Takom FV432 converted to a FV436 Command Post
Tasty work,
Think the wing nuts are a bit two dimensional perhaps adding a blob of pva to the ends will help ...
Keep up the good work
Kev
Edited by longshanks
Cheers chaps ,
The wing-nuts are a prototype at the moment, just roughed out and I think I can do better :D
Still a load to do on the outside yet before I think of the inside so stay tuned
Dan
Love the small details on this Dan. It's the little things such as the hook to hold the door open. Most would omit that.
John.
So a really small update again, I'm not getting much bench time lately so every minute counts.
I made up the RF filter box that sits next to the back door, its just a box so nothing special, it does feed from the gene socket on the outside
and carries two heavy duty power cables to the DCCU ( the main switch for all things radio related) The DCCU sits up on the left hand side just behind the
the commanders position , another scratch build.
The RF filter box is only found on the 436 so anyone building a vanilla 43 wont have to think about it, I'll point out 436 only items as the build progresses
so anyone building 432 can see what Takom skimped on to detail the APC version.
Removed the padding first up.
P1050690
P1050691
Power out sockets underneath
P1050692
P1050693
P1050694
Sorry for the small update, hopefully a better one next time :thumbsup:
Regards
Dan
Again only an hour today, I decided to wire up the back just a bit,
First up is the brass wire that feeds the number plate and convoy lights on the back door.
for those interested in detailing up the standard 432 kit this is a standard item. I used lead foil
for the brackets, not a hard job but adds just a little more detail.
Next up are the two main power cables that run from the Gene box via the RF filer to the DCCU, not glued yet as I have to make the DCCU and the table that
it sits under.
P1050697
P1050696
P1050695
Things yet for the rear bulkhead are the LSVM ( Loud Speaker Vehicle Mounted ) some trunking and a Crew Box 2 (CB2 - for the intercom so that anyone in the back can hear the driver and commander)
this again is standard 432 fit and I suspect the LSVM is as well ?
Dan
The next thing that Takom missed is the HF antenna base collar which extends down
into the crew compartment, again every 432 has this detail so another small detail  if you are that way inclined.
 In the instructions Takom will have the builder add a VHF antenna base to the top of the  tubular mount,
this is totally wrong as the mount is wired and designed only for a HF base only, I'm rivet counting now I know  :o
but the HF Tuning Unit ( TURF) lives below the base on a mounting tray of which I'll scratch later.
So to the kit Clansman bases the bits you actually plug in the whip sections , they are all moulded as VHF items apart from the Bowman bases
which incidentally  you can't really use as they provide no Bowman radios. :o
You can modify the Clansman VHF base to a HF base by cutting off the very bottom part. Dead easy :D I shall show you during the build on what part to remove if you are unsure.
P1050698
P1050699
P1050700
I'll be back later to bore you all some more :thumbsup:
Regards
Dan
  • Like 9
One more Clansman era mod done, It the armoured forward VHF antenna base.  This took a while to
build, I used the kit coax port which I removed from the upper hull very carefully, Only another two more to make for the rear.
The actual antenna base will need to be modified as its a much later version that we had fitted, the one I've used had a wingnut to clamp
the whip section.
P1050702
P1050701
P1050703
Cheers for looking in.
Dan
25 minutes ago, AntPhillips said:
Accurate Armour do a set of Clansman Aerial mounts, but you probably already knew that:
https://accurate-armour.com/aa-products/135th-accessories/a189
Cheers Ant,
I've used them in the past and they are not bad, I need to find 6 of them for the 436 but I reckon
I'll be able to cobble them together. I might even have some of the AA mounts kicking about somewhere.
Dan
The next armoured box is the SCRA(T)  Single Channel Radio Access (Terminal )  antenna housing,
this is basically what the boffins developed the GSM mobile phone network from years before the public even heard of
mobile phones.  It's part of the Ptarmigan secure radio network system and my old wagon carried one. All 436's had the armoured
box but very few carried the kit. The antenna base unit (BAE:- Base Antenna  Element)  looked more
like a US Army spring loaded unit than the Clansman base unit, it had a 2m whip which
was slightly thicker than a Clansman whip.
I've also filled in the shovel bracket holes as they were removed on most 436's, not all of them but 09EA90 had them removed.
P1050705
P1050706
P1050707
I'm going to replace the bolts on the cover, they are a tad to proud so I'll punch some new ones out.
Cheers for looking
Dan
Nice detail work as always Dan Waiting eagerly awaiting the next instalment
    Roger
Thanks for the like and comments chaps :thumbsup:
So I've replaced the bolts and tidied up the box a bit, welds added and I just have to scratch the actual antenna mount and the coax outlet on the top.
P1050712
P1050711
P1050709
The whip antenna base looks like this
medium_L2014_4180__0002_
medium_L2014_4180__0001_
And the elevated antenna that bolts on top of a 12m mast, this gets stored on two brackets that sit above the exhaust so again I'll scratch build these.
$_57
Cheers all
Dan
On 3/11/2018 at 8:28 AM, spaddad said:
Hi Dan,
you mentioned in your introduction that you still had the Bren, what did you think of it? I loved that gun on the ranges, as accurate as you could want an mg to be, maybe too accurate? The gimpy was pretty good too, just different.
Ehmm gimpy surely you mean GPMG.....say the other word and it was a leopard crawl thro mud to get your kit which had been carefully scattered about by the RM training team ....good old days? Lol
Must be RM thing :D Just stamping their authority on the lesser weapon experienced types, we always called it the Gimpy :thumbsup:
Marines eh, what you gonna do?
Edited by spaddad
Yea well there where and are lots more of us than them so Gimpy it is!😀
Cheers chaps.
It's been a while since I've been able to do anything on the 43, Mrs Dads has
had me painting rooms, snatched an hour today and scratch built the SCRA(T) whip antenna and
base.
It's close but not perfect, I turned up base on my Dremel, this took a few attempts to get rightish :D
The rest is lead wire, plastic stock, small bore stainless tubing, brass rod and wire insulation.
I might have another crack at it TBH and see if I can do better.
P1050713
P1050714
P1050717
Dan
