tonyot Posted April 23, 2018 Share Posted April 23, 2018 Wow this is looking gorgeous,....... you were very brave to paint the white over such a well finished model,...... but you have cracked it! Personally I would dab another coat onto certain areas,..... but as you say,.... the paint wore off very quickly and was often literally daubed on! How about this for a `different' arctic camo, seen on Harrier T.4, ZB600/R in 1984; This has always been my favourite Arctic Harrier pic; Good luck with the finishing off,....I have yet to start my kit yet! Cheers Tony 3 Link to comment Share on other sites More sharing options...
Tripio Posted April 24, 2018 Share Posted April 24, 2018 Good afternoon, I really love the T4,was hesitating on the build to this GB,but this artistic arctic scheme is way over my skills. Yours,minion looks beautiful. Regards,Laz 1 Link to comment Share on other sites More sharing options...
Hewy Posted April 24, 2018 Share Posted April 24, 2018 That's starting to look like a pretty good representation of the winter white, looking good craig 1 Link to comment Share on other sites More sharing options...
modelling minion Posted April 24, 2018 Author Share Posted April 24, 2018 19 hours ago, shatters said: The winter finish looks really convincing, great job. Phil Thanks Phil, its getting there but is quite time consuming. 19 hours ago, Hockeyboy76 said: Good luck with the rest of the white. Thanks HB, I think I need it! Link to comment Share on other sites More sharing options...
modelling minion Posted April 24, 2018 Author Share Posted April 24, 2018 18 hours ago, tonyot said: Wow this is looking gorgeous,....... you were very brave to paint the white over such a well finished model,...... but you have cracked it! Personally I would dab another coat onto certain areas,..... but as you say,.... the paint wore off very quickly and was often literally daubed on! How about this for a `different' arctic camo, seen on Harrier T.4, ZB600/R in 1984; This has always been my favourite Arctic Harrier pic; Good luck with the finishing off,....I have yet to start my kit yet! Cheers Tony Thanks Tony, I look forward to seeing what you can do with this kit. Funnily enough the aircraft in your first pic is the very same one I'm building, ZB600. In your pic she is actually painted up for a Summer exercise in Germany, and the paint was quite neatly applied, and she does make for a different looking model. 2 hours ago, Tripio said: Good afternoon, I really love the T4,was hesitating on the build to this GB,but this artistic arctic scheme is way over my skills. Yours,minion looks beautiful. Regards,Laz Thank you very much Laz, you are far too kind. I'm sure you could do a good job on the arctic paint scheme. 30 minutes ago, Hewy said: That's starting to look like a pretty good representation of the winter white, looking good craig Thanks Glynn, still a fair bit of work to do yet though. 2 Link to comment Share on other sites More sharing options...
PlaStix Posted April 24, 2018 Share Posted April 24, 2018 Hi Craig. You have really done a superb job with the whitewash. If you do decide to paint any more areas with the white you could try stippling it very thinly in several layers. It's how I did my first white wash on the Pz.III at the end of last year. Any streaking of the paint I then did after the stippled layers were dried and I used a very fine brush but again with very thinned paint. It meant I got the steak effects how I wanted them. If you do decide to try this, practice on some scrap first. Looking forward to seeing more. Kind regards, Stix 1 Link to comment Share on other sites More sharing options...
exdraken Posted April 25, 2018 Share Posted April 25, 2018 Brave!! Bit really looking good! 1 Link to comment Share on other sites More sharing options...
modelling minion Posted April 26, 2018 Author Share Posted April 26, 2018 Thanks for all your inputs, likes and suggestions guys, all very much appreciated. Well I bit the bullet and applied some more coats of the white until I was happy with how it looked, the only problem was that it had visible ridges etc in the paint and the effect was way over scale so I decided to give the white a quick going over with some very fine micromesh. Well as soon as I started it became apparent that the white would return to liquid form with the water I used with the micromesh so I knew I had to go lightly, so I did a small area then dried it off to see what the results would be like and I liked them so carried on and did the rest of the airframe. After I was happy with the white I used a watercolour wash for the panel lines and then sealed the whole thing with some matt varnish which also meant I could remove the masking from the canopies, which in my opinion always brings the model more to life, anyway here are some pics of how she looks now starting with an over all shot; And some closer shots so you can hopefully get a better idea of how the white looks. As you can see I have also added the exhausts, i have also added some exhaust staining to the rear of the aircraft and some staining in front of and on the end of the gun pods to simulate the effects of being fired. I have also built up and painted the undercarriage. The plan for this evening, when I can drag myself off the computer looking at other peoples great builds, is to get her on her feet and then sort out the undercarriage doors. I still have to decide whether to have the canopies open or closed, any thought guys? Thanks for looking and as usual all comments and criticisms are gratefully received. Craig. 8 Link to comment Share on other sites More sharing options...
