HT's Eduard 1/72 JRS-1 'The Boat'
I shall be partaking with this gem with all the trimmings thats in the box.
23984527238_f693f00671_h.jpgDSC_0021 by stuart wellard, on Flickr
37788319426_e0215feed4_h.jpgDSC_0022 by stuart wellard, on Flickr
37579130630_a845f0e224_h.jpgDSC_0024 by stuart wellard, on Flickr
37579129860_4e48ee6066_h.jpgDSC_0025 by stuart wellard, on Flickr
37579127520_ad62dc123c_h.jpgDSC_0026 by stuart wellard, on Flickr
37836789891_bc832e5a48_h.jpgDSC_0027 by stuart wellard, on Flickr
37788305326_d948b923ad_h.jpgDSC_0023 by stuart wellard, on Flickr
Hi Hardtarget,
Welcome to the GB! This is an excellent choice! I have one of these in the stash, so I'll be following with great interest.
Let us know which colour scheme you'll use :)
Jaime
HI All, the more the merrier. I shall be doing the Pearl Harbor kite which I believe is to be shown in the next rendition of SAM.
I made a start on a few parts and some prep work.
I started off with the IP.  The instructions would have you to sand off the face with all the molded on parts but why not simply turn it around? which is what i did without the need for sanding.  There is no size difference at all.
37126609974_0833189020_h.jpgDSC_0034 by stuart wellard, on Flickr
Next up were the wheel wells which are supposed to be a nice little fit but i found that neither part at the bottom were angled so you have to put this angle in to ensure that the top rectangular section is square to the fuselage halves. I also had to fill in the two large windows which i used some of my 'sprueglue' TM. Once cured properly ill give another coating to be sanded down later.
37126608144_f88a16b906_h.jpgDSC_0032 by stuart wellard, on Flickr
Windowed doors sanded to fit and then were cemented in place. I also drilled a 5mm hole for the new window.
23984515568_125d9cb2cb_h.jpgDSC_0033 by stuart wellard, on Flickr
I moved onto the wings next which need some sanding on the inners as there are lumps and bumps all over the place.
37788306006_b47b669bc2_h.jpgDSC_0028 by stuart wellard, on Flickr
Once the wing had set, the wing tips were next and these again need some clean up and squaring up to fit the main wing.  Lining up the panel lines showed that there is some excess wing here and there.
37788303266_0e663811a4_h.jpgDSC_0030 by stuart wellard, on Flickr
Cockpit up next which ive just started.
37126608994_e12f4336a3_h.jpgDSC_0029 by stuart wellard, on Flickr
Edited by Hardtarget
  • 2 months later...
Hey up chaps,
Progress has been good but uploads the usual non existent so its about time as the deadline is near to get some photos posted with progress and current state of play.
Seats being resin were all painted on their mountings then sawed off. some of the arm rests tend to ping off as there isnt sufficient material to cut safely.  These were glued back on and thinking if i did anouther that id saw them off first and cut off the arms.
38593009025_8d9dd433f9_h.jpgDSC_0034 (2) by stuart wellard, on Flickr
Inner fuselage prepared and painted.  There are fit issues with this kit that you need to scrape and scrape until you get a nice fuselage fit. More issues when you try and fit the cockpit sections.
27694416319_24390a1f9c_h.jpgDSC_0035 by stuart wellard, on Flickr
A bit of PE for the windows affixed using Krystal Klear which i used for all PE to stop it from 'pinging' about.
39471647281_47ec25f429_h.jpgDSC_0036 by stuart wellard, on Flickr
Seating & Cockpit in place.
27694416689_fd0f6581e7_h.jpgDSC_0037 by stuart wellard, on Flickr
Some fettling and test fitting required before it all gets sealed up.
39471648651_ac71d5db53_h.jpgDSC_0038 by stuart wellard, on Flickr
All fits one side now for the other.
27694417179_dcf31b5061_h.jpgDSC_0039 by stuart wellard, on Flickr
With some persuasion its looks ok.
39471650041_23a8b4e6a0_h.jpgDSC_0040 by stuart wellard, on Flickr
Obligatory filler deluxe plastic putty.
