CedB Posted March 27, 2018 Author Share Posted March 27, 2018 Thanks CC - I can understand the confusion over the 'Sabs' - BM would have me think it's 'Stabilising Automatic Bomb Sight' but I knew it wasn't that... Thanks Bill and James for pointing (ahem) out that it's the bumps on the sides. I knew I'd boobed Thanks Benedikt - relaxed and cool, that's the ticket! Steve you need a sihrsc file - just stroke it over lumps and they're gone. Saves ages on sanding. Recommended! Ian you're right - it should be added to the abbreviations Stuart good to see you're joining the sihrsc club - welcome! Thanks Keith (the Goldfish). Thanks Keith. Thanks Keith Canopy masked and glued on just before bed... night all! 4 5 Link to comment Share on other sites More sharing options...
corsaircorp Posted March 27, 2018 Share Posted March 27, 2018 ahem !! Following the advice of @71chally, I went back home... Say to Mem sahib that I'll go on bm a bit... Re-check the name of the actress and Google it .... BUT I did'nt notice that a very suspicious Mrs CC came back behind me .... Ooook I tried to show her the significance of the Sabs... She half believed me, I think ... Well perhaps... Will be Spitfire game tomorrow Sincerely. will not start a Pin uped A/C next week... CC 8 Link to comment Share on other sites More sharing options...
corsaircorp Posted March 27, 2018 Share Posted March 27, 2018 Here's a proof ! No, Idid'nt try to explain that I'm interested in a projection.... Device sincerely. CC 2 9 Link to comment Share on other sites More sharing options...
keefr22 Posted March 28, 2018 Share Posted March 28, 2018 12 hours ago, CedB said: Apparently we're now on 'DST' so I think it's gone German on me, even though it's set to 'Eng'. Isn't DST 'Daylight Saving Time', Ced? The reason this daft nonsense of mucking about changing the clocks was brought in in the first place? Keith 1 1 Link to comment Share on other sites More sharing options...
71chally Posted March 28, 2018 Share Posted March 28, 2018 8 hours ago, corsaircorp said: Following the advice of @71chally, I went back home... will not start a Pin uped A/C next week... CC I forgot to issue the warning, that if you are to Google Sabrina add the words '1950s' or 'Norma Ann Sykes' otherwise you could find images of the other rather prodigious Sabrina (Noma Salerno) so beloved of us late 1980s types! Probably more Starfighter than Hunter! 2 3 Link to comment Share on other sites More sharing options...
CedB Posted March 28, 2018 Author Share Posted March 28, 2018 Thanks CC Can I suggest you never sit with your back to the door? I would say that this is 'an old Spy trick' but best not draw the attention of 'the Services' at the moment! Thanks Keith Ah, yes! Could be 'Daylight Saving Time' I suppose... it's still an hour fast though, dammit. Thanks James - that picture certainly got a 'like' from me! Still no clue what the bumps are on the aircraft... I had a quick search for 'Hunter Sabs' and, after filtering out all the Hunt Saboteur links, this diagram shows that they're 'Ammunition Link Collector Boxes'. Still no clue... collects the links between the rounds I guess. Are they more valuable than the shell casings? Bet that caused a heck of a rattle when the guns were fired. 3 2 Link to comment Share on other sites More sharing options...
rs2man Posted March 28, 2018 Share Posted March 28, 2018 As you suspected , the sabrinas collect the steel links which hold the cartridge cases together to form a belt . The reason for collecting them but not the cases is that the cases were heavy enough to fall clear of the aircraft , but the links weren't and tended to damage the underside of the aircraft 2 1 Link to comment Share on other sites More sharing options...
71chally Posted March 28, 2018 Share Posted March 28, 2018 The sabrinas were indeed link collector boxes. Initially the ejected rounds links would simply enter the airflow via chutes but it was later found that they were damaging the underside of the aircraft during cannon firing. The fairings literally collected the expended links. 2 Link to comment Share on other sites More sharing options...
corsaircorp Posted March 28, 2018 Share Posted March 28, 2018 1 hour ago, 71chally said: The sabrinas were indeed link collector boxes. Initially the ejected rounds links would simply enter the airflow via chutes but it was later found that they were damaging the underside of the aircraft during cannon firing. The fairings literally collected the expended links. Are these Sabrina présents on all the Hunter, I have a F-4 with the undented wing But I'm not sure that the previous version did get thaaaat Bulges ?? Thanks James 2 Link to comment Share on other sites More sharing options...
perdu Posted March 28, 2018 Share Posted March 28, 2018 F4 might have been where they learnt to catch the links, most aircraft production programmes allowed learnt development I can't remember what I heard about the links being reused, I know I have reloaded links on 7.62mm Gimpy belts but that was most likely field operational requirements We had them in already linked usually from the armoury, I can 'just' imagine Ray the armourer sitting for along lonely nights linking belts for us But I have an awfully good imagination On the whole the links are worth less than the brass, always had to recover brass from the range on Sennybridge Never Gimpy links 😀 1 2 Link to comment Share on other sites More sharing options...
giemme Posted March 28, 2018 Share Posted March 28, 2018 2 hours ago, 71chally said: the other rather prodigious Sabrina (Noma Salerno) so beloved of us late 1980s types! Now I know where the 71 in your nickname comes from (I guess - mine would be 70) Ciao 3 Link to comment Share on other sites More sharing options...
