Julien Posted March 4, 2018 Share Posted March 4, 2018 CM-11 (M-48H) Brave Tiger With ERA 1:35 Takom via Pocketbond The CM-11 is a hybrid MBT borne out if the need to quip the Republic of China (ROC) forces with a new MBT while staying within limitations set by the US-PRC Joint Communique on United States Arms Sales to Taiwan. The MBT was developed by General Dynamics and the ROC Armoured Vehicle Development Center. The hull is that of an M-60A3 and were purchased from the US. The turret is a development of the M-48 A3 unit and was produced by the Army Ordnance Maintenance and Development Center. The turret features a M68A1 105mm main gun with the added advantage of the ballistic calculator developed for the M1 Abrams. Combined with a laser rangefinder and night vision optics this gives the CM-11 a high probability first hit in all conditions and while on the move. The commanders turret featuring an M2 machine gun was procured from Israel. In addition to this gun the loaders hatch has a mounted M240 7.62mm machine gun. During development it was found that the hybrid would not offer the same protection as newer tanks and Explosive Reactive Armour would be introduced to offset this. This proved problematic as the additional weight caused problems with the torsion bar suspension, and the older engine. These problems were solved and in 2011 tanks were seen with the new ERA package installed. The ROC all the MBT the CM-11 Brave Tiger, in the US it has the designation M-48H (H for hybrid). The Kit The ERA kit is a slight modification to the original Brave tiger kit issued by Takom. It was a welcome sight so see this MBT kitted by a major manufacturer. In the box there is the hull casting, turret casting, 6 sprues of light grey plastic, a small clear sprure, a small sheet of PE, a tow cable, 2 lengths of rubber track, 2 steel pins and a very small decal sheet. Construction starts with the lower hull. Various hull fittings are attached along with attachment points for the suspension. The rear gearboxes for the drive wheels are built up and attached. Next up the suspension legs for the road wheels from the torsion bars are built up and attached. These complex parts are built up from three parts each, and 5 parts for the front idler wheel assembly. Care must be taken on assembly as not all of the axles are the same. The road wheels (14), return rollers (6) and drive wheels (2) are then made up and added to their respective axles. Attention now move to the main hull deck. At the front the drivers hatch can be displayed open, or closed (note there is no interior). Th drivers periscope can ether be in the deployed or stowed position as well. Various hull fittings are added as is the rear ravelling mount for the main gun. Note for modellers a fair few holes need to be drilled in the upper deck for various fittings. The front lights are also added at this time. The upper hull can then be joined to the lower one and the engine louvres added at the back. The side plates which go above the tracks on the hull are now made up. There are a fair few stowage boxes on these which are also made up and added. The tracks are added and then the track covers can go on. The tracks supplied are the ribber band tracks, however they seem to be extremely well moulded. Instead of the usual arrangements of clipping them together TAKOM have gone with a metal pin each side to join the runs. Various hull fittings and some of the ERA is then added to the upper hull. Construction then moves to the tank turret. A number of holes need to be drilled to accommodate all the fittings on the turret. Antenna mounts, ventilation covers, grab handles and smoke grenade launchers are added to the hull. The gun and mantle are added. The gun is a one part barrel to which a hollow muzzle end is added. The loader and commanders hatches are added along with their respective machine guns. The various ERA panels are also built up and added ot the turret. The last item to be built up and added is the rear turret stowage basket. Markings This is probably the smallest decal sheet I have seen on a kit, even an AFV. It has only a single number, and a single national marking. Only one paint scheme is available, the US Brown/Black/Green scheme. Conclusion It is good to see TAKOM producing this kit of the MBT from the ROC. The kit si not too complex and will appeal to those who like the M48/M60 gen ration of MBTs, those looking for something a little different, or fans of the ROC. Highly Recommended Review sample courtesy of UK Distributors for 4 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted March 5, 2018 Share Posted March 5, 2018 Looking forward to seeing one of these in the Patton group build. Link to comment Share on other sites More sharing options...
Sgt.Squarehead Posted March 8, 2018 Share Posted March 8, 2018 What an oddball.....I like it! Link to comment Share on other sites More sharing options...
Julien Posted March 8, 2018 Author Share Posted March 8, 2018 9 hours ago, Sgt.Squarehead said: What an oddball.....I like it! Thats why I like it as well. Link to comment Share on other sites More sharing options...
