1/72 Type IXc U-Boat Build (U505 Early) Revell 05114
So, Christmas came and went, and as requested, a new U-Boat kit was left.
Good old Santa.
I'd completed (debatable) a Revell 05015 1/72 Type VIIc earlier in the year.
Despite struggling through the endless painting/weathering, I'd committed to, much to my surprise I wanted more.
It was my first plastic model for over 20 years but with a bit of patience, my first attempt at weathering ended to my liking.
I'd also added quite a bit of DIY detailing which I particularly enjoyed.
So, on to the Type IX.
WP_20180302_15_56_11_Pro
It's a big un at 1063mm (nearly 43") long.
I wanted to go to town on the detail with this one so I bought most of RCSubs.cz photo etch sets including the 105mm deck gun.
I didn't buy the hand rail kit as I prefer the DIY approach with these with copper and brass wire.
WP_20180101_19_50_29_Rich - Copy
WP_20180101_19_51_55_Rich
This is the first time I've even seen PE so I was quite surprised just how thin it is.
I was equally surprised by the small size of some of the hundreds of parts.:o
The deck sections also looked more daunting now that they were on the table.
More on that later.
Well, that's my project intro.
I've taken plenty of pictures so I'll start blogging to bring the build up to date.
Please feel free to comment along the way.
Be as critical as you like..........your genuine thoughts and advice are valued.
Andy.
Cheers CFFU.
I've saved lots of reference and pictures of U505 for the build.
I'm not sticking strictly to the U505 "Late" theme. More an earlier Type IXc, "U" number to be decided.
The main diverge will be the inclusion of the 105mm deck gun.
Seems they were present on many of the early Type IX boats but were removed during the mid point of WW2 when surfacing to finish off torpedoed ships became too risky due to much improved U-Boat hunting technology.
You're lucky to have such an icon, beautifully preserved and displayed in Chicago.
We have the only other surviving Type IX (U534) here in the UK but unfortunately, its been cut into sections for display.
I say unfortunately, as I would have much preferred it preserved and displayed in one piece.
It was in one piece only a few years ago but the attraction had dwindled in popularity so a new attraction was built and the rest is history.
Maybe one day they'll weld it back together and display it like Chicago have.
Moving on to the build, first job will be to open up the free flood holes.
Bearing in mind that this model will be displayed in a glass case, I only open the holes which can be seen easily from the side and above.
I'm not skilled enough to install any PE free flood detail so I'll thin down the hull shell (from inside) in the areas visible to improve the fine detail effect.
WP_20171228_15_11_51_Rich - Copy
WP_20171228_15_13_37_Rich
WP_20171228_15_13_09_Rich - Copy
Next, the Revell hull panel lines and rivet detail is way over pronounced.
Technically, at this scale, the lines and rivets would have been barely visible.
Some of those lines were protruding nearly 1mm which would have represented 70+mm at scale!
So I scraped and sanded the lines and rivets to a much more subtle effect.
This is the first time I've ripped into the stock molded detail in this way but glad i did, I think it looks much more realistic.
The following two pictures show, before sanding (on left) after sanding (on right)
The last two show how smooth the actual Type IX hull was.
WP_20171230_13_30_48_Rich
WP_20171230_13_43_58_Rich
35188361160_dc1d92e8435188361160_dc1d92e8
Thanks for reading, more soon.
Looking like quality work so far. I just finished one as well, completely OOB
The PE from rcsubs.cz is great. Oto makes some beautiful products and the fit is perfect.
pulling up a chair to follow this one
I'll get back to the build shortly, but just wanted to share this with you all.
We spent a week in France last September and during our stay, we visited the U-Boat pens at St Nazaire and La Rochelle.
The missus was thrilled. :blahblahblah:
Pics below, then back to the build......promise.
These are the pens at St Nazaire.
You can walk around inside and out.
There's also stairs onto the roof where you get a good view of the fortified lock opposite and the Loire estuary beyond.
Better still, the first pic is pretty much the view from a harbour side restaurant where we had lunch.... Heaven.
IMG_1084
IMG_1107
IMG_1110
This is the rear which backs onto a supermarket.
IMG_1105
This is the fortified lock which the U-Boats passed through to get into the Loire estuary and the Atlantic.
IMG_1100
This is the 4m thick reinforced roof which, despite dozens of bombing raids, was never breached.
IMG_1103
And Finally, these are the pens at La Rochelle.
They are part of the harbour secure complex so this is as near as I could get.
Love the Bismarck style camo painted on the side and front.
IMG_1164
That's all.
More sub soon.
Edited by AndyPG
Ok, back to the build.
Opening up the large free flood vents along the side of the Type IX gives a clear view inside the hull.
