Cookenbacher Posted February 1, 2018 Share Posted February 1, 2018 It's looking like a Vc Trevor! @Procopius recommended these masks, and I haven't looked back. 1 Link to comment Share on other sites More sharing options...
Max Headroom Posted February 1, 2018 Author Share Posted February 1, 2018 @Cookenbacher Thanks for the thumbs up. Hopefully over the weekend it will get its personality! Those templates look interesting but I’m not sure my domestic printer will work in fractions of a percent! Onwards and upwards! Trevor Link to comment Share on other sites More sharing options...
Paul J Posted February 1, 2018 Share Posted February 1, 2018 Definitely seen a photo of a MkV in Turkish markings! It was in an Ian Allan book by Ted Hooton . Spitfire Special it was called. Thin hardback book came out in the 1970's. Colour pic on cover of well known image with ZD code. But black and white pics inside with some colour art of badges etc. I do believe , if I recall right, the pic showed it from port rear three quarter view and I think there was one of a Spit flying alongside a Turkish FW190A!!!! I checkd the image against the caption and sure enough you can see 3 stub exhaust and 3 blade prop with that 'pointy rudder'!!! I would scan post pic of it here but don't have the book any more. 1 Link to comment Share on other sites More sharing options...
Max Headroom Posted February 1, 2018 Author Share Posted February 1, 2018 @Paul J You have described the same photo as in the Squadron Signal book. The photo originates from the Turkish Air Force and the caption says that it was parked in a dump of abandoned aircraft post war. Trevor Link to comment Share on other sites More sharing options...
johnd Posted February 1, 2018 Share Posted February 1, 2018 Are these the ones you meant? John. 1 1 Link to comment Share on other sites More sharing options...
Graham Boak Posted February 1, 2018 Share Posted February 1, 2018 When the Airfix Mk.Vc appeared in my hands, after some disappointment and critical language I corrected the aileron, sharpened the trailing edges and thinned down the wing from the inside, taking most of it off the leading edge. I should have fitted a new canopy, but didn't. I would not recommend this approach this now, with alternatives fairly readily available, but to be honest it seems like much less work than you are putting yourself through, especially without short cuts such as a new canopy from Squadron/Falcon. Link to comment Share on other sites More sharing options...
Max Headroom Posted February 1, 2018 Author Share Posted February 1, 2018 @johnd that second photo is the one I’ve seen before. @Graham Boak the inspiration for this build was the free Spitfire with the Daily Mail and seeing what I could do with it and my spares box. I’m essentially getting a ‘free’ Vc out of this. I obtained a second freebie at the same time and that I’ve earmarked as an early PR variant. I have a 30 year old Almark sheet at the ready......! Trevor 1 Link to comment Share on other sites More sharing options...
Paul J Posted February 1, 2018 Share Posted February 1, 2018 19 minutes ago, johnd said: Are these the ones you meant? John. Yup!! They're the ones!! Though the top one has the standard rudder by the look of it. 1 Link to comment Share on other sites More sharing options...
Max Headroom Posted February 3, 2018 Author Share Posted February 3, 2018 Little bit of progress this afternoon. First off was the rear glazing. As this is to be finished with an open canopy I’m using the Italeri part. Offered up to position it was two shallow so I tried a shimmy of Slaters Rod. Still too shallow, but a second layer cured that problem. All fixed in with Contacta Clear. Next was to prep the Sky band and yellow wing leading edge, the latter undercoated with white. The Sky was sufficiently dense not to need this. So this is where I am at the moment. A gentle smoothing out with micromesh, they will then be masked off and I will apply the Medium Sea Grey with a rattlecan and then have a play with the camouflage template, before the Dark Green is deployed. More soon. Trevor 5 Link to comment Share on other sites More sharing options...
Max Headroom Posted February 3, 2018 Author Share Posted February 3, 2018 ......and this is what it looks like with a coat of Dark Sea Grey over the top. I’ll let that harden overnight and then tackle the stencil for the Dark Green camouflage. Thanks for looking. Trevor 4 Link to comment Share on other sites More sharing options...
Max Headroom Posted February 3, 2018 Author Share Posted February 3, 2018 I’ve done a stupid haven’t I? Its Ocean Grey on top........ I’ll leave it overnight, give it a light rub and then have another go. Trevor Link to comment Share on other sites More sharing options...
