Sign in to follow this
Julien
Modern AFV UHF Antennas - 1:35 Master Models
1:35 Master Models
Modern AFVs often sprout many antenna and getting them to look right on models can be frustrating. These two sets from Master Models are designed for the IBG KTO Rosomak but can be used on a variety of vehicles.
UHF Antenna [35-016]
This set has a resin antenna mount which is shipped in a foam collar for protection. The short tube fits into the mount and the whip antenna to the tube.
UHF Antenna with tilt adaptor [35-017]
This set has a resin antenna mount which is shipped in a foam collar for protection. The short tube fits into the mount and the whip antenna to the tube like the above set. The addition here is a tilt mount which can be fitted between the base and the whip antenna . This has a small resin adjustment cog, and a couple of very small mounting pins (not shown)
Conclusion
These will certainly add something to your finished model, though be careful with them as the carpet monster will also be attracted to them.
