exdraken
Spanish Airforce C.8 finished I guess! 1/48
 Spanish Airforce F-104G /  C.8
104 Esquadron Torrejon / Madrid
 1/48
another GB, another try! The Mirage GB just finished, the Flanker started long time ago...
ingredients:
20171112_221448_1
Decal detail:
20171112_221514_1
found an interesting photo of a Spanish C.8.
it carries I guess Expal build MK-83 GP bombs probably BR-500s
http://www.916-starfighter.de/Large/Stars/wS731.htm
are the wing pylons provided by DACO correct for bomb loads?
convering the white wings; top side only or bottom also in white??
Thanks,
Werner
Edited by exdraken
Nice choice Werner, the Spanish Starfighters are IMHO some of the coolest looking ones !
Not sure about the Daco pylons as I don't have the set (mainly build 1/72).
The wings were white on top while the bottom was in light grey FS 16473
Very, very nice choice Werner.
You don't often see Spanish F-104's built, which is a shame.
I would think that the Daco pylons would be fine for your build, I will have to have a look through my references to make cerrtain.
The decal sheet looks very nice, where did you get it from as a Spanish F-104 is on my list for the future?
Craig.
thanks a lot Giorgio, that is settled then. :)
thanks Craig,
decals are from series-espanolas
http://series-espanolas.com/es/home/54-se2348-starfighters.html
great quality and attention to detail. I bought them directly from their webshop. Not sure if there is/ was an english version... but I gues with google translate you will walk your way through! If you need assistance, just ask ;)
I assume for a Spanish one I need the C2 seat, not the MB one, correct?
thanks!
Thanks for the offer of help with the decals Werner, I might well order some in the future.
As far as I know the seats fitted to Spanish F-104's were indeed the C2 seat.
Very nice choice if markings Werner. Those are exactly the same ingredients that I'm using for my build.
Ill also have to look up those decals.
Watching with interest.
James
Cool choice Werner - I was looking at a Spanish finish for my 1/72 kit......how do see the Colour scheme?
i read about the white wings and grey underwing.....is the rest aluminium?
will join along !
Hi, thanks, yours as well ;)
No, the main frame is ADC grey ( grey with a touch of blue)
The vertical tail has several shades of grey and metal, the aft section natural metal. Of course, there are exceptions....
Will post a pic of the instructions. (which by the way are wrong for the wing  underside apparently...)
Started with some plastic cutting, resin sanding and paint work. Not really presentable though yet....
just as proof that I started ;)
base work on the part that need being finished before closing the fuselage...
quite some cross reading of instructions when combing the Eduard update and the DACO set if you are not a Zipper specialist ;)
20171118_224700_1
20171118_224737_1
which of the seat cushions would I use ??
20171118_225027_1
I am closing the airbrakes... some detail Hase provides lost, but more realistic, no?
don't know what makes me building defoging tubes... :banghead:  - DACO!!
20171119_001031_1
20171119_001912_1
 DACO wings are nice and surely an improvement! dimension and detail wise!
tbc,
Werner
It's nice to see a Spanish machine being built. I have a great Aeronautika decal set and a Hasegawa TF in th pile waiting for when I can apply quality time to it.  Good luck!
Martin
Definetly
Nice progress Werner, watch out for those DACO wings though, the Hasegawa tip tanks don't fit without modification when I tried mine!
David
What a nice choice. A Spanish one is still on my to do list!
Good luck with this one.
managed to do a little bit :)
20171203_235452_1
I used the coloured transparent warning lights from the DACO set
was not convinced before, but looks good installed!, also differences between orange, red, white and of course green/blue
20171203_235614_120171203_235652_1
the C2 seat is not finished yet obviously, but the red is quite ok color wise, no?
20171204_000859_1
as Danny from DACO suggests,
the main landing gear bay will not be glued, it centers itself and may allow slight adjustment :)  sounds promising!
took care of ejector pin marks on the inner tail surfaces, again, thanks DACO ;)
sounds logical, but I only did last minute before glueing them.....
I addeds ome nose weight, just to be on the safe side.... I hate tailsitters.... ;)
20171204_003258_120171204_003322_1
as I could not find anything else I needed to to before closing the fuselage, I did so late last night! :)
Edited by exdraken
On 4.12.2017 at 7:11 PM, modelling minion said:
Looking good Werner.
Off to the paint shop soon!
Yeah... it's a 104... not a big monster of a kit!! (F-111, MiG-25...)
Edited by exdraken
some more done
the short exhaust fits :)
20171207_221437_120171207_221501_1
some work around the cockpit:
20171207_221513_1
windscreen masked, Eduard masks worked really well here!
20171207_221622_1
20171207_230603_1
wing flaps and slats glued in a bit downward position, to generate interest :~
20171207_230620_1
full steam ahead!
not much of an update,
but i did a bit of modelling over the  weekend :)
tip tanks (still without the DACO fins) were not much of a problem, but also not the easiest to align with those tanks lids :|
20171210_232104_1
cockpit looks passable imho, I guess the seat will add its  fair share :)
20171210_232122_1
Nice work Werner
Look forward to seeing her with some primer and paint on.
James
really bad pictures, but I sprayed it Tamiya gloss black as a base...
we will see if it works out....
of course, tip tank stabs were also added
maybe pictures are showing, or not....   it says error on flickr... ?? - strange-- changed the way I embedded them... ...
Edited by exdraken
Nice work Werner.
She looks pretty good all in black!
James
