Tiger Striped Butcher Bird
My next offering to the Gods of styrene and glue is the aptly named? (for what I’m likely to do to this kit) “Butcher Bird”, the Focke-Wulf Fw 190
The kit I’ve chosen is Eduard’s ProfiPACK Fw 190A-7, kit no. 8172.
I’ve appropriated photos of the kit contents from Eduard’s website…
decals
photo-etch
4 scheme’s are catered for...
W.Nr. 430352, 2. /JG 1, Dortmund Airfield, Germany, January, 1944
W.Nr. 340001, flown by Oblt. Waldemar Radener, CO of 7./JG 26, Cambrai-Süd Air Base, France, May, 1944
W.Nr. 431007, flown by Heinz Bär, CO of II./JG 1, Störmede Air Base, Germany, April, 1944
W.Nr. 642962, flown by Maj. Hans-Günther von Kornatzki, CO of Sturmstaffel 1, Salzwedel Air Base, Germany, February, 1944
Anyone who is lucky enough to own Aircraft Scale Modelling FAQ by Daniel Zamarbide will have seen chapter 7.2.4.2 Winter scheme details a Fw 190 F-8 in German “winter scheme”
I plan to recreate a similar scheme, so plenty of opportunities to learn some new techniques
until next time
as always, any suggestions or comments will be gratefully received.
rgds
John(shortCummins)
  • Like 11
Preparing the cockpit for paint.
The Eduard ProfiPACK provides photo-etch instrument panels as well as various switches and levers, to add some of these, in some cases, the existing moulded detail must first be removed. Here I’ve used a micro chisel and sanding sticks to give me a smooth surface.
Foot pedals, document/map pocket and top access panels are also part of the PE set
PE lever added to the cockpit sidewall
Fuselage/nose machine-gun subassembly
Everything is given a base coat of UMP black primer, this will help create the illusion of deeper shadows later in the painting process and unifies plastic and PE.
pilot’s seat
I’ll let the primer cure overnight and then make a start on the black grey colours for the cockpit.
until next time
rgds
John(shortCummins)
1 hour ago, One-Two said:
Nice start John
I'll be watching this one with great interest, since I have quite a few of these Eduard 190 Antons.
Do you plan make it fully closed, or to leave some cannon covers/engine cowlings open?
as Eduard have provided a nice engine and cannons it would be rude not to have them open :D
I may leave one of the cannon closed, I've still to decide
rgds
John(shortCummins)
Painting the cockpit.
I started by giving everything a coat of Tamiya XF-63 German grey
the shadows are deepened with highly thinned Tamiya XF-69 NATO black (80% thinner 20% paint)
highlights are added with Mr Hobby H305 grey (these aren't a stark as these photos make out)
dirt and grime simulated with very highly thinned Tamiya XF-68 NATO brown (95% thinner 5% paint)
dry brushing with Mr Hobby H305 grey
foot straps detailed with a mix of yellow & red brown (20% 80%) and the buckles in vallejo metal color 77.707 chrome
Next it’ll be the rest of the PE, instrument panels etc.
until next time
rgds
John(shortCummins)
Edited by shortCummins
spoiling mistook
PE for the cockpit.
I’ve added a drop of PVA to simulate glass. The lower instrument panel has non-painted levers and switches.
switches and levers painted
side panels added to the cockpit, I’m not too happy with the colour, its too blue, I’ll have to have a think about what to do about it. If/when I build this kit again I’ll not use these side
panel PE
seat/lap belts
attached to the seat
the seat is a bit of a tight fit, the PE lap harness buckles made it even tighter! I’ve given the side panel PE a wash with Tamiya dark brown panel liner and this has toned them down, I’m still not 100% but they’ll have to do.
this shows the contrast with the non-washed instrument panel and the washed side panels
Thats it for the PE for the time being, next I’ll finish up the nose gun bay and rear wheel so that I can join the fuselage halves.
until next time
rgds
John(shortCummins)
Machine guns painted with Mr Metal Color 212 iron.
buffed
The instructions suggest fitting the machine guns now however, I’m reasonably sure that I’d either knock them off or (more likely) break them so I’ll  fit them nearer the end of the build.
A base coat of Alkan RLM:02
I ‘dirty’d’ the RLM:02 with a wash of Tamiya dark brown panel liner which I toned down with the use of a Q-Tip moistened with odourless turps
Additional scratches and general ‘wear and tear’ added with thinned XF-63, XF-64 and a HB pencil
Tail wheel, UMP black primer
Tamiya XF-85 rubber black
Eduard mask and Mr Masking NEO, way too gloopy
Tamiya X-18 semi-gloss black
Alkan RLM:02
vallejo acrylic metal color 77.707 chrome
The rear wheel assembly assembled
Now I can join the fuselage halves.
until next time
rgds
John(shortCummins)
I first glued the rear wheel, cockpit and nose machine gun sub-assemblies to one side and tell in place while the glue dried.
I also glued the cockpit and machine gun subassemblies from the underside
In general the fit was very good however the machine gun sub-assembly needed to be ‘un-glued’ and re-aligned to fit.
close-ups of the machine gun area
Next will be wheel wells and joining the wings together.
until next time
rgds
John(shortCummins)
As I want to fit an external fuel-tank I needed to drill the holes to allow the fuel tank rack to be fitted to the underside.
