giemme Posted August 20, 2018 Share Posted August 20, 2018 2 hours ago, CJP said: Massimo its good to see you back on this Ark Royal CAG project - that Buccaneer is sooo neat CJP Agreed! Bentornato Massimo Ciao 1 Link to comment Share on other sites More sharing options...
Courageous Posted August 20, 2018 Share Posted August 20, 2018 Welcome back Massimo. Couldn't resist fitting the slipper tanks. Will be interesting to see if you have any problems in fitting the u/c doors correctly like it did with the Airfix kit. Stuart 2 Link to comment Share on other sites More sharing options...
Massimo Posted August 20, 2018 Author Share Posted August 20, 2018 Thanks guys! I remembered one month ago I had done a couple of parts and hadn't posted the pictures. Here they are: This morning I started working on the port(.....???correct? I'm a biit rusty on this!!!) wingfold. About the slipper tank, While I checked my references for the wingfold, I noticed there are some differences withthe resin one I fitted. I know there were two types and this is he longer one, but If anybody's got better info about it...please come forward!!! Thanks Massimo 10 Link to comment Share on other sites More sharing options...
Courageous Posted August 20, 2018 Share Posted August 20, 2018 Looking good. Those intake covers will save a lot of grief...and hide a multitude of sins. Stuart 1 Link to comment Share on other sites More sharing options...
Brandy Posted August 20, 2018 Share Posted August 20, 2018 Welcome back Massimo! Nice to see a little more progress on this one. It looks as though you're going to your usual lengths on detailing the wing folds. Great stuff. Oh, and yes, left is port! I too should be back modeling soon. I move into my new apartment on 27th ( a week today) so hope to be at the bench again very soon. Ian 1 1 Link to comment Share on other sites More sharing options...
huvut76g7gbbui7 Posted August 20, 2018 Share Posted August 20, 2018 7 hours ago, massimo said: I know there were two types and this is he longer one, The long tank was only used by the SAAF on the Buccaneer S50. The tanks used by the FAA and RAF were the same length but had different fairings where it joined he leading edge of the wing. This change was a result of pitch-up accidents on launch from the carrier being caused by airflow issues with the tanks. 3 Link to comment Share on other sites More sharing options...
Massimo Posted August 20, 2018 Author Share Posted August 20, 2018 12 minutes ago, Scimitar said: The long tank was only used by the SAAF on the Buccaneer S50. The tanks used by the FAA and RAF were the same length but had different fairings where it joined he leading edge of the wing. This change was a result of pitch-up accidents on launch from the carrier being caused by airflow issues with the tanks. Your timing is perfect , as usual, Richard!!! Thanks! Link to comment Share on other sites More sharing options...
crobinsonh Posted August 20, 2018 Share Posted August 20, 2018 Lovely work. 1 Link to comment Share on other sites More sharing options...
Massimo Posted August 20, 2018 Author Share Posted August 20, 2018 Hi guys, today I went on with the port wingfold. Nearly there.Here a couple of pictures. That's it for now. Ciao Massimo 7 Link to comment Share on other sites More sharing options...
Massimo Posted August 21, 2018 Author Share Posted August 21, 2018 Good morning, 23 hours ago, Courageous said: Will be interesting to see if you have any problems in fitting the u/c doors correctly like it did with the Airfix kit. Courageous words started travelling in my mind and thus I decided I could abandon temporarily the wingfolds to start working on the model's final posture, which means ...the landing gears. I needed to see if the original gear's dimension could do , considering that I rebuilt the gear bays. I cut the wheels and inserted a layer of plastic card as they looked a little too thin. I glued the main gear legs and dryfitted the wheels to them. I also removed the location pins and in their place on the legs' head I drilled two holes. I drilled two holes on the legs' fulcrum shaft in the wells, passing through the wing to fix two metal pins which will ensure a strong fixing point for the gear legs without any glue. This will allow me to do some trials and correct the legs' length if necessary, to give the kit the correct height and posture. To make these pins I cut two bits of stainless welding rod and I fixed them which with Super Attack (cyanoacrilate). Of course everything is very...crude, no detail at this stage. Dry fitted the gear legs . And this is what Courageous meant. At the moment the door needs a little....help to get into place and no glue to hold it there, but I'm sure a little fiddling here and there will do the trick. And finally a bit of show. I added all the tail elevator , intake covers, seats , windshield and canopy to see what she looks like and now I'll compare the last picture to my references to see if the gears legs need to be shortened. That's it for now. Ciao Massimo 8 Link to comment Share on other sites More sharing options...