I'm not really up for building full under deck detail but I did want the immediately visible structure replicating.
Namely the support brackets with holes in.
This meant cutting 128 tiny triangular pieces of 0.5mm polystyrene sheet and drilling a 2mm hole in each.
I'd already glued the hull halves together so this was really fiddly.
35188361160_dc1d92e84e_o (1)
WP_20180301_13_36_48_Pro
WP_20180301_13_38_03_Pro
I'm pretty happy with the way this turned out as the little brackets are very visible and look much better than the original Revell detail. (Below)
Thanks for reading and more soon.
Andy.
  • Like 10
Thanks Tom,
Knowing that other builders, of this model, had fit issues joining the hull forward and aft sub assemblies, I took extra care to make sure the joint was as good as I could get it.
Unfortunately, the plastic has a sink line running along the side of the join so after a light coat of primer, I could see that filling and sanding was going to be unavoidable.
I'll replace the rivets and hull lines later.
WP_20180302_08_15_50_Pro - Copy
WP_20180302_08_15_35_Pro - Copy
And after another light coat of primer, I can see it's good enough.
WP_20180302_12_49_14_Pro - Copy
Since the kit arrived, I couldn't take my eyes off the bulging sonar thingy at the forward end of the keel.
Don't like it so it has to go.
Initially, I thought this would mean I'd have to model the build on different Type IXc sub but it turns out that the sonar bulge was only fitted to U505 in the last year of service so my build will simply be U505 in it's earlier years.
This bides well with the fact I'm installing the 105mm deck gun, also only present in its earlier years.
To seal the deal, my U505 early decals arrived this morning, ie two black axes and the Olympic emblem.
The shell/shield emblem only appeared on U505's final sortie.
Anyway, here's the sonar bulge removal pictures.
Hole filled and keel remodeled with polystyrene sheet.
WP_20180301_11_50_55_Pro
WP_20180301_13_46_41_Pro - Copy
WP_20180302_12_48_27_Pro
Happy with that.
Edited by AndyPG
  • Like 9
I know what you mean.
I went carefully with the sanding so I've only lost maybe 100 rivets.
Just another one of those tasks where we have to get in the zone and knuckle down for a couple of hours.
Andy.
6 hours ago, uncarina said:
By the way, have you seen this? http://amp.rokket.biz/lib_
Cheers,  Tom
Hi Tom,
Yeh, AMP is where I bought the U505 "early" decal sheet.
Lots of great reading on there.
Thanks for suggesting.
Thanks everyone for the comments.
Really appreciate the encouragement.
Andy.
Ok, time to have a go with some of that photo etch.
Probably no need for too many words here.
Here's a few pictures of the detailing done so far.
WP_20180204_10_33_11_Pro
WP_20180301_13_38_41_Pro
WP_20180309_14_32_30_Pro
WP_20180309_14_31_25_Pro
WP_20180309_14_31_40_Pro
WP_20180309_14_29_41_Pro
WP_20180309_14_33_39_Pro
I drilled the ends of the gun barrels out to improve their look. The photo etch set includes tiny pieces of brass which need rolling into a cone in order to replicate the flared barrel muzzle.
The standard muzzle detail is so good so I'm still pondering as to whether I can make a good enough job of them to be an improvement.
My Type VIIc Flak gun muzzle was very crude and a brass barrel or even a PE muzzle would have been welcome.
I'll see how we go.
WP_20180302_14_43_38_Pro - Copy
WP_20180129_22_22_23_Pro - Copy
WP_20180302_14_40_47_Pro - Copy
WP_20180302_14_40_33_Pro - Copy
WP_20180204_10_33_36_Pro
The supplied PE bollard tops weren't quite right.
The PE instructions called for them to be glued to the top of a short piece of 2.4mm round poly rod.
I had some 2.4mm (3/32") brass tube which was perfect as the Type IX bollards do appear to be hollow anyway.
Once the tops were glued in place, you can see the obvious issues when compared to U505's actual item.
They are far too big and their design doesn't make sense at all.
I checked the suggested 2.4mm rod diameter and my references show this to be correct to scale.
After some fiddly messing around, I scrapped the supplied tops and scratch built my own from spare PE brass sheet.
In the pic below, the supplied top is on the right and my DIY one on the left.
WP_20180225_10_03_32_Pro
Here are a couple of pics of U505's bollards.
bollards2
bollards
As you can see, the tops are much smaller and the cross bar slimmer than depicted in the PE.
Here's a couple of pics of the DIY ones in place.
WP_20180301_13_39_45_Pro
WP_20180301_13_40_12_Pro - Copy
  • AndyPG changed the title to 1/72 Type IXc U-Boat Build (U505 Early) Revell 05114