Beard Posted February 3, 2018 Share Posted February 3, 2018 We've all done something like that. On the positive side DSG will make a good undercoat for the Ocean Grey. 1 1 Link to comment Share on other sites More sharing options...
CedB Posted February 3, 2018 Share Posted February 3, 2018 Oops. I'm with Simon - been there too! 1 Link to comment Share on other sites More sharing options...
Max Headroom Posted February 3, 2018 Author Share Posted February 3, 2018 The pain will stop soon. Trevor Link to comment Share on other sites More sharing options...
Max Headroom Posted February 4, 2018 Author Share Posted February 4, 2018 The pain subsided, I gave it a coat of Ocean Grey late last night and then this morning I have mainly been masking. It took a bit longer than I thought it would! Right then, I’m off to the paint shop. Wish me luck........ Trevor 5 Link to comment Share on other sites More sharing options...
Max Headroom Posted February 4, 2018 Author Share Posted February 4, 2018 During......... Trevor 2 Link to comment Share on other sites More sharing options...
Max Headroom Posted February 4, 2018 Author Share Posted February 4, 2018 I couldn’t wait any longer and peeled off all the masking I can see a few areas that need touching up, but overall not too bad. There are also a few places where I need to apply the micromesh to smooth out the ridges. Now for the underside. Thanks for looking. Trevor 4 Link to comment Share on other sites More sharing options...
CedB Posted February 5, 2018 Share Posted February 5, 2018 Nice camo Trevor, good job 1 Link to comment Share on other sites More sharing options...
Cookenbacher Posted February 5, 2018 Share Posted February 5, 2018 Yes, excellent camo work! 1 Link to comment Share on other sites More sharing options...
Max Headroom Posted February 5, 2018 Author Share Posted February 5, 2018 Thanks for the thumbs up guys. Since the above, its had had a varnish coat ready for the transfers. Having a rummage through my spares I found my Sky codes but didn’t have any 18” letters. Never mind, an Xtradecal sheet (which apparently is the old Modeldecal sheet) has been ordered and will be with me midweek. Its getting here! Trevor 2 Link to comment Share on other sites More sharing options...
Beard Posted February 5, 2018 Share Posted February 5, 2018 1 hour ago, Max Headroom said: Its getting [t]here! And looks most excellent. Your work on converting the Airfix MkI is mich to be admired although I'll either be cracking open a Sword one waiting until the AZ/ KP Vc is released later this year. 1 Link to comment Share on other sites More sharing options...
Max Headroom Posted February 6, 2018 Author Share Posted February 6, 2018 I’ve come to the bit I like best - the stickies! The roundels, Czech marking and tail stripe are a rag bag of Italeri and Almark. Looking at the photo in the book above, it’s clear that the Czech marking wasn’t on the starboard side, although from the photos it’s sometimes found on both sides. As I only have the one photo, I have presumed that it’s on the port side, but that’s a safe bet I think. It came from an Almark sheet and if I’m honest it may be a tad large. However it’s the only size I had. Squadron codes are in the post, so that’ll have to wait. One thing I won’t be doing is the serial. Again the photo shows that it wasn’t a standard application (a repaint perhaps?) and was painted on the Sky fuselage band near the top of the fuselage in maybe 4” characters? Whatever, I don’t have anything in the spare transfers box and even if I did, my eyesight, patience and mental stability would all end up being severely tested. So here is where I am at the moment. Some little jobs to do such as the No Walk lines, propeller and mainwheels will be attended to next whilst I wait for my delivery of Squadron codes. Thanks for looking. Trevor 5 Link to comment Share on other sites More sharing options...
Beard Posted February 6, 2018 Share Posted February 6, 2018 I like putting the transfer on too, the model seems to come alive at that point. Your Spitfire is looking most excellent. 1 Link to comment Share on other sites More sharing options...
Max Headroom Posted February 6, 2018 Author Share Posted February 6, 2018 Quick update. I have finally found a picture of EE721 on the interwebby and it’s the same one as in the book. http://s96.photobucket.com/user/bulivyf/media/Spitfire Vb/Mk.Vc EE 721 DUoE V.Smoliacutek -1_zpswxdel9mz.jpg.html Trevor Link to comment Share on other sites More sharing options...
CedB Posted February 7, 2018 Share Posted February 7, 2018 Very nice Trevor, smart! I share your pain with applying individual serials but square, tight edges make it easier. Also photos from a distance! Hope it goes well. 1 1 Link to comment Share on other sites More sharing options...
