Gardner95x Posted January 16, 2018 Share Posted January 16, 2018 Hi all, Anyone know who makes the best 1/32 Stuka kit in terms of quality/accuracy? Link to comment Share on other sites More sharing options...
Work In Progress Posted January 17, 2018 Share Posted January 17, 2018 It's really simple because there's no serious overlap in the ranges available. If you want an A, B or R (the early models) then it has to be Trumpeter. If you want a D/G the t has to be Hasegawa. Avoid the ancient Revell kit. Link to comment Share on other sites More sharing options...
Troffa Posted January 17, 2018 Share Posted January 17, 2018 Although Revell did issue a rebox of the Hasegawa Ju87D as kit 04711 around 10 years ago- might be a cheaper option (if you can find it) https://www.scalemates.com/kits/105521-revell-04711-junkers-ju-87d-stuka 1 Link to comment Share on other sites More sharing options...
fernandocouto Posted January 18, 2018 Share Posted January 18, 2018 5 hours ago, Work In Progress said: It's really simple because there's no serious overlap in the ranges available. If you want an A, B or R (the early models) then it has to be Trumpeter. If you want a D/G the t has to be Hasegawa. Avoid the ancient Revell kit. Right these are only choice. However trumsh*ter's kit has some incorrect issues. Even had been discovered before release but they just keep it cause correcting mould cost a lot Link to comment Share on other sites More sharing options...
VMA131Marine Posted January 18, 2018 Share Posted January 18, 2018 Trumpeter also does the D and G in 1/32. The Hasegawa is more accurate but has less detail. Link to comment Share on other sites More sharing options...