Then I fitted the rear ‘main’ spar of the wheel well
additional spars were added
UMP black primer was used on various parts
Once the primer had fully cured everything was given a coat of Alkan RLM:02
The wheel well ‘top’ probably needs to be painted RLM:02 as I think it will be visible once the engine is installed, I plane to have the engine bay open
…so I gave it a primer of UMP black, after masking the lower exhaust which have been painted with vallejo model color 70.814 burnt red
and then RLM:02
Next the machine gun barrels were added
The top of the wings, at the rear of the gun bay, needs ‘metal’ colour and Eduard provide a mask for when the wing is painted
Machine guns were painted with Mr Metal Color 212 iron which was then ‘buffed’ when it dried
I had toyed with the idea of having one machine gun bay open and one closed however I decided to have both of them open, therefore the ‘top’ of the machine gun bay(s) were added to the top wing
top and bottom halves of the wings joined
the eagle eyed amongst you will have noticed that I’ve already broken one of the wing mounted machine guns, I think I’ll have a look for some brass barrels as I’m sure the remaining one won’t last too long
Next will be nailing the wings to the fuselage.
until next time
rgds
John(shortCummins)
1 hour ago, Corsairfoxfouruncle said:
That was the hardest part of building my Tamiya 190. Trying to keep the darn barrels on without snapping them. If i build another i’d just replace them with hollow tubing or brass like youre planning to do.
Hollow tubing, great idea, I think I might have either some copper or aluminium that will do the job
thanks for that :yes:
rgds
John(shortCummins)
Attaching the wings to the fuselage, generally this is a very tight fit however there are a couple of voids that will need to be addressed.
The rear wing roots will need filling, perhaps with shims of plastic?
Also the join with to the rear of the fuselage, putty could be used here
The gun bays and engine compartment requires some wear and tear
Ailerons fitted, ‘interesting’ fit, you have to push them up and back into their ‘slots’, once fitted their really positive.
Rear stabilisers attached
the ‘top’ instrument panel needs to be attached
the fit of the ip and cowl requires a bit of guesswork
Building the engine will be next.
until next time
rgds
John(shortCummins)
This kit includes a detailed engine, first I needed to give everything a coat of UMP back primer.
Cylinders were painted with Mr Color Metal 213 stainless
Tamiya XF-16 flat aluminium was used for the manifold(?)
Push-rods, gearbox and other bits’n’bobs were painted with Tamiya XF-69 NATO black
The cylinders were then ‘weathered’ with Tamiya dark brown panel liner and the push-rod were attached
The manifold(?) subassembly was assembled
These subassemblies were then joined to make the ‘complete’ engine
NATO black parts were then dry brushed with vallejo model air 71.065 steel
Fitting the exhaust pipes will be next.
until next time
rgds
John(shortCummins)
The kit includes a template to enable the exact position for the exhaust pipes which were then fitted after being painted with vallejo model color 70.814 burnt red
Once all eight exhaust pipes had been fitted the template was removed…
vallejo pigments 73.106 burnt sienna and 73.110 burnt umber pigments are then then used to simulate rust
…and the final (back) part of the engine fitted
Fitting the engine to the airframe will be next.
until next time
rgds
John(shortCummins)
I’m not sure how mush of the engine bay will be visible, I’m assuming that some of it will be seen so I’ve ‘weathered’ the panels.
To start I’ve slathered Tamiya panel line dark brown
This was then wiped off with a Q-tip moistened with turps
AK engine oil was then added
The cowl, 5 pieces, was assembled
Tamiya panel line dark brown dirty’d the insides
The engine fits onto a cradle made from 4 pieces, good fun lining up
the cradle…
engine attached
the cowl is fitted and most of the engine is hidden
Adding the final bits’n’bobs to the airframe will be next and then I’ll start preparing for paint.
until next time
rgds
John(shortCummins)
  • 3 weeks later...
There are a few bits’n’bobs that need to be added to the airframe before I can start to prepare for paint.
Firstly I need to attach the rudder.
The windscreen was fitted
I’ve decided to add the PE extra armour…
the larger armour pice was bent to shape with the aid of a pencil
PE ‘engine vents’ added
The external fuel tank built, I’ll fit it later
Preparing for paint will be next.
until next time
rgds
John(shortCummins)
Preparing for paint.
As with all(?) builds there is a little filling, clean-up and re-scribing needed. The gap at the wing roots was tackled first.
Next some ‘perfect putty’ was used to fill the gap where the rear of the wings fitted the fuselage and then cleaned/smoothed with a moist Q-Tip.
Masking the cockpit, engine and gun bays with Tamiya masking tape, the windscreen was protected with the provided Eduard masks and Mr.Masking Sol.
24388838948_4d911c3647_o.jpgJHC_5670a by
John Cummins, on Flickr
Wheel wells were covered with sponge and masking tape
I’ve temporarily attached the canopy with some white glue, the windscreen and canopy was given a coat of Tamiya XF-63 German grey so that this colour will be seen from the inside once the masks have been removed.
When the windscreen dried everything was given a coat of UMP grey primer to check the seams and repaired areas.
When the primer has fully cured I’ll be ready to add extra rivet detail which will be next.
until next time
rgds
John(shortCummins)
