Plasto
PK 506 1/32 Sea Venom
Hi,
I'll have a go at the 1/32 Sea Venom.
I have the Matchbox original multi coloured plastic kit.
It it may require some new decals. But we will see. I'll go for a FAA scheme..
Plasto
I've dusted the box off in preparation for a start.
The original box was discarded when I bought the kit to keep postage down...
the parts in the box..
And the sprues showing its unstarted and multicoloured.....
Im going to build it OOB for the most part so we'll see where we get with that..
cheers
Plasto.
A big sea venom. Sounds good.
Great to see the Sea Venom and a original one in three colors.:Tasty: I have got the revamp from Revell from a couple of years ago.
I hope the decals will be ok.
Good luck with the build.
I made a bit of a start in between tank track manufacture...
I thought I’d build the kit in keeping with its background. So no fancy stuff and more of less OOB.
I started with the cockpit...
I just used some paint on the cockpit no instrument decals.
Plasto
Edited by Plasto
That Instrument Panel looks very effective - well done. I’ve actualy got the exact same kit, just wondering are you going to make the canopy moveable or fixing it in either open or closed position? You don’t want to hide that great cockpit work now do you!
Cheers and looking on with much interest.. Dave.
Right,
i havebeen progressing with this im and off I also have a 1/48 P-38 on the go so it’s been fork tail madness at the bench.
Most of the sub assemblies of the Venom are together.
The kit kit has been ok to build. Just a bit of filling required which can be minimised thus far with careful fit.
Here is the fuselage and wing assembly top.
There Are sink marks in the wing from the support ribbing for the wing section joiners. Typical of 70’s plastic..
underneath  I opened up the shell ejector ports and added in the wheel well inserts.. and drilled out the cannon ports I’ll add in some blast tubes later.
I made up the engines assembly and cut off the tail pipe and replaced it with a bit of brass tube thus save sanding the seam on the jet pipe.
finally I added some rib work to the rear fuselage section as the kit part has none.
Here it is all dry fitted up...
more tweaking and sanding to come..
cheers
plasto
Edited by Plasto
Hi,
I haven't forgotten this build...
Here it is currently I have added some clutter to the coaming behind the cockpit.. Also most of the construction is complete.
IMG_4368
Things need a tidy up and then onto the final construction and paint....
Plasto
Great work Plasto. Can't wait to see it with some paint on.
Great to see this big Sea Venom back on the GB front page.
Looking good and really starting to take shape now. Also looks like a fair bit of sanding was required to blend it all together.
Cheers.. Dave
Great work Plasto,this bring's back memories as I got this kit as a Christmas present in the late seventies.
Anymore progress on this lovely big kit Plasto? l was looking forward to seeing this one done and have an original Matchbox kit that keeps looking at me every time I open the stash cupboard.
Cheers.. Dave
