Sign in to follow this
Shar2
RN Cruiser Zara barrels. 1:350
1:350 Master Models
With more and more 1:350 ship kits being released, Master Models are continuing to build up their range and keeping up with the ever increasing demand for barrels with a much better scale appearance
[350-098]  - This set is for the Trumpeter Italian cruiser Zara which not only includes both main, (203mm), secondary, (100mm), but also tertiary armament, (37mm and 13.2mm).  These are all direct replacements for the kit parts, and will need the removal of the kit barrels before drilling appropriate sized hole, (0.8mm for the 203mm, 0.5mm for the 100mm, 0.3mm for the 37 and 13.2mm guns), into the breech for the tang of the barrel to be glued into.  As you can probably imagine the smaller calibre barrels are extremely small and fiddly, but they will certainly add the scale look of the completed model when fitted.
Conclusion
The barrels for the Zara are well up to the standards we’ve come to expect from Master Models, with the added distinction of being some of the smallest turned parts I’ve seen in 1:350.
