AdrianMF
A sacrifice to the Plastic Modelling Gods - Airfrog Beaufort- FINISHED
Lovely job! Thanks for the tips on the black, I may try an airbrushed version of that. Looking forward to seeing her in RFI.
Ian
11 hours ago, AdrianMF said:
And for Massimo here’s a shot of where we are now. Note the absence of a serial number and dirt, which is all I have left to do on top:
27-B39179-173-C-4-F9-D-9-C0-D-E449-CD612
Thanks Adrian!!!
SHE'S A REAL BEAUTY!!!!!
I like the new codes , but most of all I love the all thing!!!
You must be proud of yourself, you did a fantastic work!!!!
Chapeau!!!
Edited by Massimo
Thanks for all the kind comments. I will try not to drop the ball in the last few yards...
I’m getting less and less happy with my five spoke hubs, moulded from the old Airfix Blenheim ones. I made an experimental hub from slices of tube and strip, but it’s a bit too small:
F88-DA908-E755-4-DDB-A515-80242-E49-B5-F
So I made another one using a slice of drop tank. This was looking very promising until it pinged off the tweezers when I was painting it. Time for bed!
Regards,
Adrian
Lovely looking Beau Adrian, a real beauty :)
You're scratching HUBS now! Crikey…
D’you know what? Life is too short, just ordered some Aires five spoke Beaufighter wheels :whistle:
Regards,
Adrian
Looking good! I agree make life easy and order some wheels.
Maybe I should get my Encore version out for the Frog Group Build?
Neil
Neil
Be my guest! In case you haven’t noticed, the kit does have a few... errr.... issues :)
Regards,
Adrian
Tiny update.
The little yellow “R” on the nose was a Woodland Scenics rub down letter carefully painted in with yellow:
EBCE5299-C5-B9-4-B65-8-D35-BCFE87-F925-A
Serial was Laser printed on to clear laser decal film:
EFA18405-BBBA-4-B95-B48-B-F7-F68-DB4275-
Thanks for looking,
Adrian
Sounds very interesting to me. I've got to make a number of 6-spoke hubs for my Avon Sabres. :hmmm:
Stuart
ooh
progress and very nice progress
Stuart, sorry if I'm teaching granny how to suck eggs, but:
I think the first course of action is to see if you have a wheel that has the right hub and take a mould from that. You can either go the whole silicone/resin hog or if you just want the spokes you can use Oyumaru moulding compound (5-ish quid on Ebay), which softens in hot water and takes an impression when you squish it over the part and let it cool. Then fill the impression with Milliput. That's how I got my Blenheim wheel hubs - they look rough but in all fairness that comes from the original plastic part, which was not great!
To make the wheel hubs you need a hub circle and a rim circle. I've been using slices of tube or drop tank (which is NOT guaranteed to be nicely circular!). Then make some plastic rectangular strip that is the right width for the spokes and the right depth to reach from the outside of the hub circle to the inside of the rim circle. Then cut off the right number of slices of that strip and arrange them between the two discs - a tight fit is good here and I was lucky with the first one. After you are happy with the spacing, flood with liquid poly, leave to dry, and then trim and sand to wafery goodness. Make one and take copies, as above.
Then type "wheels, resin, Avon Sabre" into google... :)
Regards,
Adrian
You're not. As far as I can tell and chatting with others, Sabre spoked wheels are available in 1/48 but not 1/72 so DIY will have to be the way.
Thanks Adrian for your process.
Stuart
Woohoo Saturday!
I stippled another off-black coat over the undersides and I’m pretty pleased with the result:
C8-F1801-C-8012-4509-9-B12-DD1-AAD443450
The streaking is much toned down but it still looks suitably distressed.
And Project Hub is stubbornly refusing  to go gently into that good night:
6-D14368-D-9-CFC-4-BB4-80-A2-948-ADD165-
Oyumaru time in a minute...
Thanks for looking,
Adrian
Adrian,
What and epic effort and a great result...well done!
All the Best!
Don
Project Hub is not happy about the dying of the light:
69-DC698-B-4-F3-E-4-A24-BE8-F-39-D914-E8
I had a bit of an experiment but I moved the mounds before it was all set so these haven’t worked.
In another part of the forest, the torpedo is done, apart from the detonator whiskers on the nose:
FE17-DB23-622-E-4-E3-E-9-D54-9-A5-B0-B84
After watching the excellent video posted by Ced, it was tempting to start adding all the hatches and vanes of the real thing, but I resisted!
I found a colour photo that supports the proposition that the aerial tail is unpainted plywood. It looks like it is towing a piece of 1960s furniture!
Thanks for looking,
Adrian
Well, I’ll just stick the next bit on ... - whaaa??
C1-B8-D956-668-F-4-B3-F-B7-F6-AC60-BF59-
... and suddenly it was done:
575-E4-A05-31-C6-4850-8-F27-22-C6-AB1-A1
EB895-A87-8819-4-E4-C-BBF3-2-BFE27967-F9
1-B603-E89-3-E86-4023-8081-F5-F0-E88-A71
Torpedo has its detonator whiskers and the undercarriage has a fender for keeping the doors off (top tip: don’t add this right at the end; ask me how I know):
B3-C681-DC-97-D2-47-D2-9-C87-D023-CA73-C
Amazingly the cockpit is still visible:
46-CC1554-68-D5-4-ED5-8-F8-B-8-B85640-A3
And, although some Beauforts were certainly well used, I went all restrained and classy with the bare metal chipping:
E97-A2239-1-E1-F-43-C2-A920-6-CAF425-E83
There’s always a sense of anticlimax for me when I finish a build , so, with apologies to @Pete in Lincs:
Thanks for all the support along the way. Proper pictures tomorrow!
Thanks for looking,
Adrian
Looks like a great result
Edited by Mike
Removing extraneous photo quote - Please Reply to the thred without quoting if you're the next poster.
Great looking Beaufort.
I enjoyed following the build, and learnt a few tips on the way! Looking forward to seeing more pics and then re-reading all the posts again!
Any idea what the next project will be?
Matt
Well worth the wait.
It looks like it came out of the box that shape.
And, you are excused.
Great finish Adrian - she's a beauty.
Really enjoyed following this build and learnt a lot - thanks for sharing :)
Amazing Adrian, you have built a real beauty and should feel suitably proud of your achievements.
Great work.
All the best
Chris
Disgusting...cutting mat :rofl:.
And as for the build...fantastic and torp looks great too. :yes:
Stuart
Marvellous stuff Adrian, tremendous result after a really entertaining and informative build thread!
Keith
