PROPELLER
Avions Voisin Record 1927 1/8
Hi Jan, you are welcome...
Effectively, I use an air eraser, Paasche AEC 0314 and this abrasive:
Today, a small piece with louvers, who will be partially hidden...
Dry fit:
Dan.
Very tidy louvres there, Dan.....have you fabricated yourself a louvre-press, by any chance????
Cheers, H
Looking really great, Dan. Can you elaborate a bit on the louvres (how to)?
I will try to explain my method to make louvers .
Warning! Cardiacs, purists, timorous, go your way, don't look at what will follow.
I don't use a press, I use my mini-mill (Sieg X2) as a press! Remember, 0.3mm annealed aluminum
is not very strong...
Overview:
Tool holder with male tool:
Sorry, female imprint is not really clear...
And now, wish God help you!
Well, when I don't shoot my mini-mill, I'm cleaning the radiator cowl.
One side is _almost_ OK:
The other side...
Dan.
Keep going, mate....it's an absolute joy to follow your progress.
Agreed... that's what I'm using on the Fiat, although annealing isn't really necessary at this thickness, imho.
I planned to use my mini bench drill as a press, but unfortunately, I can't find a way to stop any rotation tbh. ( it's not a built-in function...it's.very basic, so not unlike myself, lol).
Do you have any idea how I can lock the spindle??????
The easiest way would be not to lock the spindle but to add a flat surface to your probably selfmade tool. Then add a guide for that surface to your toolbase, so your tool has to lean against it. In the case of a selfmade louvre stamping tool a slot could also work as a guide.
@Dan, thank you again for the information!
Edited by Schwarz-Brot
Harvey, I don't agree... Un-annealed the metal keep always a bit of "memory" and its more difficult to form it.
I use a thermal cleaner, 600 degrees (Celsius), its perfect!
In a first life I don't had a mini-mill... But I had a bench drill. May way to block the spindle, with two metal bars bolted like this:
Hope this (bad) sketch help you...
Feel free to any question!
Dan.
I use my Sieg X2 mill too, like Dan, but in a slightly different way. My tools are all custom made for one depth only - I can see the advantages in Dan's method, you can make a variety of louvres! If you look at the female tool, the distance between the slot and the end of the tool defines the spacing - the last pressing is pushed up against it to get it consistent. I also use a fence to line up the edge of the sheet. Oh, and the reason for the post - locking the spindle. I don't have a built in lock on my mill, so heres proof that Heath Robinson is alive and well and living in NZ...
IMG_3206
The tooling
IMG_3209
IMG_3212
And the result, WIP on Bentley bonnet no. 2
IMG_3208
Edited by Jo NZ
I have difficulty knowing which are reference photos of the real car and which are the model. Superlative work.
I'm with you on that Duncan, I often have to do a double take to check what I'm really looking at.  This really is a model engineering masterclass!
I have run out of ways to compliment your work, my friend.....sorry!
You do some exquisite work and I feel really proud to have my name mentioned along with your good self. Your work has been a major influence to me Dan......cheers pal!!!!
Cheers, H
Unbelievable work once again. I'm still very much in love with this model.
Not really into cars, but boy... what a build... very neat work and superb craftmanship and display of techniques......
Gentlemen, thank you very much for your kind words. Always appreciated and
of course very motivating!
Today left hand panel...
Thanks for watching!
Dan.
Looking really great, Dan. Nicely lined up louvres
You are welcome gentlemen!
Do you love louvres? More and not exactly the end...
Right side panel:
And now a new tool holder, and you can find one every where!
Here with for size louvres:
With a good tool, its enjoyable...
Dan.
That's an improved tool to what you used on the Talbot, I presume (not only the holder...)?
These louvres look extraordinarily good.
Thanks a lot gentlemen!
Nice to see you here Roy, and I agree, it's an improvement...
Some experiences later, many mistakes and now it's almost right.
Perfection is not in my world...
Dan.
She is coming...
The first bonnet is in place...With inaccurate louvres!
The real bonnet:
None louvre are identical and all are incurved. One tool for each louvre? Help! Sorry guys...
Dan.
