Max Headroom Posted March 25, 2018 Author Share Posted March 25, 2018 @stever219 thanks for looking in. Yes indeed that is an early pre A4 sized and now yellowing copy of Scale Aircraft Modelling. This afternoon I came across an article by Alan Hall converting Frog’s F.4 into a T.7 using balsa wood, dope and talcum powder! It was another age Thanks too for the heads up on the undercarriage. I had a vague recollection of something like that. As for the bang seat position, I may have to leave the ‘ole as is, because there are a load of screws jammed in with Milliput as ballast! Regards Trevor 2 Link to comment Share on other sites More sharing options...
Max Headroom Posted March 30, 2018 Author Share Posted March 30, 2018 No progress during the week, but I picked up the brush this afternoon and have been giving a further coat of dark green and it now looks a lot less olive than before. Amazing what a really good stir will achieve! Ober the next couple of days I’ll apply the PRU Blue and tackle the vac form canopy (yipes....at least I’ve got two goes). Following that I will treat myself to the application of the transfers before finally giving it its legs. Then I have to start that Firefly!! Trevor 2 Link to comment Share on other sites More sharing options...
Max Headroom Posted March 31, 2018 Author Share Posted March 31, 2018 So today I cracked open that new pot of Humbrol acrylic 230 PRU Blue. Set absolutely solid. What a swizz Luckily I had an old time of 230 in enamel. I opened that and it was still good - thank goodness. So I used that with the first coat (yes modern enamels also need multiple coats......). This is where I am at the mo. I suppose I need 24 hours for it to dry properly? Better get cracking with the legs. Trevor 3 Link to comment Share on other sites More sharing options...
Max Headroom Posted March 31, 2018 Author Share Posted March 31, 2018 I think this model is beginning to test me..... Silent shrug and carry on. Trevor 5 Link to comment Share on other sites More sharing options...
zebra Posted April 2, 2018 Share Posted April 2, 2018 On 01/04/2018 at 1:38 AM, Max Headroom said: I think this model is beginning to test me..... Silent shrug and carry on. Trevor Only just beginning to test you? Some of us would have put this on the shelf of doom a while ago! 1 Link to comment Share on other sites More sharing options...
Max Headroom Posted April 2, 2018 Author Share Posted April 2, 2018 6 minutes ago, zebra said: Only just beginning to test you? Some of us would have put this on the shelf of doom a while ago! I can see the finishing line and I’m darned if I’m giving up now! Trevor 3 Link to comment Share on other sites More sharing options...
Max Headroom Posted April 8, 2018 Author Share Posted April 8, 2018 Just a couple of (bad!) photos to show that this one is progressing. There is the inevitable touching up to do, but hopefully it’s all plain sailing from here. Trevor 5 Link to comment Share on other sites More sharing options...
Max Headroom Posted April 22, 2018 Author Share Posted April 22, 2018 Right then, sorry for the hiatus but there was a lack of mojo and family life occurring, but hopefully the impending deadline will now spur me on. So where was I? The undercarriage. Tell you what, I’ll come back to that later, because it’s time for me to have some fun and to give this model it’s identity. Here we go My chosen muse is WH573 ‘G-A’ of 541 Squadron. Most of the serial can be cobbled together from the kit options, as all I need is an ‘H’ from the spares box and yes I’ve got that covered. Squadron codes are also available. As for the tail flash, all I needed was one which was split in half and a triangle cut off the red part. Warning triangles are courtesy of a Fujimi RAF Phantom. Fuselage roundels are from a FROG Sea Vixen. Here is where I am now... If you look closely there is some white showing around the blue of the fuselage roundel. That’ll need a touch-up. I was going to add the wing walkway markings, but the transfer glue became a yellow gunk and as soon as I tried to remove it, the transfer wrapped up over itself. So this won’t have any...... This has given me the impetus to continue though! Trevor 5 Link to comment Share on other sites More sharing options...
Black Knight Posted April 22, 2018 Share Posted April 22, 2018 I have in my decals files a few sheets of coloured lines by Xtradecal. They do the lines in various widths and the black are good for walkway lines, the red lines for warning lines etcetera Another source of black lines are the ones printed on the edges of decal sheets or printed there to separate the markings of different schemes. You probably have plenty without realising it The wing walkway lines on this Meteor 4 were done a line at a time using the Xtradecal lines 3 1 Link to comment Share on other sites More sharing options...
