Sign in to follow this
Bjorn
Mil Double: 1/48 Aeroplast Mi-2 and 1/72 Zvezda Mi-8T
2018 started with some helicopters. First the 1/48 Aeroplast Mi-2:
Most is OOB - with was difficult enough. This is not a bad kit at all, but it is truly no shake-and-bake-build. Lots of dry-fitting and fettling was necessary. On the other hand, surface detailing is very good and after all, almost no filler was neccessary.
I used a few aftermarket decals from DF Helostuff. These were the thickest I have ever worked with, with hugely oversized decal film, almost 0,5 mm wider than the decals. To make it even more difficult, the kit stencil instructions are horrible, and the decal sheet had no indication numbers!
The curtains are made from toilet paper... :)
And so the 1/72 Mi-8: Mostly OOB, apart from some re-shaping of the part above the cockpit windows, to remove the "eyebrow" feeling.
The Finnish Air Force decals are from GAL Decals, and was pretty OK.
The biggest challenge was the rivets. I decided to keep them, and managed in some way to save them through the sanding. Luckily, fit was fairly good.
Two pretty quick builds, finished within five weeks from the start. I was surprised about the size of the Mi-8, both are about the same size although they are in different scales.
Thanks for watching. And there are more Russians to come.
What can one said that hasn't been said before? ;-)
Fully up to Björn's standard, and that means something.
Kind regards,
Joachim
Great looking pair of choppers there, really nice work
Loving these beauties!   I'm playing a game called heliborne at the moment via steam, flying these birds, which is wanting me to model them too!  The Mi-8 is awesome!
Nice helicopters Bjorn! Superb!:yes:
Hi Bjorn,
I like your Mils! I don't see any thick decals on the Mi-2 in the final result.
I also have some decal sheets made by DF HeloStuff and keep in mind that they have (unlike large scale production decals) a continuous carrier film which covers the whole sheet. As mentioned in the handling instructions, every decal item has to be cut out individually 2-3 mm around the edge of each symbol.
Edited by troschi
Yes, but this was something between a continuous film and "normal" carrier film. But this was not the main issue (I did cut them out), the thickness was the main problem. As I wrote, I have never ever worked with such thick decals.
I was worried for a moment as I hadn't seen the different scales - I too was surprised at the size of the Mi-8! :D
