Homebee
1/48 - Hawker Hunter F.Mk.6 & 6A by Airfix - released - T.Mk.7 conversion set by Aerocraft Models
7 hours ago, JeffreyK said:
Anyone else has clear parts issues? The canopy centre section was loose in the clear runner's bag so there were scuff and scratch marks on it as well as the one-piece canopy. I rectified this by sanding/polishing, but there is another, more fatal flaw: there are flow marks in the clear plastic so no matter how much you polish, you won't get rid of them. Why do so many of the new Airfix release have quality issues? My Sea Fury had problems as well.
I bought it from Hannants, sent directly to me in Japan so it's not so straight forward to rectify.
Jeffrey
FWIW, the clear sprue in my kit is the clearest and most flaw-free of any I've had in over 50 years of modelling. OTOH the upper wing/fusealge piece has 15 - 20 degress of dihedral due to warping. Seems there are some quality control issues all right, but odd that they vary so much between kits. I can bash the warp out easily enough, butI have told Airfix, on the basis that if no-one tells them directly, they may not realise they have a problem.
Paul.
It has been mentioned that the front wheel is devoid of detail (spokes)
Yes, it would have been nice if Airfix had done this but I've just drilled five holes in the rim with a micro drill and it looks much better now.
Pretty easy fix for any modellers wishing to save a few quid going aftermarket.
I think the main wheels are super, any differing opinions?
Atb, Steve.
Atb, Steve.
I hope you drilled six 'cus thats what it has :)
Jonners
Oops, sadly not Jon. I ran out of wheel rim on the fifth hole. Still, I will be doing several more so practice will make perfect. 😎 (plus using a slightly smaller drill bit, lol)
Atb, Steve.
Atb, Steve.
Mum's the word- you are safe on here as no one reads it much anyway :)  LOL !
Jonners
PS It must be said that the lack of interior detail to any of the gear doors is a bit of a mystery.
Why?
Tommo.
20 hours ago, The Tomohawk Kid said:
Why?
Tommo.
Well - they managed to put a lot of detail into the interior of the wheel wells, but the insides of the doors are pretty blank. A cursory glance at the references or a quick Google will reveal the  inner faces of the doors have some detail that would be no harder to reproduce than the detail inside the UC bays.
Does that suitably explain "why" I find it a mystery for you?
Jonners
The Academy kit has nice raised rivet detail on the inside of the doors but on both the ones I built deep injector pin marks meant much of the detail was at risk of loss. Doesn't explain why Airfix did not mould it but my one concern with their recent releases is the placement of the knock out pins in the mould and how deep some of the marks are in very awkward places to fill ( sidewall inserts of the P-40, wheel wells of the PO being recent examples).  For some reason Airfix does not use the methods of some other manufacturers such as Hasegawa who design some of these in " off" the part and joined to the part by a normal thin sprue gate.
Jonny
Ta Dude,
No need to be so high handed in your reply it was a honset question.
Tommo.
12 minutes ago, Rui Silva said:
Hi all,
Why there is no kit review in Britmodeller yet?
Well, there's this thread which you could perhaps see as a review?
1 hour ago, Rui Silva said:
Hi all,
I would look on this kit as a review, theres plenty of guys  on this thread complementing how good it is, how brilliant, superb, best kit ever, then proceed to knock holes in it(as an afterthought.)  I have found that to come right out with faults with a brand new kit, that all other Britmodellers pile into them and asking the modeller to give the kit a chance as its only recently hit the shelves(relates to all new kit releases - not just the Hunter)..………. they find its far easier(or in a round about way)to preferably complement the kit FIRST then add what really they wanted to say about in the first place...….small errors found on the kit which in their minds, proper research could have avoided, doesn't take long for a few others to join in with a complement or two then add an error they just happened to find.
