giemme
It's a HOG! 1/72 Italeri A-10A Thunderbolt II
Hi everybody;
I don't think the subject needs any introduction, as it's a well known aircraft. Slightly out of my normal interests (which are mainly fighters or fighter/bombers), it is also the type my friend and fellow BMer @Gene K flew in the second part of his career.
So let's see: the kit
dav
aftermarkets that I'll be using
dav
and the specific aircraft I'm modelling
dav
Which corresponds to this, in real life (pic from https://f16crewchief.deviantart.com/art
76th TFS A-10A No. 1
BTW, does anybody know where to find more pics of this specific airframe? This one seems to be the only one showing up on Internet.
Anyway, I started with a dryfit of the major parts: nose wheel bay
dav
and fuselage
dav
some panel lines not lining up very well in the nose
dav
and underneath
dav
A bit of a gap in the nose U/C bay area too
dav
Port top wing has some moulding defects at the root
dav
and on the outer edge
dav
which not surprisingly led to a bad alignment, when mated with the bottom section
dav
dav
Starboard wing looks much better
dav
dav
test fitting with fuselage
dav
The root joins look better once you apply a little pressure to set the correct dihedral
dav
dav
At this point, I decided to check the fit of the lovely Aires resin tub
dav
which sports a very restrained casting block and a slot to be paired with the inside of the retractable ladder bay
dav
In order to fit it into the fuselage, the areas marked with a red pen need to go
dav
The IP coaming needs to be removed too, because there's a resin part for that too, but later for that.
The kit cockpit mounting tabs need to go as well
dav
so after some scraping with a ball pointed Dremel tool and some cutting with a knife, I got here
dav
This way, the inner part of the ladder bay fits into the tub slot. As for the rest:
dav
Still a loooong way to go .... :frantic:
Comments, hint, tips, suggestions, critiques - all welcome
Ciao
Edited by giemme
Bit of info that might help you...
http://www.aerialvisuals.ca/AirframeDossier.php?Serial=161345
http://www.airport-data.com/aircraft/photo/000073175.html
http://www.2951clss-gulfwar.com/piwigo/index.php?/category/1  (LOADS HERE)
http://warthognews.blogspot.co.uk/2011/10/10c-80-0186-caught-at-d-m.html
good luck with the build, I'll be tacking a current spec A-10C in 1/72 at some time I'd be interested to see how this kit shapes up
PhilB
Edited by philbrad
Welcome back!!!
Let's see what you can do with this one!!!;)
Wrong scale for me, but I'll tag along if I may in the hope of picking up some tips.
John
PhilB
Great! :thumbsup: Thanks a lot, PhilB - I must warn you, though: I'm not the quickest of modellers around here (quite the opposite, in fact :banghead: )
On 10/1/2018 at 17:51, massimo said:
Welcome back!!!
Thanks Massimo, great to have you on board :thumbsup:
John
Wrong scale for me too, John ... :D Nonetheless, I'll try my best :wink:
Ciao
Edited by giemme
Ciao
Pleasure, happy to help. I've got a Airfix F-4, Academy F-15E and a Revell F-16CJ to attend to yet. A-10 is on the 'want to do' list.
Looking at your dry-fit I can see some fit problems with the Italeri offering. Nose fit looks a bit of a flaky. Surprised the Aires resin needs fuselage correction to fit. Only usually found this trying to fit their resin in manufacturers they aren't intended for (as with my Academy F-15E)
PhilB
Thanks PhilB; it's my first time with Aires resin, but from what I've read from other reputable modellers on here, the fit problems can happen also when used for intended kits. Not a big deal though, just some extra patience and TLC needed :wink:
Ciao
Glad you've got another build on the go Giorgio, pulling up a seat.
I can't wait to see the European 1 scheme, much cooler than the current grey in my opinion. Growing up, I got to see lots of green A-10's in Alaska.
Cool :thumbsup:  Welcome on board, Cookie!
You grew up in Alaska? Man, you are one for though climates, aren't you?
... but you actually know you'll have to wait quite some time, because of my snail pace, don't you? :whistle:  :wink:  :D
Ciao
A lot of progress for a snail -- looks like you're going full steam ahead, Giorgio!! I've pulled up my chair to witness what glory you'll bring to this beautiful airplane,
in the perfect scale.:penguin:
Gene K
:D
Great to have you on board, Gene :thumbsup:
Since I won't be getting any bench time till next WE, have you got any trivia you want to share about your time on the A-10? :)
Ciao
 ... have you got any trivia you want to share about your time on the A-10?
Trivia -- the early batches of the Hog (1981) had a manual Inertial Navigation System -- a fold out map the pilot constructed with scissors, tape, clear sticker paper, and a grease pencil!  The grease pencil also pulled duty while airborne, being used to make notes on the inside of the  canopy, and  some used it to mark dive angels for rolling in.
:phew:
Gene K
Edited by Gene K
OK, G, I'm here, & I've brought :pizza:and :popcorn:, who's brought the :drink:
Looking forward to this one, a Hog in Euro one in the One True Scale - what's not to like?!
Keith
Yep, another one sneaking in at the back here, always liked the A-10 :popcorn:
:phew:
Gene K
That sounds dangerous when done driving a car. I can't imagine when flying low level with a jet built around a huge gun ... :frantic::D
Keith
I've got beer, K! Welcome on board :thumbsup:
Cheers 06/24, welcome to you too :thumbsup:
Ciao
Hi Giorgio!
Glad I found this thread right in the beginning of the build work! It will certainly be another one of your masterpieces and it's a kit I've been eyeing for some time, so I'll be following your work if you don't mind!
Jaime
I certainly don't mind, Jaime! Welcome on board :thumbsup:
Ciao
I am here Giemme, dragging up a seat if I may.
And Keef, I got some beers :drink:.
I have got the Revell 1/48 version stashed away somewhere, I know a different scale but be interesting to see how they compare.
Simon.
Welcome to you too, Simon :thumbsup:
Ciao
This is definitely not my subject area, but as it's you, I'll be sure to follow along. Nice start, but it looks as though you have a long road ahead......
Ian
Cheers Ian, welcome on board :thumbsup:
Nothing new then, right? :rofl::rofl:
Ciao
I built an early issue of this kit very nearly 20 years ago now:
OOB, except for Equipage wheels and Astra decals....
....I still have the model - sitting in a box in the shed!
Watching with great interest as I'll be starting the same kit for the Britmodeller 10 Aniversary GB.
Mine will be OOB.
Great to see photos of Andy's model, which look suspiciously like the magazine article I'm reading.
Is that model airbrushed - it looks great?
If the article's in SAM Vol 20 No.9....
....brush-painted - tried an air-brush once, didn't get on with it....
Magnificent! :clap: Welcome on board, Andy :thumbsup:
One question, if I may: I see you modelled your A-10 with the split ailerons, to act as speed brakes. Is this a possible configuration for a parked aircraft? The kit allows for this option, but I couldn't find, from a first quick search, any pictures of airplanes with this feature deployed. TIA
Mine will be OOB.
Welcome to you too :thumbsup:
Ciao
