Sign in to follow this
exdraken
Hawker Hunter F.6 RJAF Academy and else, 1/48
hi guys,
instead of doing futile work on the Mk.59,
I decided to start another Hunter..... yeah, this pending Airfix kit is intimitating my poor Academy offerings, so I will try to do them and all the AM guys some justice ;)
this time a plain F.6,  but in not too common Royal Jordanian Air Force (RJAF) markings, some time around the 6 day war in 1967
as of yesterday the kit was resting in the cellar, but when I looked through all the Resin and decals I gathered for the Mk.59, it was swiftly brought up :)
20180303_204807_1
20180303_204844_1
and immediately started in order to bring her up the a level were some synergies could possibly be achieved with the other one ;)
this one will use PJ productions F.6 gun throughs with the old style muzzle flash deflectors:
20180303_234356_1
definitely better than the kit ones ...
20180303_234405_1
the F.6 tail cone is from Heritage and molded in one piece:
20180303_234537_1
20180303_234312_1
fit on at least one side is good :)
thanks for watching and any comments, tips and criticism!
Edited by exdraken
The only way to go one better than building a Hunter kit stuffed full of extra goodies; build two Hunter kits stuffed full of extra goodies! :D
fit of the PJ nose replacement is NOT straight forward.... I guess it suffers form some shrinkage....
20180305_184051_1
the other side is much worse..
Ouch. Looks as if it'll take as much work to make that fit as it would to improve the kit part :(
You build looks like it is the same kit, all be it re boxed, to that of my current build....looking good so far :)
yeah, there is currently only one Hunter in 1/48!  (apart from a very old Lindberg model) and that is from Academy, reboxed by Italeri lately with different decals. There is also a boxing with aerobatic teams :)
for those interested....
pics showing for me with a Photobucket Embed fix
upgrade without AM here
very through rake over by @StephenMG  who did the Hunter datafile plans
very old ramble on the subject,  and problems that may not be  there,   note the comment  from Edgar as to why the Academy Hunter and Spitfire XIV are wrong...
as can be seen,  with a few tweaks a decent model can be made.....   if total accuracy and 1/48th is yr  thing, seems it time to wait  for Airfix
HTH
Edited by Troy Smith
Looking good there !
Edited by Mikey-1980
unfortunateyl I am a bit side tracked lately.....
here some progress!
20180331_103131_1
closed the fuselage ,
as you can see, the PJ insert for the gun section fits only regularly.....
20180331_103222_1
resin cockpit drybrushed, looking dark.....
20180331_103342_1
very dark....
seat is from Neomega, I think an MKII.....
is is not VERY tall......
Good work getting this one together Werner. If you have not yet fixed the seat in place there's should be a part behind it in the cockpit which the seat rests against. In the real Hunter this was a cover over the control rods for the rudder, elevators, and ailerons that will push the kit seat forward a few millimeters.
hope for even more progressthourghout the weekend ;)
20180405_181925_1
using some plastic card the fil the gaps
There's certainly plenty plastic card in there Werner. Good luck with getting it all smooth and seamless. Hope you get plenty time to work on this one and your other Hunter over the weekend.
yeah, thanks Col!
some progress to report!
nose attached, and blended in... not the most straight forward task with all the smallish resin around there...
20180407_192106_1
20180407_192136_120180407_192118_120180407_192112_1
wings glued together, I open up wylon mounting holes only for the tanks, as this one will be in fighter config!
20180407_201811_1
20180407_203535_120180407_211619_1
https://flic.kr/p/24yvyd4
Lookking more like a Hunter now Werner. Nice work getting everything together :goodjob:
a Hunter weekend ;)
lower side, including Sabrinas
20180408_002020_1
a bit more effort on the top side necessary;)
kit canopy, can actually only be used closed, as it is too narrow to slide back :(
20180407_233302_1
so I accordingly ordered a Vacform set from Maestro models. it seems a bit tinted or yellowed, but I guess (hope) this will not be too noticeable later
20180407_234400_120180407_234413_1
the front part is from the kit.
and some bad sunshine shots....
20180408_112655_120180408_112709_1
same question here: the top wing/ pylon fairings are not needed her, no? do I best close the locating hole?
Thanks,
cheers!
No fairing on the F.6 so yes close the hole :)
:analintruder: That's a noooiiiceee build, Werner, my mate!
Too late about the Falcon vac-form canopy and windshield; I recall Jonners' build using that one - the issue with the windshield on the Academy kit is sort of like that on the KP Su-22 kit. It needs some elbow grease in order for the windshield to adapt to the round profile on the forward fuselage.
Incidentally; where did you get the Heritage resin tail correction for the F.6?
Looking awesome, my bruh! :worthy:
Unc2
P.S: Karl's build thread, as quoted by mate Troy was impressive! Too bad about those non-functioning Photobucket piccies.
Unc2
thanks Uncle!
ate least there is some progress..... that is absolutely necessary, as Airix anounced a new tool......
regarding your input above:
first Karl's pictures are  NOT lost, you just need to install the Crome or Firefox extension for the photobucket embedded fix!
second, I bought the set from KitsforCash I think last year :) yeah, it is great, and I am glad to have it used!
IMG_6267_1_1
ready for paint!
a bit late I have to admit.... :(
20180525_174151_1
20180525_174254_120180525_174322_1
the main canopy is not glued of course ;) Maestro model , in order to be able to display it open!
20180525_174352_1
20180525_174551_1
and together with an MK.59 on the left, in the exact same stage....
so,....
the painting has started!
paint a Hunter in HSS..... next challenge!
looks like light grey, and that very diry on all photos, harldy every there is a very metallic shade to it on Hunters it seems!. Least so on the rare contempranean Middle Eastern Hunters.... (Iraq, Jordan, Libanon )
used Humbrol Metal cote, added, some white and hemp:
20180527_123541_120180527_123604_1
cheers, Werner
Your paint cocktail certainly has produced a fine rendition of the faded and worn silver found on the undersides of a Hunter :thumbsup:
Hi all,
unfortunately, but in the end predictably, I did not really finish in time.....
BUT I will still post updates here if you don not mind!
the RJAF HUnters had very attractive checkerboard rudder and fin tips... later those were overpainted, probably white on the tips, and red the rudder.... when exactly not clear, and if on all of them, even less so.....
so I decided to take my chances on them.....
lots of masking work, as there are no decals as of now...  :( hopefully worth it!
20180607_230758_1
white base color
20180609_233527_1
10 checkers on each row (10 squadron after all!)
20180609_234856_1
20180612_225148_1
and here on all the required areas!
20180613_200738_1
still needs a second coat.... but then .....
Glad to see you continuing with this one and great work on the masking :thumbsup:
thanks!
so, more here:
not all bad , some touchups necessary, especially on the other side of the rudder!
you live and learn, but for red over white, it turned out ok! and not pink :)
20180614_122007_1
20180614_122046_1
and some grey as main camouflage color as well! I used Revell 378 as recommended in their 32nd  scale version... looks ok to me!
20180617_102414_1
and again some salt.....
you can see, that by now I "actively" removed the stabs and rudder.... could have done that earlier..... :banghead:
cheers!
updates:
20180622_183459_120180622_185248_1
the green is Revell 361 and 65 ~ 50/50
