It's a HOG! 1/72 Italeri A-10A Thunderbolt II - Completed! Pg.32
giemme
18 hours ago, rob Lyttle said:
Found a picture in a book -(how quaintly old fashioned am I?!)  that might help for ailerons. Showing Red internals.
Only on the initial test aircraft!
Gene K
2 hours ago, massimo said:
Great start Giorgio!!!
I love all the work you've done to match the resin cockpit to the fuselage halves!!!
That cannon housing is simply outstanding!!!:yes:
Cheers Massimo, thank you :thumbsup:
1 hour ago, boom175 said:
31 Years between the Engine shop, Flight line (Crew Chief) and being the base Engine Manager. Still miss working on them!! Any questions you have please ask.
Wow, that's a long time! :thumbsup: I will ask a few questions about painting for the moment, if you don't mind: the kit instructions call for white for the U/C bays and  while looking at walkarounds of the A-10A in Euro 1 scheme, they all look more a light grey to me. Can you shed some light here?
Also, what would be the color for the inside of the retractable ladder bay and for the avionics bay?
TIA
Ciao
TIA
Ciao
When they were Euro one camo, the wheel wells and actually the struts of the landing gear were "ADC Grey" FS 16473. As well as the interior of the ladder door well and the inside of the door itself. All the avionics bays were 16473 same as the inside of the panels.
  • Thanks 3
Excellent, thanks for sharing :thumbsup:
Ciao
Great that you're here "boom", to keep everything in order!! All your time  at Warfield ANG Base
I do have a question (for starters): Where is the transducer that actuates the slats -- the one that the crew chief operates during checks?
Gene K
Edited by Gene K
I have a couple of questions too for those "in the know": what are these sensors on the nose?
76th_tfs_a_10a_nose sensors
and this pod underneath the nose?
A-10-A Nose pod
Looking at various pics, it looks like they are not present together, and I even saw one pic (of an A-10C though) in which both were missing.
The first one I just posted it's of the airframe I'm modelling, but I haven't got a starboard side view to check if that pod was there.
Bottom line, the kit has the pod but not the sensors, so I'm just trying to figure if I only need to add them or I also need to remove the pod.
TIA
Ciao
@giemme ... I believe they're Different radar warning recievers for Sam launches. The block replaced the dot version if im not mistaken ? The eyeball/dot system was created during, and upgraded after Vietnam in the ‘70 s and early’80’s. The block style came on in the ‘80’s or maybe early ‘90’s. I think they've been changed again since the current fracas in the sandboxes has been going on.
Edited by Corsairfoxfouruncle
I'm not really "in the know", but ... AN/ALR-46 .
See this link for a quickie visual (use "translate").  Note the additional antennae for the AN/ALR-64, so depends on the airframe you are modelling as to what is showing. Also some good stuff in this multi part series here as regards other early/late mods.
I'm sure the experts will be able to help!!
Gene K
Gene K
Thanks both :thumbsup:  So, reading through Gene's links, if I want to reproduce a Gulf war era aircraft, it looks like I need to remove both the box radar warning receivers and put the dot ones on the nose and tail.
1 hour ago, rob Lyttle said:
Sorry to be giving you the trivial answer.... they do make great nostrils, don't they?
That plane in the second pic just doesn't look complete!
They do :D And the picture I have of the aircraft I'm modelling shows them, luckily :)
Ciao
Gene K
Yep! Thats where I was! The transducer is just out board of the L/H MLG sponson or "pod" it is pretty small probably 2"X2" its unpainted as it is a heated surface (it comes on when the pilot selects pitot heat )
On 17/01/2018 at 12:36 AM, rob Lyttle said:
Is there any kit or A M version of the ammo loading apparatus that's used to service the monster?
IMG_20180116_233200
It's pretty unique, and would make a great add-on.
PS. I'm sure you've sussed it already, but go maximum with nose- weight. You could well be dealing with the most tail-sitting model airframe of them all.
Flight path do an etch dragon reloaded....
https://www.djparkins.com/product.php?productid=17777&cat=252&page=1
It's 1/48 though.
Brilliant work giemme. I can't wait to see the finished results.
Matt
Edited by S5 modeller
Cheers Matt, thank you :thumbsup:
I don't think I'll attempt a diorama, right now I'm leaning towards a parked aircraft with open canopy, deployed boarding ladder, open avionics bay (but I haven't found a close up pic of that yet) and RBF tags.
Before taking the final decision, however, I still have to investigate the feasibility of moving the moveable parts and finding a crew chief figure - which would also mean I have to think of a suitable base.
:hmmm:
Ciao
Hello all.
I'm a newly registered member here but followed this forum with high interest for a long time as a reading guest.
But now it was time to register here, partly because you giemme started building a project I currently have at my workbench.
(I'm building a unit of the 74th TFS that also took part in Op. Desert Storm).
I have been collecting photos and information about the A-10 und its EL units like crazy.
