2996 Victor Posted September 22, 2020 Share Posted September 22, 2020 3 hours ago, CedB said: IPA India Pale Ale? Really??? Does it provide a tack coat so the colour sticks better? Hat, coat, keys..... 2 Link to comment Share on other sites More sharing options...
dogsbody Posted September 22, 2020 Author Share Posted September 22, 2020 9 hours ago, CedB said: Nice work on the DE Chris - looks smooth to me Empty jars are weird eh? I guess Dennis has it right and someone is dipping into the pots, otherwise they wouldn't have the reputation they do? Who knows… The paint lifting is a pain. I had a quick look back through the thread and couldn't see if you primed before paint? Did you wipe down the model with cleaner? I usually wipe mine over with IPA (fnaar!) to remove any finger grease before I prime. HTH Thanks, Ced. It is a semi-gloss paint, so it's a bit shiny. Should be good to put decals onto. I didn't prime, but I did wipe the surfaces down with 99% IPA ( not the beer! That would be sacrilege ) before painting. The paint didn't lift, but the Tamiya tape on the starboard leading edge has a little bit. I've left it for now as I didn't fancy remasking the whole underside again. I really don't care for that process. I've also been wiping my fingers with the IPA before touching the Hurc. Chris 4 Link to comment Share on other sites More sharing options...
dogsbody Posted September 22, 2020 Author Share Posted September 22, 2020 I've put the AML camo masks on. Damn! That ain't easy. They seem to stick to everything very well except a painted surface. And they are very fiddlly to get into position on curved surfaces. I think next kit, I'll just cut out some tape and use that. I've got a 40mm roll of Tamiya tape on order. I also used a little Mr. Masking Sol to fill in a few spots. I'm just waiting for that to set before I go Dark Green painting. I can see some brushwork with a small pointed brush in the near future Chris 5 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted September 22, 2020 Share Posted September 22, 2020 5 minutes ago, dogsbody said: I've got a 40mm roll of Tamiya tape on order. I use that to for big/medium jobs. It can be a bit finicky when trying to get it off the roll, it likes to tear in length wise strips. Also I de-tack tape on the outside of my hand before I use it. That way it still stick to the model but just barely. I have almost never had a paint lift when doing this. 1 Link to comment Share on other sites More sharing options...
dogsbody Posted September 22, 2020 Author Share Posted September 22, 2020 It's gone all green! So, the DG has been sprayed. Looks like it came out okay. There was aa intensely, heavy pucker moment, when turning the mounting stick, It almost slipped out my fingers. I swore. Loudly. I'll leave that to dry a bit more while I have my afternoon coffee. I was thinking of something stronger and distilled, but Mrs. DB gave me that look, so I chose coffee. Chris 6 Link to comment Share on other sites More sharing options...
dogsbody Posted September 23, 2020 Author Share Posted September 23, 2020 Masking removed. Not as good as I hoped for, but better than expected. I should have done the green in at least 2 coats, as it's a bit thick in places. I also should have let it sit longer. I left a thumb print on the starboard rear fuselage. These's one spot of overspray/ masking leakage. The Mr.Masking Sol also took some of the shine off of the brown. The painters tape lifted a bit off the aluminum, but nothing too bad. There's also some missed areas on the wing leading edge. I'll have to do some pondering, to figure out how to fix these rookie mistakes, if I can. Now the visual proof: Critiques welcomed and expected. Chris 14 Link to comment Share on other sites More sharing options...
AdrianMF Posted September 23, 2020 Share Posted September 23, 2020 👍👍👍👍👍👍 Love it! The thumb print and the ridges will disappear under a couple of passes with a fine sanding stick (and the thumbprint will probably be covered by your decals anyway) and the other booboos can be touched up with a brush if they bother you. At the leading edge wing roots it looks to some extent as though the masking tape has gone where its shape drove it instead of where you wanted it to go. Next time you could maybe mask in two stages round those areas in two stages: once with a thin strip (2mm?), made by slicing up a piece of standard tape, which you can take exactly into the corners with tweezers and see where it is; then with a wider strip that overlaps the thin strip to take care of overspray. That’s what I do, although I brush paint so I have no overspray (normally!). I think it looks great. Do another one quick before you forget that you can do it! Regards, Adrian 2 Link to comment Share on other sites More sharing options...
