JohnWS
1/72 USN 80' Elco PT Boat with some mods
Must be a thing with ship modelling people are just too critical of there own work I would never have noticed that hand rail 🔍
keep looking and it keeps getting better 👍🏻
beefy
7 hours ago, beefy66 said:
Must be a thing with ship modelling people are just too critical of there own work I would never have noticed that hand rail 🔍 ...
What, me too critical?   Yep, I think it's some kind of disease. :rofl:
On 5/29/2018 at 1:32 AM, longshanks said:
Well shame on you  ....... :fight:
That aside the MG mounts are shaping up nicely
Kev
The best modelers are their own harshest critic. I am loving every bit of this build
G'day!
An update on  building the Machine Gun Turret Travel Limiting Stop Rails.
I've made the Stop Rails using .6 mm dia. silver solder wire.  I like using the solder as it's extremely easy to cut & form.  Care has to taken when handling & gluing bits & pieces of the wire together since it bends so easily.  I tried using copper & brass wire & solder, but I can't seem to get good looking solder joints at this small scale.
I started forming the main rings for the rails using a socket (from a socket wrench set) wrapped in masking tape to get the correct diameter.  I decided to solder the wire ends together for added strength.  I don't know how many of you have tried to solder solder, but it's not for the faint-of-heart.  After many, many tries, I finally was able to get a good solder joint.  For some reason the solder wire wants to melt when you heat it ... go figure! :drunk:  I found the trick is to melt a little solder on the soldering iron, let it cool to just before it solidifies, & then touch the melted solder to the solder wire letting the melted solder weep into the joint.
Here's a photo showing one of the completed soldered rings.
Using photos, the rail details were formed and glued to the rings.  I found that roughing up the wire surface with fine sand paper before applying the CA glue seems to work the best.
Once the rings were completed, legs were formed & glued in place.  The legs will need to be trimmed before attaching to the turret drums.
Finally, The MG mounts were placed into the stop rail assemblies to ensure proper fit.
Next up, I'll trim the rail legs to size & glue the rail assemblies to the turrets, before applying coat of primer.
Oh & by the way, Iife is good as I fixed the hand rail on the day cabin. :thumbsup:
Thanks for stopping by.
John
Edited by JohnWS
Rails are looking very neat  👍
beefy
Really nice! I've done rails etc. with soldered copper wire. Hadn't thought of silver solder wire. Good one!
G'day everyone!
Another short update.
I've added a 'canvas' spray shield to the aft MG turret stop rail using a piece of close weave material, and primed & painted both Mark 17 MG mounts & the stop rails.
Also, I received the Eduard PE ammo belt set, ordered a couple of weeks ago (great customer service from Eduard).  In addition, I've been doing research on the .50 Cal. machine guns & their assembly in the Mark 17 mounts, to determine what detail would be visible in 1/72 scale.
As a result, I was able to scratch build the following parts for the MG assembly;
- added detail to the White Ensign machine guns (including relocating the molded bolt handles on two of the guns to the opposite side).
- two cradles, one for each pair of guns.
- four ammo belt feed guides (using wine bottle foil🍷).
- a couple of small parts that will attach the cradles to the gun mounts.
Next up, gluing all these little parts together & adding the guns to the gun mounts.
Thanks for looking in.
John
I thought I'd share a couple of photos of the assembled machine guns, before they're sent off to the paint shop.
The Eduard PE ammo belts fit & will be a nice addition to the guns.
Next up, painting the MG's & assembling them in the gun mounts.
John
Edited by JohnWS
The 50 Cal,s look sweet. 👍🏻
beefy
