PhantomBigStu
F-16 Kits/Block questions
I might have misunderstood you, but there is a great difference between the F-16I and F-16F, and you cannot make one from the other kit.
As for the F-16D Brakeet, you can use this to make a Polish F-16D provided that the PW nozzle and small mouth intake is in the kit.
F-16I specific sprues contained inside E-34 boxing
Q and V parts respectively intake cheeks fairings and dorsal spine vents
F-16F specific sprues contained inside 01930 boxing
M and W parts respectively Sniper pod and dorsal spine vents plus a couple of fairings
I know that in real life both are very different, but for Hasegawa the only difference contained in those two boxes are them as you can either build a P&W or GE F-16 as long you don't venture into Polish or Greek? territory as you need the longer tail ECM/chute fairing
Luigi
On 1/1/2018 at 4:16 PM, philbrad said:
Having built numerous F-16 kits over the years since the late 70's Matchbox/Airfix offerings to the current(ish) multi version Revell offerings.
Hi philbrad!!!
I was wondering what can I do with a very old Hasegawa/Minicraft F-16 A, this is an ancient kit from 1976 and I have one from 1980 when was released here in this side of the pond and sold cheaper as was made by Hasegawa/Minicraft Models as the one  depicted here in this link:
https://www.scalemates.com/kits/minicraft-hasegawa-1110-general-dynamics-f16a--164411
So, Can you advise me what I can do and which parts can modify to get other variant than the Red/White/blue early model F-16??? ... I am planning to do an early Israeli F-16 A with this one and a IAF/DF F-16B with the early Testors/Italeri kit as this one:
https://www.scalemates.com/kits/testors-683-f-16-fighting-falcon--147452
Can you help me???...Thank you very much in advance!!!
Luis Alfonso
Hi,
I have made over 2 dozens of 1/72 F-16 kits of various brands, Blocks and air forces.
Also the older kits and Red/White/blue ones...
https://designer.home.xs4all.nl/models/f16/f16-proto.htm
You may find a lot of info about the many F-16's at modelling pages here:
https://designer.home.xs4all.nl/models/f16/f16-1.htm
A lot of F-16 schemes and variations are possible.
Still more models to follow...
Enjoy modelling!
Meindert
Hi Luis -
Meindert's pages have loads of info for you, but to narrow down the options from the kits you have a little:
Your Hasegawa/Minicraft kit is of the YF-16A prototype. If you're looking for full accuracy that leaves only the two original demonstrators "from the box," one in the red/white/blue scheme and the other in a "cloud" camouflage of pale blue and white.  One of Meindert's pages shows a later boxing of the "YF-16CCv" which also wore r/w/b scheme and added canard foreplanes under the intake.
If you really have your heart set on something else, the changes are pretty extensive from the prototypes to any other versions. Most notable is the size and shape of the nose, but a lot of the details are different. Up to you whether you feel it's worth buying another kit for the version you want.
The Testors kit is much closer to your goal out of the box. That kit has the early style "small" tailplanes that were onky used up to Block 10.  Israeli A/B Vipers had the larger tailplanes, identifiable by the 45-degree crop at the outboard corners and the trailing edge extending past the aft end of the speedbrake fairings on either side of the exhaust.
Meindert's pages include a demonstration how to enlarge the tailplanes with sheet plastic and putty. The smaller tailplanes ate relatively rare, so you might also be able to buy or trade for a spare set of the larger type if you don't feel up to the modifications (I don't know of any aftermarket 'big tail' parts).
**EDIT:
Apologies for working from memory vs. checking references prior to posting - the initial F-16A/Bs delivered to Israel were Block 5 or 10 so they did have the small tailplanes, which match what's provided in the Testors "Israeli" boxing.  For the record there were some USAF surplus F-16A/Bs from later blocks delivered to Israel post Desert Storm that had the larger tailplanes.
As others have noted, the Italeri tooling has been modified several times over its history with changes that include the larger tailplanes in more recent boxings.
Source for Israeli F-16 block data:
http://www.f-16.net/f-16_users_article7.html
Edited by CT7567
Retraction of previous misstatement re: Israeli F-16A/B tailplane type.
The basic Italeri kit (#130) was updated at least once, and the updates include the big taiplane. I think my first Italeri kit is an updated one, and I bought it in January 1991. IIRC the big tailplanes were added by enlarging the mould cavities, looking somewhat un-neat. Not sure if this incarnation also had the prototype-style "pointy on both Ends" tanks replaced with the blunt-ended ones, in any case that happened with the C/D boxing I think (#188). Not sure if Testors boxed all of the Italeri versions, but given the Long-Standing cooperation between them I'd think so.
Sure about the big taiplanes for the earliest Heyl Ha'Avir machines ? I'd have to look around in my books a bit but could swear the first Batch had the original size.
I have the pre-upgrade #130 boxing, Italeri like Revell crated a small mess regarding whos box comes with what cause (and I'm not 100% sure):
1st Release marketed as Italaerei or Italaeri #130 orange/red band
2nd Release possibly still retaining the orange/red band marketed as Italeri #130
3rd Release marketed as Italeri #130 green band
4th Release Italeri #130 orange/yellow-ish band, new decals (?) no upgraded moulds
5th Release same as above, new decals and upgraded moulds and I think I still have the instructions hiding somewhere
Then Testors:
See pictures on Scalemates
From Scalemates timeline ignore anything else that is not Tamiya (rebox of #188, later ones come with Amraam missiles minus the ADF parts), Bilek again it seems a rebox of #188,  not sure about Income box and Flying Kiwis but all the others SHOULD be kept on the LHS shelves
Hobbycraft was a Smer kit with, the good things about both kits were just the decals contained inside them, cause one had early IDF markings and the Hobbycraft did come with well printed Venezuelan AF decals, otuside that the kit was a very poor copy of Italeri kit with nothing in common
Aeroplast at least the earlier one was a mess, ditto for Intech, they were either copies of Smer kit or something guess and shaped like an F-16
Mastercraft was a rebox of Smer with some extra parts  (mid sprue with C tail and drop tanks) added
Earlier IDF F-16 used the small stabs, 100% sure about F-16B having them due a couple of old pictures found inside an encyclopedia but not so sure about F-16A, going to check some Koku Fan from that era
Luigi
Edited by Silverkite
These were FY79 machines and still had the small tailplanes in USAF service, but some may have had these substituted while in Israeli service for the big tailplanes. Most were used as trainers, with few reaching operational squadrons.
Adfditionaly, if you fit the bigger stabs as is, they are too much forward, the trailing edge lining up with the speedbrakes instead of protruding backwards as they are in real life.
See: http://www.aircraftresourcecenter.com/Gal9/8401-8500/gal8462-F-16B-Chong/03.shtm
Just snip a bit off the tab and move them backwards.
Quote
Even with the tanks updated, the end plates were still incorrect (triangles instead of paralellograms,).
The RoG kit is the only correct one in this regard.
Quote
There were several Testors boxings of the Itaelri mold:
Andre
