GazB 534 Posted May 6, 2018 Share Posted May 6, 2018 Hey, Reilly. if you're still looking for stuff to make straps with, there is this: http://www.greenstuffworld.com/en/formable-metals-foil/352-flexible-metal-foil.html Its a little tricky to glue and you have to be careful not to chip paint from it (roughing the surface may work). But it can be cut and bends nicely Gaz 1 Link to post Share on other sites
Reilly 277 Posted May 7, 2018 Author Share Posted May 7, 2018 Hi Gaz, Thanks for the link. There's some interesting stuff on that site and the flexible foil looks like a solution for a few things. Up to now I've been using the lead tops of wine bottles. Cheers John. 1 Link to post Share on other sites
Reilly 277 Posted May 26, 2018 Author Share Posted May 26, 2018 Turret paint job repaired and assembly complete. It really does have a two tone look. Try and reduce that later. Adding the decals was a pain. Maybe they were old but did have the tendency to fall apart. I'll have to paint over the missing parts. Some of them really were a bit of a joke. Tamiya seems to expect the decals to fit over the massive rivets on the armour plate so spent a lot of time lining things up and cutting holes in the decals only to have them then fall apart when applied, aargh!! Problem with pictures is that the parts I missed show up rather well, back to a bit of weathering. 3 Link to post Share on other sites
Dads203 12,000 Posted May 26, 2018 Share Posted May 26, 2018 Very very nice fella 1 Link to post Share on other sites
Reilly 277 Posted May 27, 2018 Author Share Posted May 27, 2018 (edited) Ok, finally finished so here's some decent pictures of the end result. At the start of this thread I said I'd compare the two Bradley kits, Meng and Tamiya. Here they are together. Things were going well then this happened: It has since been repaired and returned to service on the display cabinet shelf. As to which kit was better; detail wise the Meng version wins hands down right down to the detail on the various tool clamps. No brass needed in the case of the Meng kit other than what was provided. Decals were of high quality compared to Tamiya which just fell apart in some places. That said some decals in the Meng kit were in places that are hidden from view and then when they would be in view they are missing, somebody made a few strange choices. The clear plastic provided for the optics on the Meng kit make it look a lot more realistic than the lack of in the case of Tamiya. More need to follow this route but it does mean that they have to be protected (or added later) when painting the main vehicle. Construction wise the Tamiya is childishly simple and it all fits together well without the hours of fettling that almost every part of the Meng kit required. Even my kak handed efforts with the Eduard PE on the Tamiya weren't too difficult although I didn't replace everything with PE. On the whole I'm pleased with the combined result and happy that I'm not going to be looking at another Bradley for some time. There's still one in the stash but its staying there for a few years. In both cases the track delivered with the model was used rather than after market. The Meng set will withstand close inspection, the Tamiya rubber bands maybe not so close but I'm happy with the results. That's all folks, thanks for looking in and the appreciated comments. Edited May 27, 2018 by Reilly 7 Link to post Share on other sites
Bullbasket 11,805 Posted May 28, 2018 Share Posted May 28, 2018 It's interesting to get a comparison between two manufactures kits of the same subject, especially when they both turn out as well as these two did. Nice one (or two). John. 1 Link to post Share on other sites
FrancisGL 3,616 Posted May 29, 2018 Share Posted May 29, 2018 The result is magnificent, both Tamiya and Meng, they look very well finished. The work has deserved the effort. Cheers Reilly 1 Link to post Share on other sites
Reilly 277 Posted June 1, 2018 Author Share Posted June 1, 2018 (edited) Thanks for the comments. It took me a bit to get the enthusiasm going for the Tamiya version after I'd completed the Meng but at the end of the day it seems to have worked out. Its flying thingies next for a bit. I've a 1/32 Corsair on the bench but after that there's a Centurion needing some urban camouflage. Cheers John. Edited June 1, 2018 by Reilly Link to post Share on other sites
longshanks 10,097 Posted June 1, 2018 Share Posted June 1, 2018 Nice Pair ! Kev 1 Link to post Share on other sites
crushkill 149 Posted June 10, 2018 Share Posted June 10, 2018 Look excellent!! 1 Link to post Share on other sites
Reilly 277 Posted June 11, 2018 Author Share Posted June 11, 2018 Thanks Crushkill. Hope I did them justice. They're looking good on the shelf. Sometime in the future I'll knock up some part of Baghdad for them. 1 Link to post Share on other sites
Kris B 2,233 Posted June 16, 2018 Share Posted June 16, 2018 Looking good. 1 Link to post Share on other sites
