Sign in to follow this
Shar2
Chance Vought F4U-1D Corsair detail Sets. 1:32
Eduard 1:32
The Tamiya 1:32 Corsair F4U-1D is a fantastic model straight out of the box as are all of this series of 1:32 kits, but there are always more ways to gild the lily.  This is Eduard come in with their range of update sets for it, four more in fact if you include the zoom and mask sets, on top of the ones already released.  Each set is held in the usual poly sleeve packaging with a card insert to prevent damage, and the instructions still leave a lot to be desired.  Typically some of the kit details need to be removed before the brass parts can be added.
Interior Zoom Set (33181) - Contained on a single of relief etched brass, it being pre-painted but no longer self adhesive. There are a large number of instrument boxes fitted around the cockpit, on the side consoles; coaming and side walls onto which the pre-painted faces are attached.  The instrument panels are also pre-painted complete with the instrument faces on the backplate.  A little dab of aqua clear will give them the appearance of glass fronts. There are also parts for complete replacement throttle quadrant and gear leaver housing.
Exterior (32412) - This single sheet set contains some very nice additional detail for the exterior and open areas of the kit.  There are quite a few parts dedicated to the interior of the tailwheel bay, especially on the mounting bulkhead which has new mounting fixtures and fittings for the tail oleo, whilst the foreward bulkhead is fitted with new fittings which include the rudder cable arm and mounting bracket. The tailwheel bay doors are fitted with new hinges panels and attachment links.
The main wheel bays also get a dose of additional detail with the fitting of new panels around the bay walls and roof along with additional cabling and pipe work.  If you’re building the model with wings folded then you have the option of adding new end plates to the flaps and ailerons along with replacement brackets and web pieces.  The wing fold areas have a host of new hoses and pipework fitted which will really make the areas look not only more accurate but busy. The kits bombs get new arming vanes for both the nose and tail positions as well as new bomb lugs, but in this scale they need to be thicker, so it may be best to keep with the kit items. The rockets are fitted with the electrical cable that attaches to the rear of the rocket, and can be left hanging if desired, to show that they’re not armed yet.
Seatbelts (33180) - This small single sheet of etched steel contains the pre-painted seatbelts, and while they are quite simple to use, they do look really nice with the stitching picked out and some shading already added. They may take a little fiddling to make look the part, as they’re not as giving as cloth belts, but once glued in place, they will certainly stand out.
Masks (JX207) - To complement the sets mentioned above, Eduard have also released a set of paint masks for the F4U-1D, which helps masking the clear areas a whole lot easier.
Conclusion
As with most of Eduards releases there are questions as to why some sets are so comprehensive yet still missing vital parts that are held back to make up other smaller sets. I suppose it does give the modeller more options on how much detail they wish to add, but is still quite annoying. The quality of these sets is superb, and will certainly help to the making of a super detailed model.
Review samples courtesy of