71chally Posted March 28, 2018 Share Posted March 28, 2018 (edited) 43 minutes ago, corsaircorp said: Are these Sabrina présents on all the Hunter, I have a F-4 with the undented wing But I'm not sure that the previous version did get thaaaat Bulges ?? Thanks James Perdu has it in a nutshell really, over the early years of service successive marks of Hunters encountered various problems and so remedial modifications were issued, so the addition of the link collecter bulges were not mark specific. You will see pictures of F.4s and F.5s for example both with and without the bulges. I think that generally speaking all Mk.6s and 9s had them, due to being later aircraft. Some nice Belgian Hunter F.4s without http://www.belgian-wings.be/Webpages/Navigator/Photos/MilltaryPics/post_ww2/Hawker Hunter F.4/Hawker Hunter F.4 ID005.html ...and one with http://www.belgian-wings.be/Webpages/Navigator/Photos/MilltaryPics/post_ww2/Hawker Hunter F.4/Hawker Hunter F4 Frontpage.htm Edited March 28, 2018 by 71chally 2 Link to comment Share on other sites More sharing options...
corsaircorp Posted March 28, 2018 Share Posted March 28, 2018 1 minute ago, 71chally said: Perdu has it a nutshell really, over the early years of service successive marks of Hunters encountered various problems and so remdial modifications were issued, so I don't think the link collecter bulges were mark specific. You will see pictures of F.4s and F.5s for example both with and without the bulges. I think that generally speaking all Mk.6s and 9s had them, due to being later aircraft. Some nice Belgian Hunter F.4s without http://www.belgian-wings.be/Webpages/Navigator/Photos/MilltaryPics/post_ww2/Hawker Hunter F.4/Hawker Hunter F.4 ID005.html ...and one with http://www.belgian-wings.be/Webpages/Navigator/Photos/MilltaryPics/post_ww2/Hawker Hunter F.4/Hawker Hunter F4 Frontpage.htm Great thanks James, Mine will be a 112nd Sqdn one for my Sharmouthed british aircrafts, I already have a decal sheet for her. Her... In the 80' my favourites female singer were both 2 Brtitsh army productions First and still a soft point for her is And the other one is .... Her Sorry for the drift Ced ! Sincerely. CC 6 Link to comment Share on other sites More sharing options...
bbudde Posted March 28, 2018 Share Posted March 28, 2018 8 minutes ago, corsaircorp said: First and still a soft point for her is I like Kate Bush very much since her Wuthering heights album (Her best! Imho) Ok, 80'drift: She also belongs to that too as Sandra, Paula Abdul, Kim Wilde, Janet Jackson.........: 4 Link to comment Share on other sites More sharing options...
Biggles87 Posted March 28, 2018 Share Posted March 28, 2018 If I remember correctly, the ' Sabrinas ' were introduced with the Mk6 and retro fitted on some '4s and '5s. On some later Hunters you could see what appeared to be cannon barrels protruding from the nose but where blast tubes with some sort of gizmo on the ends which broke up any chunks of cordite which came out with the shells and could be ingested into the intakes. This was told to me at an ATC camp at Chivenor when it was a Hunter OCU in the '60s John PS the Hunter in the head on photo ( previous page ) has the cannon extensions and also additions to the Sabrinas which probably means it's Swiss. 2 Link to comment Share on other sites More sharing options...
CedB Posted March 28, 2018 Author Share Posted March 28, 2018 Thanks rs2man, James, Bill and John for the very useful information - great stuff Thanks CC and Benedikt for the pictures of semi-clad young ladies - great Scot! I managed to squeeze a bit more in before the break. Doors scratched: ... and while I was filling those I filled the aerial hole behind the canopy and went down the wing roots: ... and put a spot on the rudder. Before: After (but before sanding): More later (perhaps much later!) 14 1 Link to comment Share on other sites More sharing options...
perdu Posted March 28, 2018 Share Posted March 28, 2018 Looks very good 👌 1 Link to comment Share on other sites More sharing options...
Courageous Posted March 28, 2018 Share Posted March 28, 2018 Looking good Ced, not to many curve balls for you...making good progress. 1 Link to comment Share on other sites More sharing options...
giemme Posted March 28, 2018 Share Posted March 28, 2018 4 hours ago, perdu said: Looks very good 👌 Agreed! Ciao 1 Link to comment Share on other sites More sharing options...
Brandy Posted March 28, 2018 Share Posted March 28, 2018 Nicely adjusted curves there Ced! Ian 1 Link to comment Share on other sites More sharing options...
Pete in Lincs Posted March 28, 2018 Share Posted March 28, 2018 On 3/27/2018 at 10:13 AM, CedB said: buy some clamps, buy some clamps... there's nothing like them IMHO for a 'gentle hold' Why aren't there small, locking strap wrenches for modellers? PSP, BTW, looks like the stuff they used in the desert for getting their vehicles out when they sank. The pieces all lock together. (And I remember it as pierced too). 2 Link to comment Share on other sites More sharing options...
71chally Posted March 28, 2018 Share Posted March 28, 2018 It is Pierced (Pierced Steel planking) which is Marston Mat, runways that were constructed from it were designated as a Marston runway. Good recovery on that rudder Ced, dare I say it you have steered the build back on course! 2 1 2 Link to comment Share on other sites More sharing options...
bbudde Posted March 28, 2018 Share Posted March 28, 2018 Looking very nice so far. Well fixed. Away tommorrow for an easter break so I wish you and all the others here a happy easter. Cheers 1 2 Link to comment Share on other sites More sharing options...
The Spadgent Posted March 28, 2018 Share Posted March 28, 2018 On 27/03/2018 at 10:29 PM, limeypilot said: Yes! Recommended by no less than Bill@perdu, and Ced. Oh, and me! Ian Recommend by me too. Great bit o’ kit. Brilliant scratch work and general modelling dear boy. Top notch stuff. Johnny 1 Link to comment Share on other sites More sharing options...
perdu Posted March 28, 2018 Share Posted March 28, 2018 There's going to be queues at the ironmongers any day now Good fix on the rudder Ced, very nicely done sirrah! 1 1 Link to comment Share on other sites More sharing options...
