Julien
44M TAS Rohamloveg - 1/35 HobbyBoss via Creative
44M TAS Rohamloveg
Hobbyboss 1:35 (HB83898)
The 44M TAS Assault Gun was a design of assult gun based on the German STUG III by Manfred Weiss Steel and Metal Works in Hungary. The gun had advantages over a tank of a lower profile, it was cheaper; and more open to the defensive war the Axis was fighting in 1944.  The chassis was from the 44M TAS Tank with the body replaced by a fixed hull with sloping sides. The frontal armour was 120mm as opposed to the STUG's 80mm. Planned armament was the German 88mm. Only one prototype was ever built as the allies heavily bombed the factory. Additionally shortage of materials and the Russian invasion of Hungary put paid to any production hopes.
The Kit
The kit arrives on 8 spures of plastic as well as the upper and lower hull. An additional 3 sprues of tracklinks are provided. A small PE fret and a length of brass wire round out the contents. With a fixed hull there is not a great deal of construction needed past the running gear and tracks.
First up 6 suspension units are made up, three for each side.  Each unit will end up carrying a double set of road wheels. These are then attached to the lower hull along with the mounting plates for the drive and idler wheels. Plates for mounting the return rollers are also added at this time. The Wheels are now made up and added. All road wheels are a double set.
The tracks are made up from 86 links per side, clean up is easy with the sprue gates on the edge and no other marks to remove.
Once the tracks are on then construction moves to the upper hull. The mantle for the gun is added along with hatches, pioneer tools and a few other hull fittings. Inside the hull the gun mounts which can move up and down, but not traverse. The rear bulkhead is then added along with the side skirts.  Exhaust fittings and brackets for the tow cable are added, and the cable; followed by the blisters for the two frontal machine guns. Lastly the main gun is made up and added. Once this is done the top hull is complete and can be added to the lower one.
Decals
The sheet for this is very small and contains national makings and code numbers only.
Conclusion
This is an interesting gun platform that never made it past the prototype stage and its good to see it in model form, whether you want to do the prototype or a whif, it's to be recommended.
Review sample courtesy of
have the turreted equivalent ready for a full production WHIF. Depending on how that turns out this could make an interesting counterpart
I made their 44M TAS a few years ago, but the tracks were awful, not fitting together well.