27694417479_90508d26d6_h.jpgDSC_0041 by stuart wellard, on Flickr
The filler is too fine and required a bit of thicker filler to get a nice finish and to cover up the step differences of the fuselage.
39471651661_9d431025bb_h.jpgDSC_0042 by stuart wellard, on Flickr
The canopy glazing was dipped in Klear and test fitted to the fuselage.  There is a slight gap at each side window if you want to mate the top of the glazing tot he fuselage. you can fill it with card or i used additional Krystal Klear.
39471652501_0fd2e17ba8_h.jpgDSC_0043 by stuart wellard, on Flickr
Once in place and dried, masking began using the mask set included.
27694417899_23c735033f_h.jpgDSC_0044 by stuart wellard, on Flickr
Update 2.
With the fuselage buttoned up it was time for the elevators. They seem to have some sort of peg system but you need to drill out the holes in the main stabilizer as they are there but filled. After this i added the struts which need an aweful lot of cleaning up and delicate cutting from the sprues.  I found one that was slightly too short and was replace with plastic card to the correct dimensions and rounded.
39441192482_98baad8bbb_h.jpgDSC_0045 by stuart wellard, on Flickr
Will all the main parts ready, priming and then a bit of paint was airbrushed on. For this kit im using the US Navy/Marine set of Vallejo MA.  Colours being 71.109 PRU Blue (as recommended by Vallejo for M-485) and 71.298 M-495.
38593007305_26b4b88d3b_h.jpgDSC_0050 by stuart wellard, on Flickr
38593007985_5d8fc34739_h.jpgDSC_0051 by stuart wellard, on Flickr
With that bit of painting out of the way it was time to affix the wing to the fuselage.  This is a line up nightmare as there is only that center section on the fuselage as a contact cementing point which is not 'squared up'  so needed quite a lot of sanding and test fitting until the right curvature and seating arrangement could be found.  once i was happy with this i cemented in place using Tamiya Cement.
39441194842_dd41d7c41e_h.jpgDSC_0052 by stuart wellard, on Flickr
With that center section in place and holing firm, the struts were added and these are int eh same condition as the rear struts and need the same amount of clean up to get a nice fit and get close to the right angles.
39441195932_bcc1633a46_h.jpgDSC_0053 by stuart wellard, on Flickr
Great Progress Stuart
.. and Happy New Year
I was hoping this one would get an airing in this GB and this is it; some really great building and build information here  - thank you
Forgive my ignorance but is this a reboxing of the Sword kit?  I have that version in the 'to be built' pile and tips are much appreciated.
Good luck in the race to the deadline
Regards
Andrew
Excellent progress and, again, thanks for the tips.  This kit is in my stash and was a possible second entry of mine to the GB. Alas, I don't think I'll even finish my first and only entry.
Jaime
Hi @Hardtarget,
If you haven't noticed yet, the GB deadline has been extended one week till 14 January 2018, 23:59 GMT. Hope you can finish this model in the additional time.
Jaime
3 hours ago, jrlx said:
Hi @Hardtarget,
Jaime
Awesome, thanks Jamie, much appreciated.
Ive made some more progress, with decals on and just started weathering before i put all the braces and small bits that will ping off when handled.  Pics will follow
  • 2 months later...
Sorry Folks, ive finally finished this kite, she wasnt easy but im pleased with the end result and will now go in the hanger.
JRS-1 Bu No 1063, VJ-1 Pearl Harbor, Feb 42.
26008018307_5bddc8a760_h.jpgDSC_0238 by stuart wellard, on Flickr
26008017817_e1465833fa_h.jpgDSC_0239 by stuart wellard, on Flickr
26008020817_3fca5de145_h.jpgDSC_0233 by stuart wellard, on Flickr
40880089541_f1b1e6b95b_h.jpgDSC_0234 by stuart wellard, on Flickr
40880089201_661bb4380a_h.jpgDSC_0235 by stuart wellard, on Flickr
26008019487_860c528091_h.jpgDSC_0236 by stuart wellard, on Flickr
40880088721_4745543cec_h.jpgDSC_0237 by stuart wellard, on Flickr
40880095841_63e46e832c_h.jpgDSC_0240 by stuart wellard, on Flickr
27009943408_6ea950190a_h.jpgDSC_0241 by stuart wellard, on Flickr
