Sten Ekedahl
Q: MB 200 interior colour?
Many many years ago a friend gave me the KP 1/72 Aero MB 200 kit. I wanted to do a French aircraft so I found some nice aftermarket decals for it and also some very good PE details for it. But as I started building and at the same time searching for references, I discovered that the front fuselage and the nose gun turret differed between the French and Czech built aircraft. The KP kit naturally portrays the latter. So the kit ended up on the shelf of doom. Fast forward some fifteen years, and I found and ordered a conversion kit that will solve the problem. So I will now resurrect this project. However one big question remains. Since there are windows all over the fuselage, and a large cockpit canopy, a lot of the interior will be visible. However I have been unable to find out what the interior colour was. KP doesn't say anything in the instructions, and Google has drawn a blank. So my only hope now is that anyone out there can help me with this.
TIA
Edited by Sten Ekedahl
afair; Most French aircraft were finished in a mid shade blue/grey inside in the years up to 1939. That is the colour I'll be using on my Amiot 143
IIRC French interiors were either chamois, a light buff brown, or blue fonce.
Chamois = Colourcoats ACF 11 / Vallejo 70:917
Blue fonce = Colourcoats ACF 12 / Vallejo 71:091
Other paint manufacturers are available;)
Having a look at the very few images available, which appear to be quite dark, I would go with Blue fonce.
Christian, exiled to africa
Hi
The colour was Chamois, the Blue Fonce was mainly for the fighters.
Paul
Thanks for the help. So chamois is the most likely colour. As I use enamels, mostly Humbrol, what would be the closest Humbrol equivalent?
No. 7 Light Buff ??? (A gloss colour...)
Possibly No. 74 Linen + No. 26 Khaki ??? (Matt).
Is wentzels still going? and Hobbybook Handeling at 23 Pipersgatan, (spelling...)
Christian, exiled to africa och 10 ar vid Uppsala universitet
Thanks, helps a lot. Yes, both Wentzels and Hobbybokhandeln are still going strong. Wentzels relocated from Gallerian to Gamla Brogatan (four or five blocks away) about two years ago. Sadly one of the owners, Jan Wentzel, passed away from leukaemia some eighteen months ago. Much too early, barely fifty years old. But despite this the shop is doing well. Hobbybokhandels has during the last four or five years expanded their second hand kit buisnes a lot.
Chamois appear during 1939 and it's a very light color. Until dec 39, the french air ministry stipule(1935 to 1939)
a "flat, dark neutral color" for interior area, included cockpit..
before 39, Morane(230,406), Caudron(714) use "light blue grey" and Breguet(691/693), Latecoere(298), Dewoitine(520) "blue grey", interior cowling & wheel wells were same color as underside
From dec 39, "Night blue" was applicable to cockpit area of all military airplanes in factory
Before 1936, Breguet use "kaki" for interior of his Br XIX, but this "kaki" is light and look like "interior green 611"
below, chamois paint on D520 wreckage(rear fuselage, interior)
Edited by BS_w
Think I have found a solution for the chamois colour; Humbrol 94 (Matt brown yellow) + white.
Now two more questions:
1. From what I've been able to deduct from photos on the net, the cabin door on the left side, is hinged on the edge towards the front of the aircraft, and opens inwards. Confirmations?
2. What was the normal colour of French bombs? We're talking around 1939 here.
33 minutes ago, dogsbody said:
French bombs: http://www.bombfuzecollectorsnet.com/USERIMAGES/OP 1668 Italian & French Explosive Ordnance.PDF
I would agree on the door situation. Hard to find a good picture, but it definitely opened inwards.
Chris
Very good information on French bombs! Thank you. But typically this proves the disadvantage with good references. The bombs in the kit, being the Czech Air Force version, are very different from French bombs, apart from the 10 kg flares. The shape of the French bombs are completely different. Hmmm... Time to do some thinking.
3 hours ago, dogsbody said:
I know. I have the same kit.
Chris
Out of curiosity, what's your plan for it?
Nothing as of yet. It's stuck down in the stash.
Chris
Managed to pick one up for a fiver at Telford after trawling through evilbay for ages. Mine will be taking a rather Saxon outlook some point in the future...
9 hours ago, Bobk said:
Looks to me as if the door of which you speak is hinged along the top edge and when opened lays up against the bottom of the wing so it opens outwards. On page 5 of this subject about Oct 3 2017 you will find two photos that will clear up the question, I hope. http://www.modelforum.cz/viewtopic.php?f=310&t=49106&p=1873039&hilit=MB+200#p1873039
Several photos there that I haven't seen before. Although there were some differences between the Czech and the French versions, I don't think the door differed. And looking closely, I think you're right there. There's even a photo on page one that seems to support this. Good thing then I had not yet constructed the door supports inside the fuselage to mount an inward opening door! An up and outwards opening door simplifies building a great deal. Thanks a lot!
One more question about an interior colour, this time the instrument panel. The easy solution would be painting it black. But was it really? Considering the fact that this aircraft was built in the early thirties, this was at a time when many aircraft still had instrument panels made of wood. so question is if the MB-200 also had this. Looking at the etched IP I have, it looks like main panel could be wood with smaller sections of it made of (black) metal. Would anyone care to speculate further, or even try to answer? Oh, another thing. I sort of got the suspicion that the internal floor in the aircraft actually might have been made of wood. It would be a logical solution to save weight in an aircraft that was rather underpowered. But this is pure speculation from my side.
Some drawings of the interior I got years ago on another long-gone forum. Unfortunately, there isn't one of the cockpit.
MB.200a
MB.200b
Chris
I have a photo from ebay that shows either a MB 200 or an MB 210 cockpit that shows the instrument panel as a very dark color. My guess would be black or midnight blue but I would lean heavily towards black.
MB.200a
MB.200b
Chris
Those drawings match exactly the Extratech (now marketed by Bren gun) PE parts.
Sten, I don't remember exactly when I got these, but it was at least ten years ago. Some had posted something about the MB.200 on that now-gone forum and amongst the replies were these drawings. As I was still fairly new to the Internet thing and hadn't fully learned the ins and outs, I didn't keep track of the original source, if it had even been mentioned.
Chris
Probably black, midnight blue appears dec 39 and use for cockpit area except the D520 which had panel instrument painted in midnight blue also.
