Sign in to follow this
rockpopandchips
The MSM-07 Z'Gok 1/144 HG
Speaking of “Maximilian” from “The Blackhole”. They were going to re-make the film. But its on hold for the “script being to dark”.
Edited by Corsairfoxfouruncle
First part of the resin is in and I happy so far, fingers coss is will set ok. I will add some white water and a few waves once it is set, probably going to try using modgepod gloss.
2018-03-10_10-23-51
Edited by rockpopandchips
On 3/8/2018 at 10:29 PM, Hunter Rose said:
Cool! And no epoxy shouldn't react with the resin after its fully cured
Cheers. I gave it 2 days before adding the resin.
On 3/8/2018 at 10:32 PM, Will Vale said:
For some reason that reminds me of Maximilian, despite the blue. Scary!
I like the base too, the way you've laid it out it has a good organic feel.
cheers,
Will
Thanks Will, Maximiian is very cool, going to have to see in the Blackhole is on amazon now....:D
LOL
Guilty as charged. Turned up yesterday after seeing it mentioned on this thread.:blush:
Mart
8 hours ago, Hunter Rose said:
Looks cracking already Brian!
Yes it is!
Getting some nasty shrinking around the edges, may be the 200g of resin in one go was to much.
20180311_213945
Thats a bit of a swine! I've had that happen to me (especially with smelly polyester resin) maybe mix a small amount together and use it to fill the gap.
Look forward to seeing more on this :)
Its polyester resin i used, I did realize it would shrink as much as that. I will give a day or 2 more and try frilling that gaps with more of the same.
A second very light coat of the modpodge applied and blown with the airbrush to get the ripples. Once fully dry i will add a small amount of white dry drushing in a few spots
2018-03-13_09-27-13
10 hours ago, Pete in Lincs said:
I like that.
Thanks.
8 hours ago, The Chief Smeg said:
I agree - looks REALLY good
Thanks.
I think i have finished it now, i feel like i should be adding some grass in the water but im not sure it needs it. What do you think?
20180314_215259
20180314_215444
That looks fantastic !
Its a same about the resin shrinkage around the edge but in no way does it detract from the diorama. The sense of movement through the water is very very realistic.
Pete
Not for me. I would be very happy with it as is.
I'm with Pete on this, I don't think it needs any grass in the water it looks fantastic as is
Pete
Edited by Brundledonk