modelling minion Posted April 30, 2018 Author Share Posted April 30, 2018 And she is finished! You have no idea how glad I am to get this one over the line, it has not been the easiest or most fun of builds but I did enjoy the painting and weathering and am quite pleased with how she has finally turned out. I decided to go with the closed canopies in the end as if I have her parked up on a taxi way on a Norwegian airfield I didn't think that the ground crew would leave the canopies open letting all the cold and snow in and making more work for themselves. I have also just added the large drop tanks on the inner pylons for a couple of reasons the first being that this is a configuration I have seen on several T-4's in Norway and the second being that the ones in the Kinetic kit are crap. Anyway enough waffling here are some pictures of the finished item; And a couple of close ups of the cockpit and weathering. In the sunshine! Thanks for all of your comments and support through my build guys, all very much appreciated. Will this be my last Harrier? Definitely not. Will it be my last Kinetic Harrier? Possibly. I have got the winter camo bug again though so expect more to come! As usual all comments and criticisms are gratefully received. Thanks for looking in. Craig. 13 Link to comment Share on other sites More sharing options...
Boman Posted April 30, 2018 Share Posted April 30, 2018 Very nice! 👍 1 Link to comment Share on other sites More sharing options...
Hockeyboy76 Posted April 30, 2018 Share Posted April 30, 2018 Great work dude, you have done well with the white, looks like she’s had a hard detachment. 1 Link to comment Share on other sites More sharing options...
modelling minion Posted April 30, 2018 Author Share Posted April 30, 2018 59 minutes ago, Boman said: Very nice! 👍 Thanks, much appreciated. 21 minutes ago, Hockeyboy76 said: Great work dude, you have done well with the white, looks like she’s had a hard detachment. Thanks HB, that is exactly the look I was going for. Link to comment Share on other sites More sharing options...
PlaStix Posted April 30, 2018 Share Posted April 30, 2018 Great looking Harrier Craig. Superb job all around! Very well done. Kind regards, Stix 1 Link to comment Share on other sites More sharing options...
modelling minion Posted April 30, 2018 Author Share Posted April 30, 2018 3 minutes ago, PlaStix said: Great looking Harrier Craig. Superb job all around! Very well done. Kind regards, Stix Thanks Stix, very much appreciated. She fought me at times but I'm quite pleased with how she has turned out in the end. Are you going to the Hinckley show on the 20th mate? 1 Link to comment Share on other sites More sharing options...
Valkyrie Posted May 1, 2018 Share Posted May 1, 2018 Great dirty looking Harrier. The streaking from the front of the fuel tanks going back is so well done it looks real. This is definitely the best scheme on a Harrier 1 Link to comment Share on other sites More sharing options...
PlaStix Posted May 1, 2018 Share Posted May 1, 2018 16 hours ago, modelling minion said: Are you going to the Hinckley show on the 20th mate? Hi Craig. Not sure yet......but probably. A bit will depend on how well the trains run on the Sunday.....if at all! Neither Mrs PlaStix or I drive so we are reliant on public transport. I'll let you know if we are going. Kind regards, Stix 1 Link to comment Share on other sites More sharing options...
Red Dot Posted May 1, 2018 Share Posted May 1, 2018 having seen it in the flesh, i can confirm that it's a cracker. Nice one Craig Andy 1 Link to comment Share on other sites More sharing options...
nimrod54 Posted May 1, 2018 Share Posted May 1, 2018 WOW! What a great build Craig and fantastic work on the 'Winter Camo'. As you said earlier, the difficulty with these schemes is showing enough restraint in trying not to achieve a perfect finish, I think that you have hit the right balance with this one. 1 Link to comment Share on other sites More sharing options...
CliffB Posted May 11, 2018 Share Posted May 11, 2018 Well worth all the effort Craig. It's superb. Cliff 1 Link to comment Share on other sites More sharing options...