Hamden Posted September 23, 2020 Share Posted September 23, 2020 Thats a great result Chris nothing wrong with your spraying at all Roger 2 Link to comment Share on other sites More sharing options...
dogsbody Posted September 23, 2020 Author Share Posted September 23, 2020 8 hours ago, AdrianMF said: (and the thumbprint will probably be covered by your decals anyway) and the other booboos can be touched up with a brush if they bother you. There were no squadron codes on the RCAF's early Hurcs. I'm going to wait for the paint to fully dry, then I'll try your suggestions. Chris 5 Link to comment Share on other sites More sharing options...
alt-92 Posted September 23, 2020 Share Posted September 23, 2020 It's not you I've used AML masks before, my main bugbear is getting the overlaps 'right'. Always needed some touch-ups, but that's where the Tamiya tape and blu/white-tack comes in (and of course thin coats at low pressure), to fix the small overspray/not-quite-straight lines. One thing I have learned is to spray away from the edge of the masks. That largely avoids the issue of paint ridges, but as @AdrianMF says: light sanding with a very fine grit will remove those. 2 Link to comment Share on other sites More sharing options...
dogsbody Posted September 23, 2020 Author Share Posted September 23, 2020 1 hour ago, alt-92 said: It's not you I've used AML masks before, my main bugbear is getting the overlaps 'right'. Always needed some touch-ups, but that's where the Tamiya tape and blu/white-tack comes in (and of course thin coats at low pressure), to fix the small overspray/not-quite-straight lines. One thing I have learned is to spray away from the edge of the masks. That largely avoids the issue of paint ridges, but as @AdrianMF says: light sanding with a very fine grit will remove those. I've got some brand-new unopened Squadron sanding sticks, like these, that I'll use on those ridges. Now, with afterthought, I should have used some Blu-tac on those spots yesterday, instead of the Masking-Sol. I probably should have used it for other spots instead of tape. When I sprayed, I didn't spray away from the tape. I just held the model up by the stick in the nose and just tried to spray straight onto it. After slopping paint out of the airbrush cup a few times, I've learned to keep it at a more horizontal level. I've also learned to wear some old pants. Chris 2 Link to comment Share on other sites More sharing options...
bigbadbadge Posted September 23, 2020 Share Posted September 23, 2020 Lpoks good to me, the thought of Airbrushing still scares me, congrats on your airbrushing though. Chris 2 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted September 23, 2020 Share Posted September 23, 2020 1 hour ago, dogsbody said: After slopping paint out of the airbrush cup a few times, I've learned to keep it at a more horizontal level. I've also learned to wear some old pants. After wearing paint a few times we all figure that out. 2 Link to comment Share on other sites More sharing options...
jackroadkill Posted September 23, 2020 Share Posted September 23, 2020 Hey Chris, She's coming on really well. I just wish my painting errors looked as good as yours.... 2 Link to comment Share on other sites More sharing options...
dogsbody Posted September 23, 2020 Author Share Posted September 23, 2020 20 minutes ago, jackroadkill said: Hey Chris, She's coming on really well. I just wish my painting errors looked as good as yours.... Stop it! I'm blushing! Either that or the beer and rum have finally given me old rummy-face. Chris 2 1 Link to comment Share on other sites More sharing options...
AdrianMF Posted September 24, 2020 Share Posted September 24, 2020 Looking at the picture of the RCAF early Hurricane and your leading edge wing roots has set me thinking about the upper/lower camouflage border around that spot. There seems to be an infinite variety of them, almost different in every photo I look at. More details to worry about! Looking forward to seeing more progress - dare we hope for an RFI in 2020? Regards, Adrian 1 Link to comment Share on other sites More sharing options...
