Brandy Posted January 18, 2019 Share Posted January 18, 2019 Fantastic detailing there Massimo. Nice and crisp too. She's going to be a stunner! Ian 1 Link to comment Share on other sites More sharing options...
71chally Posted January 18, 2019 Share Posted January 18, 2019 Massimo, I'm amazed at the level of extra detail that you achieve, the quality of it, and in such a short time frame, very impressive. 1 Link to comment Share on other sites More sharing options...
Massimo Posted January 21, 2019 Author Share Posted January 21, 2019 Good morning mates, Back home I hadn'tmuch time to psare, as my lovely Treasure had better ideas than modelling, but i managed to find some . This is what i did: I added the missing stencils to the buccaneer and while doing so, I realized the fuselage roundels needed a little more Microsol (or Mcroset?...don't remember which one is which!!!Anywaay the second one, to soften the decals and let them adhere), so I added it and set them. On another slot of time, I dedicated to the Wessex fuselage's correction I cut both halves on the line at the beginning of the tail and afterhaving cleaned the edges, I used the back ones to mark their shape on a 2mm styrene sheet, which would become the meeting point for the new section. Once reduced in size, I glued the disc to the tail half. Then I did four angled cuts in line to the fuselage side bends to keep their position, correcting the section's angle to compensate its extnsion. I cut some more discs of styrene to reach the total length of 27 mm, as suggested by Heloman. I added CA glue and flour to fill and later I filed things down and sanded the area smooth. I'll have to prime the area and give it another go when the fuselage halves are joined, but it can do for now! Finally I gave another coat of Future over the Buccaneer to fix the decals. That's it for now. Have a nice week! Massimo 12 Link to comment Share on other sites More sharing options...
giemme Posted January 21, 2019 Share Posted January 21, 2019 Impressive surgery, Massimo! And the Bucc look grand too! Ciao 1 Link to comment Share on other sites More sharing options...
Courageous Posted January 21, 2019 Share Posted January 21, 2019 Brave man for slicing the fuselage like that, I've got to do that on my next Sabre build. Excellent stuff Mas, you are the man! Stuart 1 1 Link to comment Share on other sites More sharing options...
andyf117 Posted January 21, 2019 Share Posted January 21, 2019 (edited) Content withdrawn - I will NOT be threatened by a moderator, simply because I queried the actions of another... Edited June 27, 2020 by andyf117 1 Link to comment Share on other sites More sharing options...
perdu Posted January 21, 2019 Share Posted January 21, 2019 Your usual total ownership of plastic adaptation Massimo Superb I hope Treasure and yourself had quality time for a while even if you did waste some modelmaking 😂😂😂😂 🤔 3 Link to comment Share on other sites More sharing options...
hendie Posted January 21, 2019 Share Posted January 21, 2019 WOW! impressive surgery. 1 Link to comment Share on other sites More sharing options...
Terry1954 Posted January 21, 2019 Share Posted January 21, 2019 A bold but good move on the Wessex fuselage, and the Buccaneer continues to thrill. Excellent stuff Massimo. Terry 1 Link to comment Share on other sites More sharing options...
heloman1 Posted January 21, 2019 Share Posted January 21, 2019 Hi Massimo, So, you are building the HAS MK1 planeguard. Neat work with the internal wall detailing. Not easy! So the seat arrangement is as you have seen in the pic above. However, just to the right of the cabin door is where the aircrewan sat/sits. There was only enough room for one and a 1/2 seats, otherwise the two seats as supplied would have stuck out into the door opening. Soundproof quilting to the cabin roof and the curtain at the reat, which you have already done. In the doorway is the aircrewman to the right, no diving gear. He operates the hoist, to his right is the diver. You will need to fashion the intake on the nose, a sloping pane lin the upper half and a semi-circular plate to support that. then a mesh guard in the centre of the intake. I think you might find some images on my Mk1 build elsewhere on BM. Do you have the 4+ book on the Wessex? A must have. To answer the question about seats being folded up, we used the lapstraps to secure them. Colin 2 Link to comment Share on other sites More sharing options...
Massimo Posted January 24, 2019 Author Share Posted January 24, 2019 On 21/01/2019 at 16:42, heloman1 said: Hi Massimo, So, you are building the HAS MK1 planeguard. Neat work with the internal wall detailing. Not easy! So the seat arrangement is as you have seen in the pic above. However, just to the right of the cabin door is where the aircrewan sat/sits. There was only enough room for one and a 1/2 seats, otherwise the two seats as supplied would have stuck out into the door opening. Soundproof quilting to the cabin roof and the curtain at the reat, which you have already done. In the doorway is the aircrewman to the right, no diving gear. He operates the hoist, to his right is the diver. You will need to fashion the intake on the nose, a sloping pane lin the upper half and a semi-circular plate to support that. then a mesh guard in the centre of the intake. I think you might find some images on my Mk1 build elsewhere on BM. Do you have the 4+ book on the Wessex? A must have. To answer the question about seats being folded up, we used the lapstraps to secure them. Colin Thanks Colin, I think I may have found a picture of the seats you mean. For the roof, I'll replicate Hendie's, which looks greaat. About the nose...it's a bit early now, I'm concentrating on theinterior, as I'm travelling back to the UK and any external detail (and on a Wessie there are loads of them!!!) could come off while travelling. I've got the 4+ book and it looks great! Now a small update. I haven't had much time, but I painted the landing gears' legs, using the same procedure: black first, then light grey, Future and Tamiya panel lines accent black. Resin wheels will be added once avaaliable. For now I'll keep those supplied with the kit. As I'm happy with th semi gloss finish, I decided to remove the masking tape from the windshield.I also dipped the canopy in the Future and let it dry under a glass. I also painted the front airbrakes' deflectors, the gear's and electronic bay's doors , but I didn't take any pictures. They cqn be seen at the base's front. Here I just dry fitted all small items to let her rest, waiting for my coming back. That's all for now. I'm flying back to Cambridge now and I brought with me the Wessie and.....another mate....let's see what I can do in the next few evenings. Ciao Massimo 13 Link to comment Share on other sites More sharing options...