Courageous Posted August 21, 2018 Share Posted August 21, 2018 Excellent reveal there Massimo. Yours look a lot better than mine and don't look too bad at all, even if they are a bit snug. Stuart 2 Link to comment Share on other sites More sharing options...
TheBaron Posted August 21, 2018 Share Posted August 21, 2018 Exquisite detailing as ever Massimo: the combination of structure and process here make this unmissable. 1 1 Link to comment Share on other sites More sharing options...
giemme Posted August 21, 2018 Share Posted August 21, 2018 Wow Massimo, she's looking great! That final pic is already very evocative Ciao 1 Link to comment Share on other sites More sharing options...
CJP Posted August 21, 2018 Share Posted August 21, 2018 Massimo I like that last photo - she is really starting to radiate that Buccaneer look and feel. CJP 1 Link to comment Share on other sites More sharing options...
Brandy Posted August 21, 2018 Share Posted August 21, 2018 Nice legs! Ian 1 Link to comment Share on other sites More sharing options...
Massimo Posted August 21, 2018 Author Share Posted August 21, 2018 28 minutes ago, limeypilot said: Nice legs! Ian I've seen better!!!😋 Link to comment Share on other sites More sharing options...
huvut76g7gbbui7 Posted August 21, 2018 Share Posted August 21, 2018 I think that when you clean up the wheels the sit will be just fine. 3 1 Link to comment Share on other sites More sharing options...
Martian Posted August 21, 2018 Share Posted August 21, 2018 Nice work Massimo! Martian 👽 1 Link to comment Share on other sites More sharing options...
Massimo Posted August 21, 2018 Author Share Posted August 21, 2018 Hi fellas, small update. Having got involved with the landing gear legs, I thought to start working on one of them to add detail...well more than adding detail ...I've cut most of it and restarted from a couple of parts and added some scratch built or corrected. I kept the leg's main element, re shaped the lower part and drilled the fulcrum hole for the shock absorber, then I made the cylinder rod from Aeroclub plastic tube. I added plastic rod pins . Then I added a small extension to the port plate and drilled a hole to match that on the cylinder rod. I did the same to the starboard plate, then i added pins and dry tested it with the wheel. Once happy with the temporary positioning, I removed the last plate , to finish it and added a spacer to simulate that moulded together with the wheel side plates. I know it's all just dry tested, but it's a long process but I don't want to rush things as these legs'll have to hold the kit's weight. Enough for now. Good night!!! Massimo 9 Link to comment Share on other sites More sharing options...
Terry1954 Posted August 21, 2018 Share Posted August 21, 2018 This is coming along very nicely indeed. Terry 1 Link to comment Share on other sites More sharing options...
CJP Posted August 22, 2018 Share Posted August 22, 2018 More Massimo Magic on the main gear legs CJP 1 Link to comment Share on other sites More sharing options...
Massimo Posted August 22, 2018 Author Share Posted August 22, 2018 Hi Guys, last night I glued all main parts together and this morning I got a quite solid assemby. There are still somedetails mising and the wheel will need a bit of...lifting , but the base looks good enough to hold the kit and its length seems ok. Here below a few pictures. Tonight I'll leave for a few days and next week I'll go to Austria and Croatia for my holidays, thus I won't be able to do any progress. See you soon! Massimo 8 Link to comment Share on other sites More sharing options...
Brandy Posted August 22, 2018 Share Posted August 22, 2018 Even nicer legs! Have fun! Ian 1 Link to comment Share on other sites More sharing options...
Courageous Posted August 23, 2018 Share Posted August 23, 2018 Those legs do look nice. After doing that extra work on the legs I hope you haven't made work for yourself on fitting those doors later. Stuart 2 Link to comment Share on other sites More sharing options...
TheBaron Posted August 23, 2018 Share Posted August 23, 2018 Even leggier. Superb. 2 Link to comment Share on other sites More sharing options...
