Universal Airbrush Accessories - Iwata from Airbrushes.com
Julien
Lube
Everyone wants to keep their airbrush in top condition, after all they are not cheap. This is a non toxic silicone free lubricant from Iwata which can be used on all moving parts. In particular they recommend applying it to; The Main Lever, Needle Packing, Valve-piston packing, along the needle and the needle cap to enhance paint flow and prevent tip drying. This is a new formula and is now clear. This new formula does not evaporate and maintains its viscosity. Recommended to keep your Airbrush in tip top condition.
Spray Out Cleaning Pot
This is a universal pot to allow spraying out paint and cleaning products from your Airbrush. This is a glass pot the lower part of which is covered with a removable rubber sleeve. This stops the pot from sliding of your work bench, and if it does in someway will offer some protection from breaking.  There is a hanger which will fit all gravity-side-bottom feed and trigger style brushes (sp pretty much all of them then!). There is a filter cap which holds small foam type filters of which you get two spares in the box (these are also available to buy separate). The cap can even hold small parts if you dont want them rolling around. The pot eliminates over-spray when cleaning and its easy to clean up afterwards. The glass bowl when removed from its sleeve is even dishwasher safe. Highly recommended, especially if like me you have just been using an old jar for this.
Airbrush Holder / Hanger
As the name would suggest this is holder to keep your brush(es) safe on the bench. This is universal and will hold two brushes of any combination. The design holds your brushes securely and prevents them from being accidentally pulled off. There is a heavy duty clamp which will open up to 3 inches (75mm). The box also includes a bracket to attach the cleaning pot to the stand.
Workstation
As mentioned the Spray out pot can be attached to the airbrush holder to create a Workstation. In addition there are tapped holes and a screw to mount a pressure regulator here as well if needed. If purchased as a work station there is a cost saving as well.
Conclusion
These are some handy tools from Iwata which will fit most airbrushes out there and will help keep your equipment in good condition. Recommended.
Review samples courtesy of
