Italeri 1/72 Su27D Sea Flanker - COMPLETED
theplasticsurgeon
Joining you with this kit
That cost me £6.50 at Portishead show in 1999, and remained in my stash ever since. . .
possibly because Flankerman told me it's a rubbish kit, 2 minutes later :-(
Edited by theplasticsurgeon
More info
Busy with other stuff, but here's the cockpit installed into the airframe.
Living down to the rubbish fit.   Cockpit interior is XColor Azure blue.  Seats and stuff are type grey.
This is the airframe around it all.
Plan is to finish something thike this.
More info
Hi, Nice progress and that cockpit looks good too. Did you use any aftermarket for it?
The reference picture you say to finish it alike is from a Su-30MK, to be more exact, the brother or even 'the' ill-fated Paris Flanker in '99. Mind that these colors are never used on a naval Su-33. But offcourse you paint your model like you would like eh 😉
On 08/10/2017 at 4:53 PM, FortyEighter said:
Do you literally use Tippex?  How easily does it smooth?
Confirming Tipp-ex, or other correction fluid. Paint it right down into the gap of a seam,
allow to dry and harden.  Then smooth off with fine wet-n-dry, or with a turps rag.
The Flanker isn't quite ready, but here's that stage from my recent Harvard.
Thanks for the "how to do it" - will try it
Back with you, having airbrushed the undersides with Humbrol 196 Light Grey.
Now on with the masking to protect that from the upper-side colour.
I've scaled the colour instructions diagram to model size on a copier - this makes camo patterns a LOT easier to mask.
Just now, Valkyrie said:
Like that scheme, canopy is nice and clear too crisp work
I dunk all my canopies in Johnson  Klear early on in the build, to allow plenty of time for it to cure.
I've just looked back over a few other GBs - yes it does add a certain something.
Onwards and upwards, - she now gets her white bits. Brush painted acrylic in this case.
And now up onto her pins
And canopy properly framed
Hoping to call this one before the weekend is over.
Does anyone know if the IR sensor ahead of the cockpit on this 'plane? It's 1990 Black Sea trials.
The IR sensor shows on the box-art. Crossed off the sprue map.  Not shown as being fitted on the instructions - but mysteriously appears on the final stage diagram. Not on paint diagrams either.
