bentwaters81tfw Posted February 18, 2018 Share Posted February 18, 2018 Although production of this kit runs to about 100 kits, I know a few of us have stumped up the readies. Mine is now fully decalled and only requires the wheels and props attaching. I have found one or two details that need addressing to save you a little trouble. This is a resin kit, and when assembled is relatively heavy compared with i/m. The u/c comprises white metal legs throughout with flattened resin wheels. There is a main heavy casting with an H pattern retraction strut. This strut may need shortening slightly to get the main casting at the correct angle. The oleo struts glue into the main casting, and are approx 1.5mm in diameter, and terminate in an axle box. The oleos are also too long. Under load, the axle boxes are only just proud of the heavy castings - check the photographic references ion our Walkaround section* These oleo struts are very weak and bend easily under the weight of the airframe. I have just had one snap off. I recommend the following fix. You will need a mini vise and a 1.2mm drill. Firstly drill the holes in the main leg casting 2-3mm deeper (more if you like). Take each (4) axle boxes and cut off the oleo strut. Do these one at a time so you have a reference point. Drill the axle box vertically to accept a replacement steel oleo pin. Superglue replacement oleos. Second point. The axle boxes have a large diameter peg instead of an axle shaft. The wheels are resin and have a centre spot marked but will need to be drilled to fit the legs. I have drilled a 1.2mm hole across the axle boxes and through the wheel hub to accept a steel axle pin. I then reamed out either side of the hub to accept the pegs. Obviously you will end up with two holes drilled at 90 degrees to each other, but the axle box is big enough, and a dollop of super glue holding the axle and oleo will strengthen the whole assembly. It's a bit of a faff, but will result in u/c that will take the weight of the model. The tail wheel will just superglue into the fork and mudguard. On the instruction sheet, Mel says fit the main gear wells into the wing with slow setting epoxy, then fit the nacelles. Be sure to assemble in the stated order - however: The wells can be dropped into place dry, the nacelle offered up with a dab of superglue at the rear, then the well can be positioned with a finger and thin superglued. The front of the nacelle can then be superglued to the wing. You will need to file some corners here and dry fit in order to get the correct alignment. The fuselage halves have a rough finish to the mating surfaces. DO NOT be tempted to sand these smooth. If you do, the fuselage will be too narrow and you will have problems with the (resin) canopy - no spare. Test fit and file the windows to get a snug fit - particularly the rectangular ones. I used Clearfix. Match the fuselage halves carefully (The cockpit bulkhead may need filing) tape together with strips, and superglue in short sections. Start above and behind the cockpit and work aft. Then underneath and work forwards, closing the nose last. Let each application dry before starting the next. Then you can sand and fill the joint as required. I found the canopy to be slightly wide and low at the back. After dipping in Klear, I superglued one rear corner on the vertical join - Not the cill. I left it over night then did the same the other side, nipping the canopy between fingers to ensure alignment. When this cured, the corners were flush, and top lined up without a dip. Any gaps were taken up with superglue or GS Hypo and Deluxe perfect putty. The inner wings will need fettling to get a snug fit at the root. A sharp knife and a small flat file will take care of this and any other fine adjustments you need. The under nose glazing may also need the 'glue one corner at a time' treatment as well. When fitting the tailplane, glue flush with the cabin roof joint, and fill any horizontal gaps under the tailplane afterwards with plastic shims and filler. If you do it the other way, you will have a nasty step to fill on the cabin roof. Don't forget to fit the tailwheel well before the tailplane! A final point. The astrodome has no lip to it, and mine at least is very slightly oval, as is the hole. You can see where this is going. After retrieving the dome twice from the inside if the finished airframe, I used a large dollop of Clearfix to glaze the hole, then fitted the dome on top with the longer axis longitudinally on the airframe Aside from that, it goes together with little fuss. * Frank. 2 Link to comment Share on other sites More sharing options...
Guest Posted February 19, 2018 Share Posted February 19, 2018 Ta for that. Just have to get one now - I bowled up to Mel on the Friday at Telford and asked for both the Hastings and a Cranberry, only to be told that he had neither. Pity, because he'd have had £170 instead of me putting it aside for next year. Link to comment Share on other sites More sharing options...
Edge Posted February 19, 2018 Share Posted February 19, 2018 6 hours ago, The Wooksta! said: Ta for that. Just have to get one now - I bowled up to Mel on the Friday at Telford and asked for both the Hastings and a Cranberry, only to be told that he had neither. Pity, because he'd have had £170 instead of me putting it aside for next year. I asked Mel about the Hasting & his response was that he's due another batch from the casters early 2018, so hopefully not long to wait. Edge Link to comment Share on other sites More sharing options...
chris57 Posted February 19, 2018 Share Posted February 19, 2018 I picked up Canberra's from Mel at Banstead and enquired about the Hastings. Apparently there is a problem with the canopy casting which needs resolving, so no fresh supplies at the moment. Chris Link to comment Share on other sites More sharing options...
Edge Posted February 19, 2018 Share Posted February 19, 2018 33 minutes ago, chris57 said: I picked up Canberra's from Mel at Banstead and enquired about the Hastings. Apparently there is a problem with the canopy casting which needs resolving, so no fresh supplies at the moment. Chris Thanks for the info Chris. Keep my fingers crossed that the canopy issue can be resolved. Edge Link to comment Share on other sites More sharing options...
71chally Posted February 19, 2018 Share Posted February 19, 2018 Hopefully he is considering injection plastic-ising it! Link to comment Share on other sites More sharing options...
Guest Posted February 19, 2018 Share Posted February 19, 2018 According to Colin at Freightdog, there's only a few who do clear resin casting and it has a high failure rate (I had a spin myself with only bad results). Hence he's sticking with vacform canopies with his Supermarine 327. Perhaps Mel should reconsider the clear resin and switch to vacform? Link to comment Share on other sites More sharing options...
wavodavo Posted February 19, 2018 Share Posted February 19, 2018 Very interesting information. I started mine last year but got side tracked on other things. The thing I've got a problem with is the shape of the fuselage, one side has the tail end has bent in and the two halves don't meet with one half taller than the other. Dave Link to comment Share on other sites More sharing options...
bentwaters81tfw Posted February 19, 2018 Author Share Posted February 19, 2018 1 hour ago, wavodavo said: Very interesting information. I started mine last year but got side tracked on other things. The thing I've got a problem with is the shape of the fuselage, one side has the tail end has bent in and the two halves don't meet with one half taller than the other. Dave Why not contact Mel? Perhaps his manufacturer may have a solution, or Mel might send you a replacement part. OTOH, Radleigh on here has experience of resin kits (this was my first, and I have several others) and he may have a suggestion or two. 1 Link to comment Share on other sites More sharing options...
Guest Posted February 19, 2018 Share Posted February 19, 2018 Hot water. Dip the bit in, let it soften then carefully bend it to the correct shape. You may need to repeat the process a few times as resin sometimes seems to have a "memory". Bulkheads may well make the fuselage conform. 1 Link to comment Share on other sites More sharing options...