giemme Posted January 24, 2019 Share Posted January 24, 2019 Cool! Ciao 1 Link to comment Share on other sites More sharing options...
perdu Posted January 24, 2019 Share Posted January 24, 2019 Your mighty Bucc looks fab Massimo With decent resin wheels it will be amazing I made one of my last Wessex's seats be up in the folded position, it just never got to look as good as yours will I should have used the lap strap to hold it folded Next time maybe 1 Link to comment Share on other sites More sharing options...
coneheadff Posted January 25, 2019 Share Posted January 25, 2019 Niiiiiiice 1 Link to comment Share on other sites More sharing options...
Massimo Posted January 25, 2019 Author Share Posted January 25, 2019 On 24/01/2019 at 12:31, perdu said: Your mighty Bucc looks fab Massimo With decent resin wheels it will be amazing I made one of my last Wessex's seats be up in the folded position, it just never got to look as good as yours will I should have used the lap strap to hold it folded Next time maybe Woooops....where has the picture gone????? Those seats in the picture are a real gem!!! Is there a topic about that wessex build? If so I'd really like to see it!!! I may still decide to lift the left one,and that pic was a great reference!!! Link to comment Share on other sites More sharing options...
Massimo Posted January 25, 2019 Author Share Posted January 25, 2019 Hi mates, a small update. Last night I added some detail to the starboard fuselage half. Not much, but another little step. Tonight I'm going out so no more modelling. Ciao Massimo 6 Link to comment Share on other sites More sharing options...
corsaircorp Posted January 25, 2019 Share Posted January 25, 2019 Hello Massimo ! I'm a bit jealous about your frequent Journey to U.K !! Not to mention your skill in detailing your kits !! Great job Man ! Congratulations !! Sincerely. CC 1 Link to comment Share on other sites More sharing options...
perdu Posted January 25, 2019 Share Posted January 25, 2019 2 hours ago, Massimo said: Woooops....where has the picture gone????? Those seats in the picture are a real gem!!! Is there a topic about that wessex build? If so I'd really like to see it!!! I may still decide to lift the left one,and that pic was a great reference!!! OK here we are, I didnt want to influence the topic is all if you want it here it is This was in my HAS3 build last year or the year before in the Westland Wessex group build Lots of scrabbling about for an average perdformance I'd say but it was fun to go that far away from my usual stuff I hadn't been resin-ing stuiff much before 3 Link to comment Share on other sites More sharing options...
Courageous Posted January 25, 2019 Share Posted January 25, 2019 Great work on the Bucc legs, looking good. Nice work on the HAS internals too. Stuart 1 Link to comment Share on other sites More sharing options...
Massimo Posted January 26, 2019 Author Share Posted January 26, 2019 Hallo mates, tonight I had some time for modelling, after work, so I started by adding the top frame tube and the sort of handle to the seats' back. Then I decided to go for the roof. I used the same method used for the curtain by the rear bulkhead's passage. I'll add the web effect over the shaft covers once they're dry. Now a question for the well informed: What's the white thing fitted to the port side of the fuselage shown in the icture below? Hope somebody's got an answer!!! Ciao Massimo 5 Link to comment Share on other sites More sharing options...
giemme Posted January 26, 2019 Share Posted January 26, 2019 Interiors progressing very well, Massimo Ciao 1 Link to comment Share on other sites More sharing options...
Richard E Posted January 26, 2019 Share Posted January 26, 2019 1 hour ago, Massimo said: Now a question for the well informed: What's the white thing fitted to the port side of the fuselage shown in the icture below? Hope somebody's got an answer!!! Ciao Massimo I won't claim to be well informed but to offer an educated guess: an external fuel tank ? 1 Link to comment Share on other sites More sharing options...
andyf117 Posted January 26, 2019 Share Posted January 26, 2019 (edited) Content withdrawn - I will NOT be threatened by a moderator, simply because I queried the actions of another... Edited June 27, 2020 by andyf117 1 Link to comment Share on other sites More sharing options...
hendie Posted January 26, 2019 Share Posted January 26, 2019 interior is looking fabulous Massimo. I could almost forgive it for being in the wrong service! 4 Link to comment Share on other sites More sharing options...
Courageous Posted January 27, 2019 Share Posted January 27, 2019 Insides are looking cool. Stuart 1 Link to comment Share on other sites More sharing options...
