M7 Priest Academy 1/35 ****FINISHED****
AndrewE
For my second build I am going to stay with the artillery and build an Academy 1/35th M7 Priest.
I shall be using the T29 track that I discarded from my M12 build as I have found a number of pictures of Priests with this type of track.  Stowage will mostly be from the spares box and scratch build.
39680415841_b7f52bc032_b.jpgM7 Priest 01
25808476658_41173b75f9_b.jpgM7 Priest 02
38783862165_50d49ab831_b.jpgKbTTbllWtfUEPY6DdXXEIkuVITy3T_CA2bq6XdtyJX8
  • Like 10
To help with all the baggage I need to add for this build I have purchased the Black Dog resin set for the Priest.  It is designed for a British one as evidenced by the steel helmets but apart from them I think all will look OK on the US version I shall be building.
I made a start last night by removing all of the suspension components from the sprues, hopefully I will get a chance to clean them all up later today, this is the part I dislike most about AFV builds so I like to get it out of the way as quickly as possible.
33 minutes ago, AndrewE said:
Yes, me too, having just done the 40 wheels for my Sherman build, followed by the ones on the Cruiser tank A10 in the 10th Anniversary GB.
Love Black Dog's stuff though. It has such great detail.
John.
Sorry, I have not been very good at posting updates on this build.  I have now just about completed construction into the major components ready for priming and painting.  The Black Box resin stowage has been attached to the rear decking only.  The large resin stowage piece for the front will go on once the hull is together.
The additional armour protection is cut from plastic sheet and I have used stretched sprue and lots of liquid glue to make the weld join.
  • 1 month later...
It has been rather a long time since my last update on this build unfortunately. February and the first half of March were not very productive on the modelling front for me due to work commitments and several trips abroad but I did manage to keep things ticking over and have made lots of progress in the last couple of days.
Not many photos I'm afraid but since my last post I have painted the interior and gun assemblies, added the wheels and tracks (which needed to be shortened by one link either side), attached the top half of the hull and remaining stowage to the front and painted the stowage, exterior etc.
Just needs some matt varnish and weathering now and although I am going away for a couple off days this week I will be back in time to finish everything off before next Sundays deadline.
Just finished the Priest this afternoon. It took a couple of matt coats, firstly Tamiya Flat and then Alclad Klear Kote Matte to get a nice flat finish.
I will take more pictures for the gallery tomorrow in some better light.
It took much longer than I had hoped to complete this but I am very pleased with the result.  Just a shame I have no time before the end of the GB to do an M10.
That really is excellent Andrew, The stowage and ammo really make it look busy and take it to the next level! Very well done. :worthy:
Kind regards,
Stix
  • 1 year later...
Hi ,just found your build on the interweb as i am just about to start this kit ,it turned out very nice ,but what are the bits in the back of the tank for ?
I am guessing it is there to stop the front end dipping downwards ,it that correct?
Hi,  if you are referring to the bits of broken stone I have fixed inside the hull this is just to give the model a bit of weight.  I don't think the gun (and extra stowage at the front) would affect the sit of the vehicle.  I am not sure what the stuff is made from but they are broken up ring shaped weights that pet shops sell fish tank  weed planted in, helps keep them settled at the bottom of the tank.  I seem to have a never ending supply of them so rather than just throw them away I always put 2 or 3 in every AFV I make to give them some weight. I kid myself that it also helps to keep the bottoms of the tracks flat to the shelf surface but in reality they probably make absolutely no difference.
  • 2 years later...
just coming up to my stowage on the Priest I am building, going to steal this photo for the rear deck... will have to make it all from scratch or stowage I have, but at least I dont have to use the crappy "mesh" boxes