Max Headroom Posted April 23, 2018 Author Share Posted April 23, 2018 Thanks BN! I have stripes on sheets as you say and even strips of Kemco ‘pressfix’ ones, where you stick the line face down then wet the backing sheet and then peel away. I might do that, but the priority now is pushing it over the finishing line. Trevor Link to comment Share on other sites More sharing options...
Max Headroom Posted April 29, 2018 Author Share Posted April 29, 2018 Minor update. Mostly touching up on the camouflage and trying to get rid of the white marks on the edge of the fuselage roundels. I have also painted the nosewheel ‘wheel well’ black to give an impression of depth and the main ones silver. To be honest there’s not much to see so no pix at the moment. Ive come across a problem though. Careful study of the vac form transparency shows that my option, the one with the metal rear end, is deformed slightly, so I’ve one go at this but adapting the fully blown canopy. Unless someone has a spare MPM canopy??? Trevor Link to comment Share on other sites More sharing options...
Black Knight Posted April 29, 2018 Share Posted April 29, 2018 Let me check; I've three of the MPM/Xtrakit/Airfix F8 kits. Each has two canopies. I'll check on what I need. edit; having checked; I need all three solid back canopies However; I can find no difference is size and shape between the two types of canopy. The only difference on the MPM is that the solid rear canopy has this part slightly raised and the full blown type has a canopy frame line where it should be. Thus I would suggest; sanding off the frame line on a full blown type and just painting the rear section I can let you have a full blown type if you want it. The plastic, whilst nicely thin, is thicker than a vac one, and less likely to turn yellow-brown 1 Link to comment Share on other sites More sharing options...
Max Headroom Posted May 2, 2018 Author Share Posted May 2, 2018 Hi @Black Knight I’ve only just come across this and thanks for the offer. I’ll grit my teeth and adapt the full blown canopy and with careful masking see if I get away with it...... Fingers crossed 😱 Trevor Link to comment Share on other sites More sharing options...
Max Headroom Posted May 13, 2018 Author Share Posted May 13, 2018 Better get a jiggy on..... Trevor Link to comment Share on other sites More sharing options...
Max Headroom Posted May 13, 2018 Author Share Posted May 13, 2018 So then sit rep time. First order of the day was to remove the masking from the cockpit and nacelles. Allie approves! Easy things first. I gave it the serial number. Next was the undercarriage. As you may remember one wheel was damaged I found an unused thingummy on the sprues to replace the missing bit. In order to give the leg more grip I routed a hole in the wheel well roof. But I did a stupid Soft lad here hadn’t realised that the wheel well roof was part of the upper wing surface 🤪 It’s a Cat 3c repair. My tame miniature ground crew will effect an emergency repair...... I now have it standing on its legs though! It’s most definitely not a tail sitter Trevor .......more later 3 Link to comment Share on other sites More sharing options...
Max Headroom Posted May 13, 2018 Author Share Posted May 13, 2018 Apart from painting the canopy and the drop tanks this is done. Final instalment later! Trevor 3 Link to comment Share on other sites More sharing options...
Max Headroom Posted May 13, 2018 Author Share Posted May 13, 2018 AND IT’S FINISHED! Bit of a rush and frankly not my best, but at least I have a single seat Meatbox to keep my NF.13 company. Enough words, here’s the finished article. Finally, here is the NF.13 I built when the kit first came out for comparison. Thanks to all for looking in and giving advice and encouragement. Now for the RFI. Trevor 5 Link to comment Share on other sites More sharing options...
John Masters Posted May 13, 2018 Share Posted May 13, 2018 Looks good Trevor! 1 Link to comment Share on other sites More sharing options...
zebra Posted May 13, 2018 Share Posted May 13, 2018 Looks great. Well worth all the effort you’ve put in! 1 Link to comment Share on other sites More sharing options...
Black Knight Posted May 13, 2018 Share Posted May 13, 2018 Really very most excellent 1 Link to comment Share on other sites More sharing options...
CliffB Posted May 15, 2018 Share Posted May 15, 2018 Mission accomplished, I'd say. 1 Link to comment Share on other sites More sharing options...
Max Headroom Posted May 15, 2018 Author Share Posted May 15, 2018 Thanks guys! When posing the photos I noticed that the 10 is considerably heavier to avoid tail sitting! Trevor 1 Link to comment Share on other sites More sharing options...
