Jens
Italian F-104S - Hasegawa 1/48 + DACO
I caved in...
This is the Hasegawa Starfighter I will try to build (and actually finish) for this GB:
I haven't decided on the scheme yet but I am leaning towards a grey ASA or ASA-M.
Jens
Edited by Jens
We have complete faith in you, Jens. I look forward to seeing your progress.
Andrew.
Looking forward to watching your build Jens.
I have a grey Italian 104 on my to build list to.
James
Nice!
Spillone with Aspide and Aim9 M ?
Edited by exdraken
Thanks for the comments.
There are so many nice Italian Starfighters that I would like to build, so the hard part is deciding which ones. As for the weapons I would like to load it with 2 AIM-9 and 2 Aspides, but I might go with one of each and the wing tip tanks in the earlier green/aluminum colours.
Jens
Jens
Just like the photo above :D
There are pylons mounted as well... so maybe inboard tanks?
*Sigh* I just had a look at some of my Hasegawa Starfighters and decals in order to figure out which one to build. I found an Italian Tiger Meet F-104S that I also want to build now... One step forward, two steps back... :D
Jens
Well, the obvious answer would be build them all... :D
Of course this is rarely possible, so it will be a difficult choice.
Regarding armament, the common operational configuration for interceptors was one misile of each type, both on underwing pylons. Configurations with 2 of each type were however flown for sure, as there are several pictures showing them. Ok, they were mostly PR shots, but means that they were possible.
I am going to build at least (at least) six Italian F-104S, but not for this GB. ;)
Jens
I started building the F-104S yesterday. Not much to show yet as I just cleaned up some parts, glued the wing tanks together etc.
Jens
While slowly working on the interior I have changed my plans. This will now be the Tiger Meet 1988 Tiger F-104S, and instead of using the Daco intakes I will use the Cutting Edge F-104S conversion kit.
Jens
Also a good choice!
How compares the CE to the Daco parts?
The CE intakes are shorter and have better panel lines but they are also thicker. I think the correct length is somewhere between the CE and the Daco/Hasegawa intakes. Also, the CE set does not include (nor mention) the changed large ventral fin.
My first choice would be Daco any day, but for an F-104S without weapons I have no problem using the CE parts.
Jens
I have now fitted the CE intakes to the kit. Although I did remove about 1 mm or so from the rear of the intake insides there is still a gap to fill as you can see.
Since a correct ventral fin is not included in the CE conversion set I modified the one from the kit using the Daco part as a guide. You can see the modified kit fin in the top of the photo.
Now, where did I put my Evergreen... :D
Jens
Other than that horizontal "bar", is there something different about S intakes?  I'm just wondering why there are new ones to choose from.
The horizontal bar is the hinge for a large rectangular auxillary air door that opens outwards (also in flight). That door is quite different from the one on all other F-104 variants. Also, the S intake lips are further aft, and the intake itself is slightly larger than that of the other F-104s. Would anyone notice the size difference? Most likely not, but the panel lines and the large hinge are quite prominent.
Jens
I see, thanks.  I've got a full Daco set coming, so hopefully that does, as claimed, give me "everything I need" to make an actual S out of the basic G.  The decals arrived the other day- for "9-99", the nice flashy one.
I remember the discussions on the larger size of the S intakes and one comment from a person I consider a real expert was that the larger intake area was simply achieved by shortening the intake lip, with no other changes (apart of course from the larger auxiliary door on the side.
The only thing you don't get in the Daco set is a modified instrument panel for the ASA.
As for the intake sizes they might have been the same. In the scales we operate in it wouldn't matter anyway.
Jens
True, it's very difficult to see certain differences on scale models. The intake should have been bigger as the S engine required more air to get the extra power, reason why it also had a larger aux door, however the Phantom managed to go from one variant of the J79 to the other without changes in the intake size...
I though I had pictures of the intake of an S taken at a museum but I can't find them unfortunately
Hello Jens
Did you cancelled this nice project? I would like to know when its going on...........
I didn't really cancel the project. It just got sidetracked like so many other projects before it. That said I have decided to build it as a Tiger Meet F-104S. I recently started drawing correct tiger stripes in order to be able to cut masks for them. The decals provided in the Hasegawa kit are not correct.
This is the first test cut (in vinyl, but I will use another project for the real masks). I have adjusted the stripes a bit since then.
Jens
