stevehnz Posted November 8, 2017 Share Posted November 8, 2017 That looks brilliant Dave, nicely done. Steve. 1 Link to comment Share on other sites More sharing options...
Giorgio N Posted November 8, 2017 Share Posted November 8, 2017 Great build Dave ! Not only that, it's also a great insipiration for all those modellers who have a Matchbox Tempest in their stash 1 Link to comment Share on other sites More sharing options...
charlie_c67 Posted November 8, 2017 Share Posted November 8, 2017 Definetly more detailed than mine Dave! Hope you have better luck with the underbody seam. 1 Link to comment Share on other sites More sharing options...
modelling minion Posted November 8, 2017 Share Posted November 8, 2017 That cockpit looks fantastic, so much better than the original kit offering. 1 Link to comment Share on other sites More sharing options...
Arniec Posted November 8, 2017 Share Posted November 8, 2017 Great work on the cockpit. Love the detail you have done to make it look ace. Cheers, 1 Link to comment Share on other sites More sharing options...
Rabbit Leader Posted November 9, 2017 Author Share Posted November 9, 2017 16 hours ago, stevehnz said: That looks brilliant Dave, nicely done. Steve. Thanks Steve - I normally hate cockpits and the intention was never to go this far. I'm glad I can now move on the the fun stuff. 16 hours ago, Giorgio N said: Great build Dave ! Not only that, it's also a great insipiration for all those modellers who have a Matchbox Tempest in their stash Thanks Giorgio - Canopy aside, this Tempest is quite an accurate kit and the original Matchbox plastic is a dream to work with IMO. 11 hours ago, charlie_c67 said: Definetly more detailed than mine Dave! Hope you have better luck with the underbody seam. So far so good I think. I still need to clean this area up, however I do not invisage having too many dramas. Perhaps my strange way of assembly may have payed off (pure luck of course as this was never planned this way!). 10 hours ago, modelling minion said: That cockpit looks fantastic, so much better than the original kit offering. Thanks MM - It helps having a donor kit, although I normally model with a fairly tight budget - hence I've never used PE. 6 hours ago, Arniec said: Great work on the cockpit. Love the detail you have done to make it look ace. Cheers, Thanks Arniec - still a fair bit of work to go before this kit is over the line, however (like most Matchbox kits) it's been a fun build so far. Cheers.. Dave. 2 Link to comment Share on other sites More sharing options...
Thom216 Posted November 9, 2017 Share Posted November 9, 2017 Adding my kudos. Nice work on that pit. 1 Link to comment Share on other sites More sharing options...
Rabbit Leader Posted November 19, 2017 Author Share Posted November 19, 2017 Update #8 - Construction complete (well almost) It's been a while since I last updated this WIP, however it's been slow and steady with a few annoying moments in between. Basically, the fuselage with pre-attached wings were married together with CA and left to harden. I also run a fairly messy bead of this stuff along the join lines as it acts as a great filler. Once this was all filed back, I cemented a thick strip of plastic card to the rear of the cockpit opening as this section is flat. This was later sanded to the correct contour, whilst the headrest and seat will be mounted later. Lost panel lines that had disappeared during construction were rescribed as well as new lines added around the nose area. I did mess up a few areas, however this will all be put to the test once the first coat of primer is laid (no doubt I will need to re-fill and re-scribe!) The under fuselage filter was glued in place and to be honest is not quite located in the right spot and is a little on the small side - it'll just have to do though. Anyway - with a bit of luck, this kit will get it's first coat of grey primer tomorrow (Gunze Mr. Surfacer 1000), so it's good bye to that lovely multi-coloured Matchbox plastic. Cheers.. Dave 15 Link to comment Share on other sites More sharing options...
Beard Posted November 19, 2017 Share Posted November 19, 2017 Lovely work. I think I'll have to bookmark this WIP so I can refer to it when I get round to building the two I have in the stash. 1 Link to comment Share on other sites More sharing options...
GREG DESTEC Posted November 19, 2017 Share Posted November 19, 2017 Excellent work Dave, Well done All the extras and the careful finishing is making all the difference with this build. I look forward to the next update. Cheers Greg 1 Link to comment Share on other sites More sharing options...
TEMPESTMK5 Posted November 19, 2017 Share Posted November 19, 2017 Good afternoon Dave Very good job .. Patrice 1 Link to comment Share on other sites More sharing options...
Ventora3300 Posted November 19, 2017 Share Posted November 19, 2017 (edited) Looks absolutely pristine. Is it one of those glue in bushes for the prop shaft - will it spin? Edited November 19, 2017 by Ventora3300 1 Link to comment Share on other sites More sharing options...
Rabbit Leader Posted November 19, 2017 Author Share Posted November 19, 2017 3 hours ago, Ventora3300 said: Looks absolutely pristine. Is it one of those glue in bushes for the prop shaft - will it spin! The prop is a combination of Matchbox, Heller and some internal bits made out of plastic card. It's a little on the wobbly side, however has been designed to spin - if it actually does so after painting is still a big unknown? Cheers.. Dave 1 Link to comment Share on other sites More sharing options...
Thom216 Posted November 21, 2017 Share Posted November 21, 2017 Lovin' it! 1 Link to comment Share on other sites More sharing options...