Marklo Posted September 24, 2020 Share Posted September 24, 2020 Some polishing and some careful retouching and it will be fine. Happens all the time. 1 Link to comment Share on other sites More sharing options...
dogsbody Posted September 24, 2020 Author Share Posted September 24, 2020 2 hours ago, AdrianMF said: Looking at the picture of the RCAF early Hurricane and your leading edge wing roots has set me thinking about the upper/lower camouflage border around that spot. There seems to be an infinite variety of them, almost different in every photo I look at. More details to worry about! Looking forward to seeing more progress - dare we hope for an RFI in 2020? Regards, Adrian I'm not making any promises. After the paint gets fixed ( if I can ) there's still decaling and then clear coating. After that, it's adding the undercarriage, pitot and canopies. Crap! I just remembered I haven't painted any of the undercarriage yet. Hey, I did say at the start that my speed would be glacial. Chris 4 Link to comment Share on other sites More sharing options...
CedB Posted September 24, 2020 Share Posted September 24, 2020 Great stuff Chris - I think we've all made similar mistakes while getting the hang of airbrushing so good work! 2 Link to comment Share on other sites More sharing options...
dogsbody Posted September 24, 2020 Author Share Posted September 24, 2020 Thanks, Ced. Chris 1 Link to comment Share on other sites More sharing options...
dogsbody Posted September 27, 2020 Author Share Posted September 27, 2020 While looking at my sanding supplies, I found these two packs of Flex-i-grit sheets. Some of these are quite fine, too. They may be useful when I try to remove the paint ridges. If I get the time to go downstairs to do anything! The missus has been a bit off with a bit of a cold ( it's not Covid ), so she keeps getting me to do/fetch things. It's been a right pain in the nether regions! Chris 4 Link to comment Share on other sites More sharing options...
fubar57 Posted September 27, 2020 Share Posted September 27, 2020 On 21/09/2020 at 17:36, dogsbody said: I've already found a place in Ontario that has Mr. Hobby Aqueous paints. The paint colour numbers match the Aqueous paints I have. Maybe tomorrow, I'll order some. Chris Looking good Chris. Let me know how that Ontario thang works out. I tried Sunward and their "free" shipping but in the end, the "free" shipping doesn't include my area. I found a place in Japan that is cheaper than Canada, shipping included but we need our dollar to get up to $.80US. If I remember it worked out to under $3.00CAN per bottle, shipping included Link to comment Share on other sites More sharing options...
dogsbody Posted September 27, 2020 Author Share Posted September 27, 2020 47 minutes ago, fubar57 said: Looking good Chris. Let me know how that Ontario thang works out. I tried Sunward and their "free" shipping but in the end, the "free" shipping doesn't include my area. I found a place in Japan that is cheaper than Canada, shipping included but we need our dollar to get up to $.80US. If I remember it worked out to under $3.00CAN per bottle, shipping included According to the tracking number, it should be here by Wednesday. Yeah, the shipping was a bit much. My order came to $47 and change, but the shipping is over $21.00. Oh well, such is life on The Backside of Beyond! I used this place just because it was the first Canadian site that had Mr. Hobby and Mr. Color paints. There may be something closer, I just didn't look. Chris 1 Link to comment Share on other sites More sharing options...
dogsbody Posted September 27, 2020 Author Share Posted September 27, 2020 A wee update for those who have nothing better to do than to follow this glacially slow build. I started to sand down the paint ridges, trying to be gentle. One ridge on the rudder was hard to get at with the sanding stick. I then had a rush of fecal matter to the brain! I took a round wooden toothpick and cut off one end at an angle. I used that to rub the paint ridge and it almost totally disappeared. I then went over the rest of the ridges and smoothed them out. I then had another brain rush. I realized that I'm getting too tensed up and fretful about this build. This is the closest I've come to completing anything in well over 35 years. If it ain't perfect, so what! Chill out. I also realized that I'm looking at my Hurc with magnifiers on over my glasses. If a gnat had relieved itself on the wing, I could see it. At normal viewing distance, most of the flaws I can see would't show. Besides all of you gentlefolk here on this forum, probably no one else will ever see it. So, after my coffee and cookies, I'm going to go back and try to fix some of the other paint mistakes with a fine brush and thinned paint. Chris 7 Link to comment Share on other sites More sharing options...
CedB Posted September 28, 2020 Share Posted September 28, 2020 7 hours ago, dogsbody said: I realized that I'm getting too tensed up and fretful about this build. This is the closest I've come to completing anything in well over 35 years. If it ain't perfect, so what! Chill out. Good plan Chris - she's looking good from here! 2 Link to comment Share on other sites More sharing options...
