Julien Posted January 22, 2018 Share Posted January 22, 2018 Bundeswehr German Military Present Day1:35 Master Box Ltd Master Box have seen a market for some well-sculpted, modern mouldings of soldiers for a while now. While WWI and WWII have seen a lot of figure sets recently it seems companies are now catching on with the meed for modern day figures. Master Box have now brought this set out for modern day German Army figures. This set arrives in the de facto standard figure shaped box with a painting of the included figures on the front, and parts breakdown with pictorial instructions on the rear. On opening the end of the box, you're greeted by a re-sealable bag containing one large sprue and one smaller one containing all the parts you'll need to build five figures in fairly relaxed non-combat stances. Contrary to the sprue photos on the back of the box, the styrene is grey, which shows off the contours and captures all the detail that has been included in the kit. Torsos, legs, arms and heads are all separate parts, with webbing also separate for a more realistic in-scale feel, with helmets, weapons and load-out also separate, which gives the modeller some scope for individualising each figure without too much work. The sculpting is first rate, and the sheer detail of each part is stunning, from the smallest pucker in the corner of a bag to belts that cut into the shoulder, plus realistic clothing. Painting shows modern temperate camo, and the dessert camo as worn in the controversial deployment of German troops to Afgahnistan. Conclusion Master Box have a superb range of figures, and this set is both timely and very well done. If you want to add a sense of scale to your modern armour, this set will do just that. A much needed boost for fans of modern German armour. Very highly recommended. Review sample courtesy of 1 Link to comment Share on other sites More sharing options...