Rabbit Leader Posted November 22, 2017 Author Share Posted November 22, 2017 Update #9 - Prime, sand, rescribe & reprime. It was time to prime this kit and start the paint phase. I tend to get bogged down after the initial construction, so I'm hoping that being part of a GB and displaying this WIP will encourage me to keep motoring along. Priming is one of those modeling applications that, once laid will either show that you've done a great job or more often than not bring you back to good old mother earth quick smart. I applied the initial coat of Gunze Mr.Surfacer 1000 thinned with Mr. Color Levelling thinner and was somewhat a little disappointed. I believe that the two coloured Matchbox plastic has a sneaky way of hiding flaws and this was more than evident after the kit was one uniform colour. The re-scribed lines are also a tad on the wobbly side for my liking, so some areas had to be refilled, sanded and rescribed. The under nose radiator flap was scribed and refilled three times and I'm still not overall happy with it! Anyway, here she is all primed and ready for the top coat - its no Airfix CAD test piece but it's gonna have to do otherwise I'll never finish it. I've also included a few shots of what it looked like in between priming coats just to show that it's not all high polished and fancy looking plastic! At one stage I was toying with the idea of painting this Tempest in the post-war Silver scheme, however I think a nice camouflage pattern might help hide a few of the many blemishes. Cheers.. Dave 13 Link to comment Share on other sites More sharing options...
Blitz23 Posted November 22, 2017 Share Posted November 22, 2017 This is coming on a treat, great work so far Dave! 1 Link to comment Share on other sites More sharing options...
dude_gan_ainm Posted November 22, 2017 Share Posted November 22, 2017 It looks great in the photos Dave,no worries there man.Drive on. Jimbob 1 Link to comment Share on other sites More sharing options...
stevej60 Posted November 23, 2017 Share Posted November 23, 2017 Look's great under the primer Dave. 1 Link to comment Share on other sites More sharing options...
Rabbit Leader Posted November 30, 2017 Author Share Posted November 30, 2017 Update #10 - Painting begins! Finally managed to get back to the workbench and apply some paint to this Tempest. Thanks to Chris Thomas' recent Osprey Combat Aircraft title - "Tempest Squadrons of the RAF", I finally committed to a colour scheme of my liking and believe I can make up the decals from my large box of spares. The chosen subject is Tempest F.6 NX170/K which served with No.249 Squadron, Deversoir Egypt, October 1949. By this time many Desert Tempest's were sporting the new Post War 'Desert' camouflage of Dark Earth, Light Sea Grey (Grey/Green) and Medium Sea Grey lower surfaces. Other publications list the upper grey as Light Slate Grey, which is what I had and used, however it does not appear to be as "Olive" as Chris' profiles which I rate highly. I also chose a relatively hard edge camouflage demarcation, which after studying the small amount of photos that seem to exist for this scheme had a slightly simplified camo pattern in comparison to the usual Tempest design. I've therefore tried to be as accurate as possible, however am not sure with it all just yet. I'll paint the undersides tomorrow, however need to fix a slight issue in this region first. So here are some progress pics. Cheers.. Dave Mr. Paint MRP-116 RAF Light Slate Grey Tamiya Tape marking out the simplified camouflage pattern Gunze Mr.Color C369 RAF Dark Earth Masking removed 13 Link to comment Share on other sites More sharing options...
Thom216 Posted November 30, 2017 Share Posted November 30, 2017 Nice colors, and looking really smooth! 1 Link to comment Share on other sites More sharing options...
tonyot Posted November 30, 2017 Share Posted November 30, 2017 Really enjoyed catching up with this one Dave,.....you`ve done an excellent job on the old girl so far. If you are going for the post war desert scheme as applied in Egypt after the tussle with Israeli Spitfires,....it is Dark Earth and Light Slate Grey uppers with MSG undersides. Here is one that I did over 18 yrs ago,...just for reference; Good luck mate and I`ll delete the pic if you like, Cheers Tony 2 1 Link to comment Share on other sites More sharing options...
Rabbit Leader Posted November 30, 2017 Author Share Posted November 30, 2017 1 hour ago, tonyot said: If you are going for the post war desert scheme as applied in Egypt after the tussle with Israeli Spitfires,....it is Dark Earth and Light Slate Grey uppers with MSG undersides. Here is one that I did over 18 yrs ago,...just for reference; Good luck mate and I`ll delete the pic if you like, Cheers Tony Appreciate the comments Tony, and please leave your photo as attached - for it's a great build, you hardly see these Tempests shown and it also confirms my colours somewhat. You'll also be happy to know that (once again) thanks to your inspiring posts, I've ordered a sealed Matchbox Halifax online prior to going to bed last night. We all know it has it's faults, however finding these and making attempts to correct them is just one of the many interesting points to this hobby. It also helps one understand the subject matter just that little bit better. So I'll bookmark your Halibag post, although I know it wont make this current GB - will there be a Matchbox III GB for 2019/20 perhaps ?? Cheers... Dave 3 Link to comment Share on other sites More sharing options...
Smithy Posted November 30, 2017 Share Posted November 30, 2017 Wonderful Dave and my first choice of paint scheme for any VI. Really wonderful and a joy to watch this build. 1 1 Link to comment Share on other sites More sharing options...
Cookenbacher Posted November 30, 2017 Share Posted November 30, 2017 That looks fantastic Dave, I really like the post-war desert scheme. Like Simon, I think I'll have to bookmark this thread. 1 Link to comment Share on other sites More sharing options...
stevehnz Posted November 30, 2017 Share Posted November 30, 2017 I'm so liking the look of that Dave, really nice & what a great idea for a MB II GB in a year or two. Steve. 1 Link to comment Share on other sites More sharing options...