Hi all,
For what it's worth, I've had mine for a week or two now and my view (though to be fair, I haven't built it yet) would be that it's a mix of very good and slightly disappointing. Highlights would be the intake design, the wheel wells, the overall outline and the decal sheet, but the cockpit is only average and the flaps (completely devoid of any detail whatsoever), nosewheel (plain hub with no detail) and undercarriage doors (no detail at all on inner surfaces) would all, I think, be considered 'fails'. However, the aftermarket will probably take care of all of these shortcomings eventually. For anyone who might be interested, I tried the Aires cockpit designed for the Academy kit and it actually seems to fit the new Airfix kit quite well. In summary, even though I thought I'd be throwing my Academy one (and all the associated aftermarket) out, I now think I'll probably keep it.
The final point I'd make - though maybe it's generalising a bit too much - is that there seems to me to be a 'prop team' and a 'jet team' at Airfix and the former seems to be better than the latter. The Blenheim, for instance (e.g., cockpit, engines, wheel wells, flaps) to me seems more/better detailed than the Hunter.
Not trying to have a go at Airfix (any new 'Cold War' jet is very welcome), just my tuppence worth. Donning tin hat now and running for the dugout!
Edited by hopkp
Grammar!
8 hours ago, The Tomohawk Kid said:
Ta Dude,
Tommo.
Well, when people ask monosyllabic questions, that lack any hint of politeness, I tend to answer in a manner I find appropriate.
Perhaps you might consider that next time you ask a question.
Regards
Jonners
Edited by Jon Kunac-Tabinor
Typo
  • Haha 2
  • Sad 1
Regards
Jonners
 Jon Kunac-Tabinor, the epitome of politeness?
Look into that mirror dude.
Tommo.
Tommo and Jonners: Take your quarral into a privat chat room and let the rest of us stay on topic/target please. The rest of us is not interested in your stone throwing.
Better yet, and this is the official line, both of you calm down.  There's absolutely no need to get shirty about this.  It all escalated to handbags rather too quickly.  Not good :fraidnot:
Any more shenanigans and there will be holidays :shrug:
Sorry Boss..  I'd stopped worrying about this with my last reply 8 days or so ago.
From my my perspective it was all said and done.
Jonners
4 minutes ago, Jon Kunac-Tabinor said:
Sorry Boss
Thank you.  The report came in today, and it couldn't really go unremarked upon :shrug:
Hi Mike!
That word... :giggle: I was at an Irish shindig during last St. Patrick Day. We had a lot of brews and soon all hell broke loose, when someone started some sort of a mosh in the living room.
I sudenly went through a window and landed before a couple of levely garden dwarves who seemed to be staring at me.
First thought crossing my mind was the these two were the Shenanigans... :rofl2:
Unc2
PS: Jonners is my mate.
Jolly good. :)
@Jon Kunac-Tabinor I took these at Cosford the other year, I knew there was a reason for it. More pics in the Hunter walkaround;
h3.JPG&key=c48ed18927b12c8f35ca970f6ee14
Julien
Hi all,
Eduard has announced 6 sets for the Airfix Hunter kit, available in April according with the Hannants website.
Bought two of them this Friday at the LHS. :)
Xtradecal future sheet
- ref. X48203 - Hawker Hunters International Operators
https://www.hannants.co.uk/product/X48203
  • Hawker Hunter F.56 - BA360A - 20 Sqn/Target Towing Flight Indian Air Force - Kalaikunda AB India 1972;
  • Hawker Hunter F.6 - 660 - 4 Sqn Iraq Air Force - H-3 Air Base during ‘Operation Moked’ Iraq 1967;
  • Hawker Hunter FGA.70 - L175 - Lebanese Air Force during ‘Operation Moked’ Iraq 1967;
  • Hawker Hunter F.6 - 60-602 - 5 Sqn Royal Saudi Air Force 1969;
  • Hawker Hunter FGA.9 - RRAF121 - 1 Sqn Royal Rhodesian Air Force - Thornhill AB Rhodesia 1967;
  • Hawker Hunter FGA.9 - R1821 - 1 Sqn Royal Rhodesian Air Force - Thornhill AB Rhodesia 1972.
X48203_1.jpg?t=1545587883
V.P.
:yikes:Just watching the build of the Airfix 1/48 Hawker Hunter kit on YouTube when I spotted this:
Are the main landing gear legs that fragile on the Airfix Hunter kit...?
Unc2