As I have been following this thread, I have noticed that here and there emerged questions. Or there are infos that could be helpful for a optimum result.
Did you know this resource?
Link
Very important information, because often the infos in books are vague and sometimes they even contradict each other. I believe that this loadout scheme is very credible as it underlines pictures of the real thing:
Link
Look at the bottom of the drawings:
Link
Another important thing:
Compare the color scheme on the Italeri instructions sheet of the unit your are building with the real thing.
Italeri says that these colors will be needed: FS34082, FS36118 and FS34102.
The European 1 scheme on the A-10s consists of FS34092, FS36081 and FS34102.
I don't know if the unit you are building has different colors, but I doubt that.
Edited by Sting67
  • Thanks 2
The avionics bay can also be seen here on picture #23.
As crew chief figures I would take the ones included in Hasegawa's U.S. Aerospace Ground Equipment Set.
I don't know how far you would like to add detail to the Hog, but I got these resin wheels. Although the Italeri wheels are a good representation of the original, they lack of small details like the screws on the wheel wells. That could be fixed with a few rivet decals but all in all the resin wheels are nicer.
I hope this helps.
Edited by Sting67
Link
Link
Link
Sting67, thanks a lot for the boatload of useful info and links, and welcome on board! :thumbsup:  So, if I understand correctly the antennae configuration from your link, this specific airframe (79-0186) should have had the AN/ALR-69 RWR system, i.e. round antennae nose and tail and no boxes.
As for the paint scheme, for some reason I didn't even look at what the instructions say, so the references I have are exactly the same you mentioned: FS34092, FS36081 and FS34102.
That's precisely the one I was looking for! :thumbsup:
On 23/1/2018 at 04:58, Gene K said:
Gene K
Great pics those too, Gene :thumbsup:  They show a lot of interesting details.
How about some progress pics? :coolio:
Actually, I didn't have much workbench time last WE; friends, food, beer, wine ... you got the point. On top of that, the scarce progress led to to more questions.
Tub: I glued in the central PE console, now this is ready for priming
cockpit18
I started working on the IP; the Aires set supplies a printed clear acetate for the gauges, which I painted on the back side with the relevant colors
cockpit19
to obtain this
cockpit20
I then cut out the three PE bits composing the IP and dry fit them in place
cockpit21
I also cut and bend the HUD supporting frame, and here come the questions; first off: should the frame be glued on top of the molded frame highlighted by the red line in next pic, or posed as I did in the very same pic? I can't really tell, from the reference shots I have
cockpit22
Second question: see the top frame circled in green in next pic
cockpit23
Again, looking at reference pics, it looks like there's nothing like that on top of the side frames. What do the experts think?
All comments welcome
TIA
Ciao
Edited by giemme
wrong picture
  • Like 11
5 minutes ago, giemme said:
Sting67, thanks a lot for the boatload of useful info and links, and welcome on board! :thumbsup:  So, if I understand correctly the antennae configuration from your link, this specific airframe (79-0196) should have had the AN/ALR-69 RWR system, i.e. round antennae nose and tail and no boxes.
Thank you very much!
And, yes, looks like you see it right with the antenna configuration.
If you want, I can upload some pics of the old Verlinden A-10 Update set that, unfortunately, is now discontinued but has resin and PE parts to detail the avionics bay as you plan to do.
Also, another bigger detailing set from Aires also includes parts to detail the part of the avionics bay of picture #23 above. The old Verlinden set has a larger section.
(If I find out how to upload images).
See here:
As far as the avionics bay go, the plan is (if I take the decision to represent a parked aircraft - now I'm probably boring you all to death with this un-decision ... :chair: )  to add some detail to the already quite detailed kit's offering. My main concern was about colors of the various parts, but I think your picture sorted it :thumbsup:
Please feel free to post anything you think could be useful for the thread - it's one of the reasons BM is such a great place :wink:
Ciao
Edited by giemme
17 minutes ago, Sting67 said:
Ok, here we are. I hope this helps you as a little source of inspiration.
Great stuff Sting67, thank you :thumbsup:
4 minutes ago, Spookytooth said:
Great start on the office Giemme.
Good to see a lot of ref. pics showing up.
Should help you and others a hell of a lot.
Simon.
Thanks Simon :thumbsup:  Hopefully this can be of help to someone else, I'm already loving this thread a lot :)
cockpit23
BTW, I take this back; going through my ref pics, I saw at least two of them showing the top bridge on the HUD frames, although admittedly of a more recent aircraft. I'm guessing there was some update here too, so now the question is: would this version be correct for a Gulf War era airplane? :confused:
Ciao
I'm still not sure, but it looks weird. Without having checked that I would say that the Gulf War Hogs (the A models) didn't have that.
I don't think this is strictly related to A or C models, as the pics I saw this in are clearly from an A-10A; see here, page 1 for the bridge over the frames, page 2 for the IP, showing the A-10A style instruments.
Ciao
