Author Share Posted May 7, 2018 Aluminium color is masked, red is applied, which in turn will be masked to apply the blue: 9 Link to comment Share on other sites More sharing options...
Azgaron Posted May 8, 2018 Share Posted May 8, 2018 Excellent work! Looking good! Håkan 1 Link to comment Share on other sites More sharing options...
Terry1954 Posted May 8, 2018 Share Posted May 8, 2018 (edited) The great work continues Moa. Really enjoying seeing your skills at work! Terry Edited May 8, 2018 by Terry1954 1 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted May 8, 2018 Author Share Posted May 8, 2018 With the red areas masked, the blue paint goes on: 9 Link to comment Share on other sites More sharing options...
Azgaron Posted May 8, 2018 Share Posted May 8, 2018 Nice paint job! Håkan 1 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted May 8, 2018 Author Share Posted May 8, 2018 Peeling the masks off reveals the color scheme: Needless to say, and in spite of appearances, completion is not really near. A line separating the colors needs to be added, decals applied, and then very complex upper wing cabane structure and wing struts need to be added, plus rigging, transparencies, prop, wheels and pants, and many small details. Sigh..... 13 Link to comment Share on other sites More sharing options...
Courageous Posted May 9, 2018 Share Posted May 9, 2018 Looking very pretty. 1 Link to comment Share on other sites More sharing options...
